Originally Posted by Imp4
Originally Posted by Gokhan
Go with the M1 HM. You know it's radically different than the vanilla HM and has a lot more seal swellers and cleaning ability...
Oy vey!!!
What 'seal swellers' and 'cleaning ability' can be documented in a TDS???
Are you ever going to read the posts before you reply to them?
The Super Tech and Super Tech HM are identical formulations to every decimal in the the detailed data sheets. The M1 vanilla and M1 HM are entirely different formulations.
The answer to your question regarding the details of the seal swellers and cleaning ability is obviously whatever they choose to document:
https://www.mobil.com/en-US/Passenger-Vehicle-Lube/pds/NA-XX-Mobil-1-High-Mileage-Oils
Note 1 -- If your engine has excessive sludge deposits due to less-than-adequate maintenance practices, Mobil 1 High Mileage can help by reducing the sludge left behind in your engine. For severe cases of sludge, short oil change intervals (3000 - 5000 miles) are recommended for the first 2-3 oil changes as reduction of the sludge takes place. In cases of engine damage that may have resulted from poor maintenance, even Mobil 1 cannot remedy years of neglect.
Features -- Advantages and Potential Benefits: Seal Conditioner -- Helps to prevent leaks
----------------Super Tech vanilla----------------
Description
ST FS 0W20 dex1 Gen2 6/1Q
Inspection Information Test Method Typical Value
Gravity, °API ASTM D287 35.66
Specific Gravity @ 60°F (15.6°C) ASTM D4052 0.8465
Flash Point, °C ASTM D92 226
Flash Point, °F ASTM D92 439
Viscosity @ 40°C, cSt ASTM D445 44.59
Viscosity @ 100°C, cSt ASTM D445 8.475
Viscosity Index ASTM D2270 170
Pour Point, °C (°F) ASTM D5950 -45°C (-49°F)
Cold Cranking Simulator at (°C), cP ASTM D5293 5800 (-30)
High Temperature / High Shear Vis at 100°C, cP ASTM D6616 5.76
High Temperature / High Shear Vis at 150°C, cP ASTM D5481 2.7
Noack Volatility, % loss ASTM D6375 13
Color ASTM D1500 3
Zinc, wt. % ASTM D5185 0.085
Phosphorus, wt. % ASTM D5185 0.076
Calcium, wt. % ASTM D5185 0.135
Sulfur, wt. % ASTM D4951 0.3
Magnesium, wt. % ASTM D5185 0.059
Boron, wt. % ASTM D5185 0.023
Molybdenum, wt. % ASTM D5185 0.0079
Sulfated Ash, wt. % ASTM D874 0.9
Nitrogen, wt. % ASTM D4629 0.104
Pumping Viscosity at (°C), cP ASTM D4684 21,000 (-35)
Shear Stability, Final Viscosity in cSt ASTM D6278 7.5
Foam Seq. I (Tendency/Stability), mL ASTM D892 (Opt. A) 0/0
Foam Seq. II (Tendency/Stability), mL ASTM D892 (Opt. A) 5/0
Foam Seq. III (Tendency/Stability), mL ASTM D892 (Opt. A) 0/0
High Temperature Foaming, static foam ASTM D6082 (Opt A) 20/0
TBN, mgKOH/g ASTM D2896 7.9
Claims Information
API SN PLUS Approved
API SN Approved
API SM Meets Requirements
API SL Meets Requirements
API SJ, SH, SG, SF, SE, SD, SC Meets Requirements
dexos1 gen 2 Approved by Brand
Chrysler MS-6395 Meets Requirements
ILSAC GF-5 Approved
ILSAC GF-4, GF-3, GF-2, GF-1 Meets Requirements
GM 6094M Meets Requirements
GM 4718M Meets Requirements
Ford WSS-M2C947-A, WSS-M2C947-B1 Meets Requirement
----------------Super Tech HM----------------
Description
WM HM FS 0W20 DX2 6/1Q
Color ASTM D1500 3
Claims Information
API SN Approved
ILSAC GF-5 Approved
