Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Refrigerator runs in cooling mode for 2+ hours.
by mrsilv04 - 03/30/20 09:24 AM
Non Detergent Oil
by 10ecfarmer - 03/30/20 08:06 AM
Joe Diffie on vinyl
by skyactiv - 03/30/20 07:52 AM
cooling system vacuum refill kit
by Donald - 03/30/20 07:35 AM
What's the proper oil for a push mower
by jayjr1105 - 03/30/20 07:31 AM
Honda DW-1 OLD Bottles Question.
by David1 - 03/30/20 06:25 AM
Winter 'shoes' for office goers
by MoneyJohn - 03/30/20 05:54 AM
Life2race, rider9195, kingsville911, B34R, ChrisSnowden
71056 Registered Users
120 registered members (53' Stude, asiancivicmaniac, AC1DD, 14Accent, 2015_PSD, 2009Edge, 14 invisible), 1,850 guests, and 21 spiders.
Topics303,360
Posts5,234,763
Members71,056
Had a AT oil pan leak on my 15 Grand Caravan #5383331 03/22/20 10:32 PM
K
KrisZ Offline OP
K
Someone at Chrysler transmission assembly plant sure messed this one up.
When I did a cooler line ATF exchange over two years ago I did notice a very small wetness on the ATF pan. Well, that recently developed into a small leak. Enough to stain my garage floor.
During the pan removal, once the bolts were loosened a bit, ATF started to leak and the pan dropped without any signs of being adhered by the RTV. To me it looked like the RTV was applied and let sit over an extended period of time, instead of being installed on the transmission. I used a regular gasket on this instead of RTV, since it came with the ATF filter and I hate removing old RTV, which was the most time consuming in this whole process. So hopefully that wasn't a mistake on my part.
On the plus side, I did get to change the ATF filter and clean the magnet, which had a usual amount of break-in, gray sludge.
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: Had a AT oil pan leak on my 15 Grand Caravan [Re: KrisZ] #5383353 03/22/20 11:18 PM
clinebarger Offline
That's been a Chrysler issue since they started RTV pan sealing over 25 years ago. Don't be surprised if the gasket weeps fluid over time!
2001 Chevy Camaro L92/4L80E
Re: Had a AT oil pan leak on my 15 Grand Caravan [Re: KrisZ] #5383357 03/22/20 11:25 PM
Nick1994 Offline
Happened to my grandma's 14' Grand Caravan. I let the dealer reseal it under warranty. That was after we had the engine oil pan and timing chain cover re-sealed under warranty.
2015 Hyundai Genesis 5.0L 58k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 238k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Mobil 1 HM 10w40 & Fram Ultra
Re: Had a AT oil pan leak on my 15 Grand Caravan [Re: KrisZ] #5383399 03/23/20 05:11 AM
demarpaint Offline
That's why I won't use RTV sealant, smart move using a gasket. hide I'd get a gasket too and this. Permatex High Tack That combo hasn't let me down yet.
God Bless Our Troops
Re: Had a AT oil pan leak on my 15 Grand Caravan [Re: KrisZ] #5383402 03/23/20 05:14 AM
L
Lubener Offline
L
That's the reason I always use a gasket and never RTV. If the surfaces aren't perfectly clean and the process is not done right, it will leak. RTV doesn't belong on a automobile. Heck, it did last 5 years for you.
The "thinking" man's friend.
Re: Had a AT oil pan leak on my 15 Grand Caravan [Re: demarpaint] #5383502 03/23/20 08:41 AM
W
WyrTwister Offline
W
Have never used High Tack . But I learned to use Permatex non hardening ( #2 , I think ) 50 years ago . I use it to attach the gasket to the removable part . The pan , in this case . Let it set for a short time then bolt it up .
Wyr
God bless
Re: Had a AT oil pan leak on my 15 Grand Caravan [Re: WyrTwister] #5383618 03/23/20 10:50 AM
K
KrisZ Offline OP
K
I had good luck with gaskets as well. RTV is fine for assembly lines where robots apply the sealer and surface is new and clean. For a shade tree like me though, they are horrible. Horrible to remove, horrible to apply, and good luck getting the surface clean of oil.
I used a little bit of Permatex Ultra Black on the pan to hold the gasket in place. Even if it starts leaking again in five years, at least it will be much easier to deal with... if that time comes.
Re: Had a AT oil pan leak on my 15 Grand Caravan [Re: KrisZ] #5383633 03/23/20 11:05 AM
T
TheLawnRanger Online Content
Online Content
T
This is a confusing topic. Fel-Pro says many of there gaskets have a sealer made into them and the Permatex High Tack will mess it up. On the other hand, I've not heard anyone complain that actually used a sealer.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: Had a AT oil pan leak on my 15 Grand Caravan [Re: KrisZ] #5383658 03/23/20 11:47 AM
A
andyd Offline
A
My Brother showed me about the same time as Wyr. grin2
Thick oil is better grin2
Re: Had a AT oil pan leak on my 15 Grand Caravan [Re: KrisZ] #5383683 03/23/20 12:12 PM
T
Online Content
T
If you use high tack or a sealer just to get the gasket to stick to the removable part of the AT pan, would it effect the part of the gasket that connects to the mating surface?
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Re: Had a AT oil pan leak on my 15 Grand Caravan [Re: KrisZ] #5383716 03/23/20 12:55 PM
sloinker Online Shocked
Online Shocked
When I bought a new transmission pan for my Pentastar van for its drain plug I also used the gasket which came with the new filter. The OE pan also had a gasket, this is a '14 model I purchased with 11 miles on it. When I pulled the top and bottom intake manifolds to replace the leaking oil pressure sender everything was gasketed and/or O ringed. Are there multiple engine/transmission assembly plants that would cause this discrepancy in manufacture. I will never use RTV if there is a OE gasket alternative.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Had a AT oil pan leak on my 15 Grand Caravan [Re: TheLawnRanger] #5383812 03/23/20 03:08 PM
demarpaint Offline
I haven't run across one of those yet. As always I'd make certain everything was spotlessly clean and oil free, then more than likely follow the directions. Given a choice, I'd probably opt for a gasket that doesn't say not to use a sealer until I see a lot of positive feedback on the gaskets you're referring to. I've had such good luck with High Tack it would be hard for me to gamble with anything else.
Re: Had a AT oil pan leak on my 15 Grand Caravan [Re: KrisZ] #5384385 03/24/20 09:13 AM
J
JTK Online Content
Online Content
J
I don't recall if the pan on the 62TE in our 2013 came from the factory with a conventional gasket or RTV. When I had a local transmission shop do a pan drop, filter and fluid refill on it, they used gray RTV and a not so pretty job of it. I think I had the pan drop done at around 40K miles and we had about 75K on that van when we traded it in. No issues with it. Great van.
It's about impossible to do a quick turnaround pan drop and reinstall and not have some ATF on the mating surfaces by the time you get the pan re-installed. It's hope for the best with RTV I guess.
Another reason that makes the newer plastic pans with the gasket built into it like on the ZF8's great. No worries.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
