Originally Posted by 007
Only issue with the service is that you can't expect meat, bread, fresh fruit and veggies like you would pick yourself off the shelf or things where expiration dates are a concern as they don't do that . For other stuff NO problems!
If you get something like bread that's close to expiration (pretty unlikely these days) then just freeze it and take out bread as needed.
I did the on-line order and pick-up at my local Fred Meyer today and it worked out great. There were some items not available, but that's OK because the stuff I really need came through. I even asked them to pick the greenest bananas they had, and they came through, so they do read any special instructions you give.
The milk was only available in 1 gallon size (usually only buy 1/2 gallon jugs), so I froze a couple of qt sized containers of the milk to make it last longer. Haven't tried freezing milk before, but on-line info says it works OK. Just put it in the refrigerator a day before you need it and let it thaw slowly. Will be interesting to see if I can tell if it's been frozen or not.
