VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 04/01/20 02:41 PM
NEW Adam's Polishes - Hand Sanitizer
by SavagePatch - 04/01/20 02:40 PM
Home vehicle modification fails
by IMSA_Racing_Fan - 04/01/20 01:57 PM
Internet speeds in current climate.
by sloinker - 04/01/20 01:55 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
113 registered members (53' Stude, 2004tdigls, Alfred_B, Al, 2010Civic, 2009Edge, 12 invisible), 1,926 guests, and 24 spiders.
Topics303,447
Posts5,235,425
Members71,072
Does cleaning out the intake manifold have any measurable effect? #5383186 03/22/20 06:35 PM
A
atikovi Offline OP
A
Changed the spark plugs and wires on my 99 Taurus with the 24V Duratec V6 and you have to take off the upper manifold for access. It only has 62,000 miles so it wasn't too dirty, but I cleaned the lower manifold.
Before,
[Linked Image from fototime.com]
After,
Does this make a noticeable difference in performance? The upper intake is similarly dirty. Should I clean that too?
Re: Does cleaning out the intake manifold have any measurable effect? [Re: atikovi] #5383194 03/22/20 06:46 PM
Dave9 Offline
No, cleaning it makes no difference except where the deposits cause restrictions. I suppose it could be argued that thick deposits make a small restriction anywhere for a tiny % benefit. However it may reduce the rate at which any local sensors get fouled, and of course help to make a better seal where gaskets are involved, and reduce the chance that any later (especially cleaning solvent sprayed in) dislodged chunks of deposits could make their way to valves and cylinders.
If having it apart makes a PCV valve easier to access, now might be a good time to replace that too.
As far as cleaning the upper intake, sure why not? I just wouldn't do much more than a spray cleaner, no elbow grease and scrubbing unless there's thick deposits stuck in place.
Re: Does cleaning out the intake manifold have any measurable effect? [Re: atikovi] #5383196 03/22/20 06:51 PM
A
atikovi Offline OP
A
OK, at least it looks pretty.
Re: Does cleaning out the intake manifold have any measurable effect? [Re: atikovi] #5383219 03/22/20 07:30 PM
L
Leo99 Offline
L
Looks a lot better. Brake cleaner?
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: Does cleaning out the intake manifold have any measurable effect? [Re: atikovi] #5383247 03/22/20 07:57 PM
A
atikovi Offline OP
A
Carb/TB cleaner.
Re: Does cleaning out the intake manifold have any measurable effect? [Re: atikovi] #5383293 03/22/20 09:05 PM
R
Railrust Offline
R
Measurable effect? Not really but it couldn’t hurt.
2018 Chevy Silverado 5.3
2007 Lexus LS460 (deceased)
2008 Honda CRV
(Whatever synthetic oil is on sale or rebate)
Re: Does cleaning out the intake manifold have any measurable effect? [Re: atikovi] #5383384 03/23/20 02:13 AM
G
GMBoy Offline
G
Without all that crud absorbing some of your fuel mixture, you might find a hint more reponsiveness if anything. Regardless - it needed to be cleaned since it was all apart anyhow.
Re: Does cleaning out the intake manifold have any measurable effect? [Re: atikovi] #5383398 03/23/20 05:07 AM
L
Lubener Offline
L
I was told by someone once that a lot of carbon there could lean things out. I am on the fence with that. Myself, I would clean it up since it is staring me in the face and could prevent those throttle plates from sticking someday.
The "thinking" man's friend.
Re: Does cleaning out the intake manifold have any measurable effect? [Re: atikovi] #5383559 03/23/20 09:46 AM
CT8 Offline
Where did all the stuff go that you removed from the intake runners?
2015 F150 2.7
2018 F350 6.2
Re: Does cleaning out the intake manifold have any measurable effect? [Re: atikovi] #5383564 03/23/20 09:49 AM
A
atikovi Offline OP
A
It will probably get burned up the next time I start it.
Re: Does cleaning out the intake manifold have any measurable effect? [Re: atikovi] #5383625 03/23/20 10:57 AM
F
Fordiesel69 Offline
F
I think it is worth cleaning. You would need an engine dyno to see the difference, I dont even think a chassis dyno would be able to tell. That 3.0L duratec must have been a costly as none in my area have the badge. I remeber the mercury sable I drove had that engine and it was very smooth and quiet compared to the vuclan 3.0L push rod engine.
99' Crown Vic Police - SAP (P71)
00' Crown Vic Police - SAP (P71)
08' Crown Vics Police - SAP(P71's) (total of 3 garage queens)
13' Taurus Police
14' Fusion S Base
