Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Refrigerator runs in cooling mode for 2+ hours.
by mrsilv04 - 03/30/20 09:24 AM
Non Detergent Oil
by 10ecfarmer - 03/30/20 08:06 AM
Joe Diffie on vinyl
by skyactiv - 03/30/20 07:52 AM
cooling system vacuum refill kit
by Donald - 03/30/20 07:35 AM
What's the proper oil for a push mower
by jayjr1105 - 03/30/20 07:31 AM
Honda DW-1 OLD Bottles Question.
by David1 - 03/30/20 06:25 AM
Winter 'shoes' for office goers
by MoneyJohn - 03/30/20 05:54 AM
2004 FZ6 Delo 400
by thestockie1 - 03/30/20 04:34 AM
Turn signals all blinking fast
by JHZR2 - 03/30/20 12:14 AM
New Ram... thoughts by owners?
by wallyuwl - 03/29/20 11:38 PM
rider9195, kingsville911, B34R, ChrisSnowden, DIY4quality
71055 Registered Users
118 registered members (440Magnum, 007, 53' Stude, 4WD, 762fermeandyou, 55hambone, 7 invisible), 2,131 guests, and 21 spiders.
Topics303,357
Posts5,234,708
Members71,055
ACEA A5 Oil #5382721 03/22/20 09:19 AM
K
knerml Offline OP
K
Does anyone know of any ACEA A5 synthetic oil that is 5W40? Can only find 5W30.
Also, are there ACEA standards that are "above" A5?
Trying to reconcile Hyundai's oil recommendations for the 20.T engine.
Thanks.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W30 & OEM Filter
2018 Hyundai Santa Fe Sport AWD 2.0T Mobil 1 5W30 & OEM Filter
Re: ACEA A5 Oil [Re: knerml] #5382762 03/22/20 09:49 AM
T
Triple_Se7en Offline
T
Put "ACEA A5 synthetic oil that is 5W40" in your Google Search box. You will get that info you seek quickly.
Also, Santa Fe has forums / messageboards that are helpful to me, another owner like yourself. I will not post that info here. But again, google is your friend.
Keep Your Pistons Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul X-Line 2.0 MPI - both Pennzoil Ultra Plat. 5W30 / AC Delco PF1127 Ecores
04 Chev Colorado Napa Syn 0w20 & K&N
Re: ACEA A5 Oil [Re: knerml] #5382786 03/22/20 10:04 AM
blupupher Offline
5w-40 has a HTHS that is too high for the A5 rating.
API SM is allowed for Hyundai, and a lot of xw-40 oils out that meet that spec.
edit: weird, just looked at the owners manual, and the 2.4 has SM, ILSAC GF-4 or above, ACEA A5 or above listed, but the 2.0T only has ACEA A5?
Which is weird since their temp chart for the 2.0T allows for 5w-30, 5w-40, 10w-30, 15w-40 and 20w-50, but only 5w-30 meets the A5 spec.
there is a little disclaimer at the bottom of the temp chart that says:
For better fuel economy, it is recommended to use the engine oil
of a viscosity grade SAE 5W-30 (API SM / ILSAC GF-4). However,
if the engine oil is not available in your state, select the proper
engine oil using the engine oil viscosity chart.
This should allow for whatever to be used, but again, is a bit vague.
If you are really concerned about warranty, the you should stick to a A5 rated oil.
Me personally, I would not worry about it. Just keep the receipts/proof of oil change and use a quality oil and you should be fine.
'18 Santa Fe: PP 10W30/OEM
'18 Soul: Synpower 5W30/ProGuard
'12 xB: M1 EP 0W20/CQ Blue
'10 Santa Fe: Synpower 5W30/D+
'04 F150: Magnatec 10W30/ST
'02 F150: Magnatec 5W20/D+
'94 VT1100: Peak 15W40/D+
Re: ACEA A5 Oil [Re: knerml] #5382826 03/22/20 10:33 AM
V
Virtus_Probi Online Mad
Online Mad
V
I wonder how many states have banned 5W30??
2014 Forester XT, 114800 miles
Last Change;
Valvoline AFS 5W30
Tokyo Roki 15208AA170 oil filter
Subaru 16546AA10A air filter
Re: ACEA A5 Oil [Re: knerml] #5382830 03/22/20 10:38 AM
T
T
Us the ACEA A5 5w30 spec and the empty Pennzoil Platinum bottle I have in the garage, meets the spec.
Re: ACEA A5 Oil [Re: knerml] #5382857 03/22/20 11:03 AM
P
Polyalphaolefin Offline
P
In my kia ceed I use A5 oil (5w30) only on winter, on summer I use A3 5w40
Car: KIA Ceed JD 1.4 MPI
OIL: 5w30 ACEA A5 / A3; 5w40 ACEA A3; 0w40 ACEA A3
Re: ACEA A5 Oil [Re: Triple_Se7en] #5382884 03/22/20 11:28 AM
Snagglefoot Offline
Ultra Platinum as well.
If you want the job done right......do it yourself.
Re: ACEA A5 Oil [Re: knerml] #5382887 03/22/20 11:31 AM
M
Mainia Offline
M
This is just me, but as a Hyundai turbo owner who puts heavy use on his engine, I fully discounted their "recommendation " for a thin A5/B5 oil. I am running Mobil 1 5w-30 ESP which is far superior of an oil with German certs guaranteeing quality in a rough service scenario vs their "mileage only" scenario. Hyundai uses the words "it is recommended" to use A5/B5, HOWEVER they give you an out allowing other oils to use if there are none in the country. We have seen Hyundai send out TSBs to mandate the use of ONLY 5w-40 oil in their 2.0T years ago because of their, ongoing to this date oil film barrier issues that take out rod bearings and then the whole engine. I know, my Elantra GT needed a new motor at 14,000 miles because they can't seem to figure out their high occurrence of why they take out rod bearings in almost every model engine they make at a higher percentage then any other manufacture. 8 years and we still have this as an issue. My 1.6T engine is one of their engines that has the least of this happening thank God. Asian auto manufacture are not known for robust oil specs.
I have a high fuel dilution problem very close to the same as the 1.5T Honda's. It is a non issue, since I do regular wear testing and I have no wear issues. I am over 5% @Polaris Labs advanced test. The one you have to force them to do, vs the default, almost no accuracy nothing test. I will not run any Dexos 1 Gen2, I want as close to 12.0 @ 100C as a minimum and a HTHS 3.5 as a minimum.
5w-30 and 5w-40 -30F to 120+F
10w-30 0F to 120+F
15w-40 10F to 120+F
20w-50 20F to 120+F
I will risk them "trying" to void my warranty when my choice of oil that falls in their very wide spec for viscosity for this 1.6T engine as per the manual viscosity approved and my choice of oil far exceeds their oil for rough service that my engine sees from time to time. German cert oils are known to be the best called out oil specs for rough service that the common man can buy without access to factory oil and race teams. I really think it is a non issue. I plan and have a strategy to fight them if it every becomes an issue in a warranty claim. You learn quickly, Hyundai loves to screw you on warranty if they can. They have the best warranty on paper, but not when it comes to reality. The Magnuson-Moss Warranty Act had to be called out when they first tried to deny my 14,000 mile Elantra GT because it had a Fram Ultra on it.
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: ACEA A5 Oil [Re: blupupher] #5382920 03/22/20 12:07 PM
K
knerml Offline OP
K
The other confusing fact is that Hyundai recommends using Quaker State oil in the owners manual, and I do not believe they offer ACEA A5 oils.
Moving to Phoenix and thinking about using Castrol Edge 5W40.
Re: ACEA A5 Oil [Re: knerml] #5383072 03/22/20 04:16 PM
G
Gokhan Online Content
Online Content
G
Korean oil recommendations are a mess.
All they mean by A5/B5 is a synthetic oil with HTHS ~ 3.0 cP. In US this translates into a GM dexos1 Gen 2/Gen 3 5W-30.
You can also run a high-HTHS oil (HTHS ≥ 3.5 cP), but make sure it's mid-SAPS, meaning ACEA C3 or GM dexos2; otherwise, full-SAPS oils like ACEA A3/B4 will increase the rate of the accumulation of the intake-valve deposits in your GDI/TGDI engine. SAPS means sulphated ash, phosphorus, and sulfur, and you ideally need to keep the SA at or below 0.8%.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 70 mpg on gas, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: ACEA A5 Oil [Re: Gokhan] #5383167 03/22/20 06:10 PM
M
Mainia Offline
M
Isn't Mobil 1 ESP 5w-30 a low SAPS? The old formula had 0.6% ash, but the newer formula has 0.8% ash.
https://www.mobil.com/en/lubricants/for-personal-vehicles/our-products/products/mobil-1-esp-5w-30/
2005 Honda Civic
Re: ACEA A5 Oil [Re: Mainia] #5383210 03/22/20 07:13 PM
G
Online Content
G
These are the ACEA SAPS definitions for PCMO (gas and light diesel, the A/B, C, and upcoming G categories):
Low-SAPS: SA ≤ 0.5%
Mid-SAPS: 0.6% ≤ SA ≤ 0.8%
Full-SAPS: 1.0% ≤ SA ≤ 1.6%
I guess oils with 0.9% SAPS fall in between mid-SAPS and full-SAPS.
Low-SAPS oils are virtually nonexistent as there are only one or two engines that specify them (some Peugeot or Opel diesel engine?), and those specs may go away soon because they're not worth the trouble.
Re: ACEA A5 Oil [Re: knerml] #5383233 03/22/20 07:44 PM
M
Mainia Offline
M
So it's mid SAPS, good. Thanks.
2005 Honda Civic
