Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Refrigerator runs in cooling mode for 2+ hours.
by mrsilv04 - 03/30/20 09:24 AM
Non Detergent Oil
by 10ecfarmer - 03/30/20 08:06 AM
Joe Diffie on vinyl
by skyactiv - 03/30/20 07:52 AM
cooling system vacuum refill kit
by Donald - 03/30/20 07:35 AM
What's the proper oil for a push mower
by jayjr1105 - 03/30/20 07:31 AM
Honda DW-1 OLD Bottles Question.
by David1 - 03/30/20 06:25 AM
Winter 'shoes' for office goers
by MoneyJohn - 03/30/20 05:54 AM
Life2race, rider9195, kingsville911, B34R, ChrisSnowden
71056 Registered Users
111 registered members (53' Stude, 2K2AcuraTL, 4WD, 928, 14Accent, 2015_PSD, 11 invisible), 1,844 guests, and 21 spiders.
Topics303,360
Posts5,234,763
Members71,056
Disc brake tools #5382690 03/22/20 08:47 AM
Donald Offline OP
What are the advantages of one of there tool sets vs a C clamp. Or two C clamps.
https://www.amazon.com/OrionMotorTe...84690&sprefix=disc+brake+&sr=8-3
2015 Ford F-250 w/Powerstroke
Re: Disc brake tools [Re: Donald] #5382692 03/22/20 08:51 AM
FowVay Offline
On many vehicles that have the parking brake controlled through the caliper, it is required to thread the piston back into the caliper to reset it. If you try to just force it back in with a c-clamp you will destroy the caliper.
A c-clamp works fine on the front calipers but may not work on the rear.
Re: Disc brake tools [Re: Donald] #5382697 03/22/20 08:53 AM
O
Olas Offline
O
depends if you're working on the front or the back axle
front brakes will push straight back with c-clamp or vice or whatever
rear brakes need to rotate as the piston goes into the caliper, so you need the tool in the link to turn the piston without marking it.
Cable ties should hold it
Re: Disc brake tools [Re: FowVay] #5382702 03/22/20 08:59 AM
J
JC1 Offline
J
+1. Some people use needle nose pliers to retract the piston.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Disc brake tools [Re: Donald] #5382730 03/22/20 09:25 AM
K
krismoriah72 Offline
K
I have a couple of these and a couple of c-clamps..havent been stumped yet
[Linked Image from cdn.1aauto.com]
Re: Disc brake tools [Re: Donald] #5382750 03/22/20 09:39 AM
CleanSump Offline
I have one of those sets. However, I only use it for rear calipers that screw in. C-Clamps are quicker and easier for standard push-in pistons.
E320 OM642 2008
Blazer 4.3L 1997
Yamaha Bolt 2014
Enfield 1954
Re: Disc brake tools [Re: Donald] #5382757 03/22/20 09:45 AM
J
JustinH Offline
J
I bought this identical set to do rear brakes on our Scion. It worked fine, and included adapters for most cars I would own.
'16 Ford Escape
'11 Scion XB
Re: Disc brake tools [Re: Donald] #5382763 03/22/20 09:50 AM
W
wayne50 Offline
W
A really big bladed screwdriver works well.
Re: Disc brake tools [Re: krismoriah72] #5382806 03/22/20 10:15 AM
Donald Offline OP
How is this used?
Re: Disc brake tools [Re: FowVay] #5382809 03/22/20 10:17 AM
Donald Offline OP
But if my parking brake is shoes then caliper piston does not screw in and C-clamp is enough? Correct?
Re: Disc brake tools [Re: Donald] #5382812 03/22/20 10:21 AM
javacontour Offline
Many rear calipers are screw in and have indents in the piston. You find the face of the cube that matches the piston and use an extension and ratchet to wind the piston back into the caliper.
How is this used?
network down, IP packets delivered via UPS -BOFH
Re: Disc brake tools [Re: Donald] #5382825 03/22/20 10:31 AM
J
JeffKeryk Offline
J
Free rental at O'Reilly works for me.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Disc brake tools [Re: krismoriah72] #5382842 03/22/20 10:52 AM
5
50jeffrey Offline
5
This was too small for when I did my friend's 2011 VW Jetta. Was able to use a c-clamp, as the 'head' rotated and along with the pressure of the clamp I was able to twist the piston in. Got lucky with that. Wasn't having any success with needle nose pliers, either.
Re: Disc brake tools [Re: Donald] #5382845 03/22/20 10:54 AM
CaptainHazelwood Offline
That cube socket or needle nose don't work on VW rear calipers, or at least not well. They require a lot of force while being twisted in.
Re: Disc brake tools [Re: Donald] #5382865 03/22/20 11:08 AM
B
bobbobtar Offline
B
I also bought the same set but use it on the rear brake of a 2019 CanAm Spyder.
2020 Chevy Silverado LT 1500 3.0L diesel
2018 John Deere 2032R
2019 F3 CanAm Spyder
1981 Chevy Malibu 355cu 425hp
