RV's for MD's
by 02SE - 04/07/20 01:42 AM
Crawfish, It's A Louisiana Thang!
by BlueOvalFitter - 04/07/20 01:01 AM
M&P .40 Magazines $12.99
by BlueOvalFitter - 04/06/20 11:30 PM
Lots of Big Sur pics, only one of the car :-)
by SLO_Town - 04/06/20 09:24 PM
'16 Pilot Inline ATF filter
by parshisa - 04/06/20 08:55 PM
2019 Ram 1500 Classic
by Skippy722 - 04/06/20 08:53 PM
STP S3614 XL CUT OPEN
by 53' Stude - 04/06/20 07:15 PM
Kia Rio awful sound after sitting 5 years
by antonmnster - 04/06/20 07:13 PM
Cut open Motorcraft FL820S
by PantherFan88 - 04/06/20 06:38 PM
240V Electric Hookup Questions
by 92saturnsl2 - 04/06/20 06:33 PM
license plate frame with 3rd brake light
by wings&wheels - 04/06/20 06:12 PM
Wurth HHS 2000
by ejt - 04/06/20 06:06 PM
Snapper drive belt install trouble LT300
by spk2000 - 04/06/20 05:56 PM
installing garage LED shop light help needed
by FirstNissan - 04/06/20 05:20 PM
Casite filters
by opus - 04/06/20 05:16 PM
Oil for Jeep
by rokwldr - 04/06/20 05:12 PM
Kitchen sink faucet leak help
by 97prizm - 04/06/20 04:45 PM
RIP Al Kaline.
by PimTac - 04/06/20 04:36 PM
Frankentruck power steering question
by Thomcat316 - 04/06/20 04:11 PM
Comment from Miata track on Amsoil GL-4
by Bill_W - 04/06/20 03:28 PM
BludRacing, Cacciatore, Thomcat316, NTexian, LateLifeCrisis
71116 Registered Users
31 registered members (blufeb95, edhackett, Char Baby, 73guna, alcyon, 3 invisible), 1,133 guests, and 20 spiders.
Topics303,700
Posts5,240,225
Members71,116
DIY projects with UMO? #5382512 03/21/20 11:02 PM
cwilliamsws6 Offline OP
I have a 5 gallon bucket in my garage which is full of a mixture of motor oil, gear oil, transmission fluid, power steering fluid, and brake fluid. No antifreeze or non-lubricant type liquids in there.
Before I take this nasty concoction to the recycler does anyone know of any DIY projects or alternate uses I could give it? I was contemplating making a waste oil furnace for my garage or just burning it off in my 2 stroke generator in place of 2 stroke oil.
So what should I do? Dump it (not literally, by that I mean take it to the proper facility), or get creative and put it to a new use?
2007 Honda CR-V LX "The Linoleum Falcon" 210K miles
HK conv 5w20, STP blue bottle, PrimeGuard POF4610 filter.
"Bad decisions make good stories."
Re: DIY projects with UMO? [Re: cwilliamsws6] #5382516 03/21/20 11:06 PM
R
rubberchicken Offline
R
Donate to somebody that has a waste oil furnace , or possibly a machine shop could use it for cutting oil ? I am not a machinist so this could be a silly suggestion.
Re: DIY projects with UMO? [Re: cwilliamsws6] #5382524 03/21/20 11:26 PM
K
KGMtech Offline
K
Your local oil recycling center will be able to take this brew. The stuff ends up at re-refineries that can break down the mixture to base components, this is what they do best.
Burning it is not what I would recommend, as there are metals in that mix that might not be so good downwind.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: DIY projects with UMO? [Re: cwilliamsws6] #5382575 03/22/20 01:09 AM
Dave9 Offline
A mere 5 gallons is not worth any effort more than taking it to a recycler.
However, you could spray it on the underside of vehicles as a rust preventative, maybe mix some grease and gasoline together first to liquify those two, before mixing it into your oil, so it has better staying power.
Do not burn it in a 2 cycle engine unless you're in the mood to clean off a tarry, ashy mess from the exhaust port, muffler, cylinder, piston, and probably carb too (oil finds its way backwards enough to matter).
Re: DIY projects with UMO? [Re: Dave9] #5382765 03/22/20 09:51 AM
J
Jstew Offline
J
Around my property I use it as a fire starter - we have 10 acres and are always burning brush. I pour about a gallon of it on my brush pile and then light with newspaper. BTW, mine always contains a mix of brake fluid and trans fluid too!
1969 Chevrolet Corvette / 65K / Brad Penn 10w30
2003 Pontiac Vibe / 155K / QSUD 5w30
2008 Toyota Sienna AWD / 160K / QSUD 5w30
2014 Dodge Durango RT 5.7 / 27K / Redline 5w20
Re: DIY projects with UMO? [Re: cwilliamsws6] #5383866 03/23/20 03:53 PM
T
Tyson Offline
T
I've seen it used as a preservative on trailer decking, and also on concrete forms.
