Originally Posted by Triple_Se7en
One time with my Chevy S10 4X4, I was stumped as to why my defrost and floor heat cycles didn't work, at any blower speed. All that worked was the bi-level setting.
Turns out there was a damaged hose right at / near the transfer case, underneath the vehicle. Once that was replaced, all my defroster, bi-level and floor heat settings began to work again.
Indeed the Ranger's cab HVAC controls are via vacuum, but it all originates from one tee off the intake next to to brake booster line. Easily capped off for testing and eliminated as a source of trouble. Great thought tho as the HVAC control / manifold vacuum connection is easily overlooked.
