Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
C&P Allison Transmission Filter - 27k miles, 3 years
by shibby6600 - 05/28/20 05:51 PM
XG9100 - 7k miles - 9 months - filter magnet
by shibby6600 - 05/28/20 05:47 PM
2017 Audi A4 PCV Valve replacement
by dbias - 05/28/20 05:23 PM
Audi E-Tron Technik
by OVERKILL - 05/28/20 05:12 PM
Deer 1....My Avalon 0
by ZZman - 05/28/20 03:21 PM
Auto Dealers Supplies?
by cknight49090 - 05/28/20 03:09 PM
interesting video reg vs premium
by raaizin - 05/28/20 02:55 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
17 registered members (4WD, dave1251, blufeb95, ctechbob, BusyLittleShop, BlueOvalFitter), 1,071 guests, and 42 spiders.
Topics305,999
Posts5,284,442
Members71,558
2006 VW Jetta 2.5 spark plugs #5382145 03/21/20 01:36 PM
SEMI_287 Offline OP
New to me 135k. May be factory plugs, I'm more sure. They looks pretty good! No signs of anything wrong or burning oil. Replaced the stock VW coils with Audi red tops.
2005 BMW 325xi- M1 0w40
2007 Chrysler 300C- M1 0w20
2006 Jetta 2.5- Edge 0w30
2007 Audi A4 3.2- Edge 0w30
Re: 2006 VW Jetta 2.5 spark plugs [Re: SEMI_287] #5382198 03/21/20 02:35 PM
L
LazyDog Offline
L
keep an eye on the PCV which is part of the valve cover, they have to be replace at some point.
Re: 2006 VW Jetta 2.5 spark plugs [Re: SEMI_287] #5382211 03/21/20 02:56 PM
A
Audios Offline
A
Looks great, great engines!
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: 2006 VW Jetta 2.5 spark plugs [Re: LazyDog] #5382219 03/21/20 03:04 PM
SEMI_287 Offline OP
I'm assuming the whole valve cover has to be replaced? They're a great little engine! Not the fastest car I've owned but midrange torque is nice.
Re: 2006 VW Jetta 2.5 spark plugs [Re: SEMI_287] #5382227 03/21/20 03:14 PM
A
ARCOgraphite Offline
A
When 4 is too small and 6 is too big - 5 is just right.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: 2006 VW Jetta 2.5 spark plugs [Re: SEMI_287] #5382460 03/21/20 09:47 PM
Chuckh Offline
I had a 2006 Jetta 2.5 and had the PCV valve problem. I don't think the individual parts for that were available at that time. I found this kit here at Advance Auto Parts. One thing to keep in mind is that there may be other brands if you don't like this one for some reason but here it is:
VW PCV diaphragm repair kit
I just thought you might want to see that before you spend all that money replacing an otherwise good valve cover. I don't get why those parts were not available before.
Re: 2006 VW Jetta 2.5 spark plugs [Re: SEMI_287] #5382467 03/21/20 09:54 PM
Chuckh Offline
The VW 2.5 has not changed much. My 2006 Jetta had a MAF sensor but that is missing on 2013. My guess is they switched to MAP on later models. Other than that everything looks the same so it is possible that it would also work on later models.
Re: 2006 VW Jetta 2.5 spark plugs [Re: SEMI_287] #5382470 03/21/20 09:56 PM
R
raaizin Offline
R
One fun fact this engine uses the head from a Lamborghini Gallardo V-10
That change also makes it possible for the new engine to use one Lamborghini part--the aluminum-alloy 20-valve cylinder head found on one bank of the Gallardo's V-10. This greatly improves the engine's breathing over the two-valves-per-cylinder head on the previous four-cylinder Jetta. Combined with variable intake-valve timing, the result is peak torque of 168 pound-feet, up 38 percent from the old engine, despite just a 25-percent displacement increase. Peak power is up 30 percent to 148 horsepower, proving the new engine is biased toward torque.
Here is link for article
https://www.caranddriver.com/reviews/a18202887/volkswagen-jetta-road-test/
Re: 2006 VW Jetta 2.5 spark plugs [Re: SEMI_287] #5383042 03/22/20 03:22 PM
Chuckh Offline
I read that somewhere once. Volkswagen owns Lamborghini so it would be easy for them to use the already existing parts from other vehicles such as those. Rather than spending all that money to design a new part for the 2.5 they just used that instead and made the 2.5 block work with it. The newer non TFSI 2.5 is 170 HP. If the Passat was not my only car it would be nice to get a hold of the 2.5 from a TT RS but good luck keeping tires on that thing.
Re: 2006 VW Jetta 2.5 spark plugs [Re: SEMI_287] #5384278 03/24/20 06:34 AM
SEMI_287 Offline OP
I heard the I5 and the V10 have a lot in common. I've heard you can use the V10 head but I didn't look deep enough to confirm. It handles great and the suspension looks to be less complex than my BMW. I noticed on the back of the motor it's a little wet, I thought maybe a weeping rear main but I dug further and it looks like the vacuum pump gasket is kaput. Watched a couple videos and it seems easy. Seems I'll need a vag-com cable too.
Re: 2006 VW Jetta 2.5 spark plugs [Re: SEMI_287] #5384304 03/24/20 07:20 AM
O
Olas Offline
O
after reading that they share the same boreXstroke, it must be hard to resist ordering rods and pistons to up the compression and then it would make sense to do the camshafts too, it would be close to 'half a lambo motor'. you should contact APR to see if they'd be interested in using yours as a development car wink
