Local dealership charges $15 for an oil change.....
by Harrington - 04/04/20 02:57 PM
Did harvest king change suppliers?
by Micahmcmeen - 04/04/20 02:30 PM
Switching back from High mileage to regular.
by Micahmcmeen - 04/04/20 02:28 PM
Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Penne alla Boscaiola
by vavavroom - 04/04/20 10:05 AM
Fuel stabilizers for e10 gas - long storage
by caprice_2nv - 04/04/20 09:59 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
111 registered members (55hambone, 2015_PSD, 762fermeandyou, 01rangerxl, 4WD, 41Pack, 9 invisible), 2,608 guests, and 18 spiders.
Topics303,589
Posts5,237,888
Members71,094
Cabin Filter Change Interval #5382394 03/21/20 08:25 PM
R
rrretiree7 Offline OP
R
I have a 2010 Caddy CTS. How often should I change the filter? Thanks for your help
Re: Cabin Filter Change Interval [Re: rrretiree7] #5382403 03/21/20 08:34 PM
U
UG_Passat Offline
U
Try starting with what the owner's manual recommends for the factory type replacements.
Those "HEPA" or equivalents (Such as Mann Frecious Plus), then you follow the manufacturer's recommendations.
https://my.cadillac.com/content/dam...sedan/2010_cadillac_cts_sedan_owners.pdf
Page 10-5
Every 25,000 miles.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Cabin Filter Change Interval [Re: rrretiree7] #5382415 03/21/20 08:44 PM
Quattro Pete Offline
Mine get changed once every 2 years, low annual miles.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Cabin Filter Change Interval [Re: rrretiree7] #5382416 03/21/20 08:45 PM
B
BurntMusic Offline
B
Owner's Manual
Section 10-5
First Engine Oil Change After
Every 40 000 km/25,000 Miles
. Fuel system inspection for
damage or leaks.
. Passenger compartment air
filter replacement (or every
12 months, whichever occurs
first). More frequent replacement
may be required if vehicle is
driven regularly under dusty
conditions
2017 VW Golf 1.8T (Castrol 5w40 dealership bulk + OEM filter)
PP Euro 5w40 SN Plus VOA
Re: Cabin Filter Change Interval [Re: rrretiree7] #5382429 03/21/20 09:03 PM
csandste Offline
Changed mine at 30,000 miles. Relatively clean.
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Cabin Filter Change Interval [Re: rrretiree7] #5382488 03/21/20 10:13 PM
Donald Offline
Change in Oct so you can check for mouse nests. They like to build them on top of the cabin air filter. In the spring you can pull it and vacuum.
2015 Ford F-250 w/Powerstroke
Re: Cabin Filter Change Interval [Re: rrretiree7] #5382526 03/21/20 11:29 PM
Marco620 Offline
Had mine for 316,000 miles. Just wash it out with soap and water. K&N VF2007 I will say the OE filtered better but being able to reuse has been a plus.
15' Civic 1.8 i-vtec 319,500 mi M1 0w30 & LG Biotech,Castrol CVT Fluid,GUMOUT/ PEA
Doberman Whisperer! HondaGuru.
E pluribus unum.
Re: Cabin Filter Change Interval [Re: rrretiree7] #5382561 03/22/20 12:26 AM
R
Rolla07 Offline
R
Depends on alot of factors. I like changing mine once or twice a year.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Cabin Filter Change Interval [Re: rrretiree7] #5382617 03/22/20 06:28 AM
silversport Offline
it is easy enough to check on many cars...pull the filter and look at it (unless it is a charcoal one as it might be harder to tell)...then give it a sniff...clean and no odor?...leave it be for a bit...smells or dirty looking, change it out...
Bill
Re: Cabin Filter Change Interval [Re: rrretiree7] #5382623 03/22/20 06:58 AM
E
Egg_Head Offline
E
I change mine annually, after the pollen has finished falling.
1979 Garelli Rally Sport
2009 Cub Cadet LT1042
2002 BMW 540 M Sport (totaled)
2011 MB E350 4Matic wagon
1979 CJ-7
1978 K-5 Blazer 400ci
Re: Cabin Filter Change Interval [Re: rrretiree7] #5382647 03/22/20 07:51 AM
F
FT92 Offline
F
well my first change was at 80K probably could have left it in there for another 10K or so wasn't all that bad...
Re: Cabin Filter Change Interval [Re: rrretiree7] #5382675 03/22/20 08:34 AM
Snagglefoot Offline
I bought several Fram Charcoal types on clearance at Rock Auto. Once per year works for me. They were cheap so I just change them even though they aren’t too bad. Otherwise, I run the risk of getting rid of the cars before I’m out of filters. smile
If you want the job done right......do it yourself.
Re: Cabin Filter Change Interval [Re: rrretiree7] #5383600 03/23/20 10:24 AM
P
painfx Online Content
Online Content
P
You guys still change it even if it is still clean?
I find that at 25k it is still clean.
Re: Cabin Filter Change Interval [Re: rrretiree7] #5383616 03/23/20 10:45 AM
T
TheLawnRanger Online Content
Online Content
T
Just check it. I've done 100,000 miles on one vehicle and it was fine. I've had another that was filthy after 20,000 miles. It depends on what and where you drive.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: Cabin Filter Change Interval [Re: rrretiree7] #5383660 03/23/20 11:48 AM
supton Offline
I try to do twice/year, if I go a year they tend to look kinda plugged up. Maybe they aren't, but they'll have leaves, acorns and look awful. But a year is 25kmiles and the cars were parked outside--now that they are parked indoors maybe once/year will be just fine.
I try to buy in bulk so as to knock down the price. I don't feel a need for fancy but I wouldn't rule them out either--when my allergies are kicking I really do like the notion of having clean filtered air in the car (a good pollen filter that is).
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
