KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
MC FL500S 7,000 miles CUT OPEN
by 53' Stude - 04/03/20 03:43 PM
USS Theodore Roosevelt
by BMWTurboDzl - 04/03/20 03:42 PM
2020 Subaru Forester Base
by wagsrk08 - 04/03/20 03:41 PM
New Rislone Hy-per Fuel Product?
by Jackson_Slugger - 04/03/20 03:38 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
41 registered members (bennyG, bachman, blufeb95, Alaskanmont, 928, bernau, 6 invisible), 1,348 guests, and 19 spiders.
Topics303,554
Posts5,237,343
Members71,086
2500hd 4x4 noise #5382388 03/21/20 08:13 PM
chilson450 Offline OP
I've been noticing a noise in the front end of my truck. It's a 2008 Chevy 2500hd. It's only when in 4x4 and changes on acceleration or coasting. I hear it when accelerating mostly or when turning and the wheels are binding. I'm thinking it is in the front differential. I have jacked it up and spun everything by hand but can't seem to find anything noticable. I'm doubting it's a wheel bearing because it's only in 4x4. I drive a similar truck with the same drivetrain for work and the 4x4 is almost silent. So I know something is off on this one. Does anyone have any ideas on what to look for before I pull the differential?
2008 Chevy 2500hd 6.0
2011 Ford Explorer 3.5
Re: 2500hd 4x4 noise [Re: chilson450] #5382392 03/21/20 08:22 PM
spasm3 Offline
Is this on pavement or dirt?
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: 2500hd 4x4 noise [Re: chilson450] #5382398 03/21/20 08:28 PM
B
BlakeB Offline
B
Are the tires all matching? If the tires don’t match it will bind up the driveline because the front and rear tires aren’t spinning at the same speed.
Re: 2500hd 4x4 noise [Re: chilson450] #5382401 03/21/20 08:32 PM
Tires are all matching michelins. I only use 4x4 on dirt or when the roads are snow covered.
Re: 2500hd 4x4 noise [Re: chilson450] #5382410 03/21/20 08:38 PM
spasm3 Offline
I'm assuming you have checked and its not out of gear oil. Is there any chance it has has water in the diff? like crossing a flooded area. Have you owned it since new?
Re: 2500hd 4x4 noise [Re: chilson450] #5382413 03/21/20 08:42 PM
Snagglefoot Offline
I would plan to change the gear oil and clean the magnet on the fill pug. If the plug is absolutely covered full I would clean it, put it back, fill the diff and run it more to clean out any additional filings. Here is a drain plug covered with filings and a shot of the cleaned up drain plug and fill plug from a 2008 3/4 ton Chev.
How many miles?
If you want the job done right......do it yourself.
Re: 2500hd 4x4 noise [Re: chilson450] #5382421 03/21/20 08:54 PM
It's full of gear oil. I bought this truck a little over a year ago and changed the oil after I bought it with Valvoline synthetic 75w90. I recently took the drain plug out to check for shavings on the magnet and it was still clean and so was the oil.
Re: 2500hd 4x4 noise [Re: chilson450] #5382437 03/21/20 09:14 PM
Snagglefoot Offline
It could possibly be the CV axles as well but I’ll defer to the mechanics in the Bitog group.
Re: 2500hd 4x4 noise [Re: chilson450] #5382581 03/22/20 02:24 AM
O
oldhp Offline
O
Did you jack up the whole front end? Did you turn the front wheels full left/right and turn the tires by hand? Is the transfer case full of oil? If you can't find anything at this point, remove the front drive shaft and see if noise goes away. Good Luck !!!
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
