2018 chevy express passenger van
by Fitter30 - 04/04/20 04:01 PM
Twilight Zone
by 2015_PSD - 04/04/20 03:57 PM
Local dealership charges $15 for an oil change.....
by Harrington - 04/04/20 02:57 PM
Did harvest king change suppliers?
by Micahmcmeen - 04/04/20 02:30 PM
Switching back from High mileage to regular.
by Micahmcmeen - 04/04/20 02:28 PM
Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
91 registered members (Andreeas1978, ammolab, 2015_PSD, 41Pack, 55hambone, 6 invisible), 2,449 guests, and 17 spiders.
Topics303,591
Posts5,237,899
Members71,094
What could cause a decrease in oil consumption? #5382349 03/21/20 06:57 PM
M
MCompact Offline OP
M
The car: 2009 Cooper Clubman(N12 engine, no turbo)
I bought the Clubman with 104k miles on it; at that time it was using one quart of oil every 800-900 miles.
At 107k miles I replaced the valve cover as it was thought that a bad PCV valve(integrated into the VC) might be causing the consumption issues.
At 112k the oil was changed, and a non--LL-01 5W-30 synthetic was used(my fault, I neglected to tell the shop to use LL-01). Oil consumption continued to hover around 800-900 miles/quart.
At 116k miles the oil was changed using Mini(BMW) 0W-30. Oil consumption was unchanged until @119k miles- since then oil consumption has dropped to @1500 miles/qt.
There's been no change in driving conditions; I drive it a minimum of 24 miles per day, and it fully warms up during those drives. There are no misfire codes- so it isn't fuel dilution. Fuel economy hovers around 40 mpg.
So, any explanation as to what might have caused the welcome reduction in oil consumption? My guess is the BMW LL-01 oil may have freed-up a stuck oil control ring or two...
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: What could cause a decrease in oil consumption? [Re: MCompact] #5382353 03/21/20 07:01 PM
CT8 Offline
I would call it a miracle .
2015 F150 2.7
2018 F350 6.2
Re: What could cause a decrease in oil consumption? [Re: MCompact] #5382359 03/21/20 07:07 PM
demarpaint Offline
You might have gotten lucky and freed up the rings a bit. Or the car likes the latest fill of oil, it just took it a while to let you know. See what happens during the summer months, that could change things again.
God Bless Our Troops
Re: What could cause a decrease in oil consumption? [Re: MCompact] #5382378 03/21/20 07:53 PM
B
blufeb95 Online Content
Online Content
B
Was the air filter neglected then changed at some point?
Re: What could cause a decrease in oil consumption? [Re: MCompact] #5382396 03/21/20 08:25 PM
javacontour Offline
How many miles on the car/oil now?
I've seen these where they are non-linear. I.E. the first quart may not burn off for 2000 miles. The next one in 1500, the next in 1000 and so on.
Until you go through a complete OCI, it's hard to say if the consumption you current experience is going to continue at the same rate.
network down, IP packets delivered via UPS -BOFH
Re: What could cause a decrease in oil consumption? [Re: blufeb95] #5382453 03/21/20 09:38 PM
M
MCompact Offline OP
M
I changed it at the same time I last changed the oil; I wouldn't say it was neglected at all. Thee same can't be said about the cabin filter, however.
Mine:
2014 M235i
2009 Cooper Clubman
Wife's:
Son's
2009 328i
Re: What could cause a decrease in oil consumption? [Re: javacontour] #5382461 03/21/20 09:47 PM
M
MCompact Offline OP
M
121.8k miles on the car, 5.8k miles on the oil. As for oil usage during the current OCI, as I said, it varied from a high of 920 miles to a low of 790 miles for the first four top-ups. The fifth top-up at 121k was 1,494 miles. As noted, the car now has almost 122k on it and only 0.5 quart of oil has been consumed- so if anything oil consumption has decreased even more.
Mine:
2014 M235i
2009 Cooper Clubman
Wife's:
Son's
2009 328i
Re: What could cause a decrease in oil consumption? [Re: MCompact] #5382472 03/21/20 09:56 PM
Propflux01 Offline
Sounds like rings got unstuck.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: What could cause a decrease in oil consumption? [Re: MCompact] #5382511 03/21/20 11:01 PM
A
antonmnster Offline
A
I had a lawn mower that I bought used that burned so much oil the yard would be a blue haze. But after running it for a summer of my yard - a half acre that was way too much for that little engine, but ran it at 100% for an hour per cut - it stopped using oil.
I think the last owner didn't change the oil that much and the rings are free.
2007 BMW 335i n54 218,000 miles, lubricated by whatever is on sale
Re: What could cause a decrease in oil consumption? [Re: MCompact] #5382519 03/21/20 11:14 PM
R
rubberchicken Offline
R
On the Mini - the valve cover does have an integrated PVC, but I thought that was just for the N14 engine. The valve cover is an expensive item, but it is a fairly easy replacement. Mini's are notorious as consumers of oil, and it is the rare engine that does not consume oil like a Saudi yacht. I am surprised you are not using 5w40 oil, as I believe Mini updated its recommendations . Try that and see if your oil consumption drops further.
My son has a 2009 Cooper S (turbo) and it uses a quart every 1000 miles. It is in rough shape now, and he decided to buy a 2020 Honda Accord Sport.
Re: What could cause a decrease in oil consumption? [Re: MCompact] #5382601 03/22/20 04:22 AM
O
Olas Offline
O
when the only variable is the oil, you have to assume that the oil caused the drop in consumption.
Cable ties should hold it
Re: What could cause a decrease in oil consumption? [Re: MCompact] #5382614 03/22/20 06:09 AM
CourierDriver Offline
With todays technology, no auto should have any oil loss issues, but we don't live in a perfect engineering world,,,imho
I'd still like to have my 67 Beetle back....life was easy then..imho 2 quarts of oil roughly ,lol
No matter what time it is,its always time for a nap
Re: What could cause a decrease in oil consumption? [Re: MCompact] #5382756 03/22/20 09:42 AM
B
BAJA_05 Offline
B
Why not throw some Kreen at that and see if it cleans things up for you moving forward?
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: What could cause a decrease in oil consumption? [Re: rubberchicken] #5382761 03/22/20 09:49 AM
M
MCompact Offline OP
M
I was coerced out of retirement so my goal is to keep the Clubman as my commuter car to the end of my term(December, 2024). I put approximately 6k miles per year on it so that means I just need to get it to 150k miles. I really like it and it makes the commute a bit more fun. If it was my only car and I had no option but FWD I'd get a Veloster N with the Performance Package.
Mine:
2014 M235i
2009 Cooper Clubman
Wife's:
Son's
2009 328i
Re: What could cause a decrease in oil consumption? [Re: MCompact] #5382771 03/22/20 09:55 AM
T
Triple_Se7en Offline
T
You did four top-offs using a total of a half-quart of oil? That's only four ounces average per top-off...... why?
Keep Your Pistons, Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Plat. 5W30 / AC Delco PF1127 Ecores
04 Chev Colorado Napa Syn 0w20 & K&N
