Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 04/01/20 02:41 PM
NEW Adam's Polishes - Hand Sanitizer
by SavagePatch - 04/01/20 02:40 PM
Home vehicle modification fails
by IMSA_Racing_Fan - 04/01/20 01:57 PM
Internet speeds in current climate.
by sloinker - 04/01/20 01:55 PM
concrete work while at home
by spasm3 - 04/01/20 01:19 PM
Oil change
by IvanPletex - 04/01/20 12:52 PM
New Battery --> Group 25 (stock), 24 or 34???
by gathermewool - 04/01/20 12:49 PM
Tell this geezer why I need gigabit Internet?
by csandste - 04/01/20 11:48 AM
KenoshaWizard, junipertoxic, mtnrider, Rickborn, TreyT42
71071 Registered Users
115 registered members (2002 Maxima SE, 53' Stude, 2K2AcuraTL, apollo18, AC1DD, 15 invisible), 1,895 guests, and 20 spiders.
Topics303,440
Posts5,235,348
Members71,071
Storing a car in FL #5382191 03/21/20 02:31 PM
L
loneryder Offline OP
L
I store my 20 yr old MB convertible during the summer months here in SW FL. Last year I stored it at an indoor storage facility. They said they would plug in my battery tender. It's a big metal barn with open doors on one end. They didn't use the battery tender and the car was so dead it could not be jumped. I also heard that the car was near the door and was filthy from the guy who cleans them up. Not paying $110 a month for that kind of service.
This summer a neighbor behind me is letting me park under his covered patio. I will run an extension cord over for the battery tender and cover the car and tie it down as best I can. It's hard to keep a cover on a car on the coast of FL.
Does anyone (in FL) have any suggestions as to what else I should do? Should I crack the windows under the cover? Put moisture control packs in car?
Re: Storing a car in FL [Re: loneryder] #5382249 03/21/20 03:45 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Id look into a rental garage or storage unit. Power or no power - worst case figure out what the $55 WM battery is that marginally fits it, and chalk it up to the cost of doing business.
Under a cover, marginally outdoors, youre asking for scratches. Under a covered patio should prevent some rain and sun, but if it stays damp under there after a rain, its not the best thing.
Honestly if its not able to be seen by someone once in a while Id want to avoid keeping it permanently plugged in.
You might look into a solar maintainer too...
Re: Storing a car in FL [Re: loneryder] #5382259 03/21/20 03:55 PM
R
RoadDukie Offline
R
I'd also pump up your tires to the max inflation pressure as noted on your sidewalls. Your de-humidifier block sounds like a good idea too. They can be picked up at Walmart in the RV section of the automotive department.
Good luck.
1998 Mercedes S500
2003 Corvette Roadster
2007 Chevrolet Avalanche
2009 Kawasaki Concours 14-ABS/2012 Kawasaki KLX250S
2002 Polaris Sportsman 500HO
Re: Storing a car in FL [Re: loneryder] #5382261 03/21/20 04:00 PM
E
eljefino Offline
E
What awful bugs or rodents can get into Flordian cars? I'd find a way to keep them out.
My w123 interior got wrecked by mouse pee.
Under a dank patio sounds awful, unless there's consistently good ventilation (natural wind.)
Re: Storing a car in FL [Re: loneryder] #5382281 03/21/20 04:31 PM
Nick1994 Offline
Store it in a 10x20 storage unit with a garage door. Disconnect battery (a disconnected battery isn't going to die very fast) and pump the tires up.
2015 Hyundai Genesis 5.0L 58k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 238k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Mobil 1 HM 10w40 & Fram Ultra
Re: Storing a car in FL [Re: eljefino] #5382283 03/21/20 04:32 PM
B
BHopkins Offline
B
Have you considered a car capsule? They do a pretty good job at protecting a car from insects, rodents, dust, water, pollen and such. Apparently they have versions that are made for outdoor use. With one of these, you can skip the car cover, and all the worries associated with them. And they have feedthrough slots where you can run a cord for the battery tender. You could pay for one with what you were putting out for storage.
https://carcapsule.com/outdoor-carcapsule/
In God we trust. All others bring data.
2013 Subaru Outback 2.5i - M1 HM 0W-20 & NAPA Gold filter
2014 Mercedes E350 M276 - M1 European 0W-40 & Purflux filter
Re: Storing a car in FL [Re: loneryder] #5382308 03/21/20 05:10 PM
M
MoultrieCreek Offline
M
My retired parents travel the hottest 4-5 months of the year to escape the FL summer. They leave their SUV in the garage and disconnect the battery - they've never had an issue when coming home, just reconnect and it's ready for the road. No tender necessary. They keep the gas tank full as well.
If it's being stored in open or carport conditions for any longer period of time I would worry more about the humidity. Crack your windows where I live for more than a couple days and the Cuban tree frogs will make a happy home (and a disgusting mess). I've seen some work trucks left closed up outdoors for a few months with no real issues, but I parked a project car behind the garage once and didnt touch it for a year... The interior turned into a giant petri dish.
Re: Storing a car in FL [Re: loneryder] #5382320 03/21/20 05:39 PM
G
GSCJR Offline
G
I just parked mine today; literally. Filled the tank with E0 and a splash of stabilizer. Vacuumed the interior, cleaned the glass, washed the exterior and installed two dessicants inside otherwise mould spores would appear on the seats. I also disconnected the battery. I would have liked to have filled the tires to the maximum but didn't get a chance. I have noticed that being near the ocean really has accelerated the corrosion levels under the hood in under six months.
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 157KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 180KM
Re: Storing a car in FL [Re: loneryder] #5382324 03/21/20 05:48 PM
R
redbone3 Offline
R
Several strategically placed mouse traps.
2014 Passat Wolfsburg, 1995 Miata.
Re: Storing a car in FL [Re: loneryder] #5382331 03/21/20 06:08 PM
R
RhondaHonda Offline
R
A bunch of desiccants in the cabin and one in the trunk and keep the windows closed. Disconnect the battery and maybe put a battery tender on it.
2019 Ford Raptor
2017 Corvette Grand Sport
2017 Yukon XL Denali
Re: Storing a car in FL [Re: loneryder] #5382819 03/22/20 10:28 AM
L
L
Thanks for all the suggestions. All good. It's really a covered driveway by the house and should be out of the sun but get plenty of air. I'm questioning whether to put a cover on it as wind during summer storms can get crazy.
Re: Storing a car in FL [Re: BHopkins] #5384002 03/23/20 07:11 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Now that is neat!
Re: Storing a car in FL [Re: BHopkins] #5384941 03/24/20 08:25 PM
E
eljefino Offline
E
Would it annoy the neighbor to have that fan blowing 24/7 like there's a kids' bounce house outside?
Re: Storing a car in FL [Re: loneryder] #5384944 03/24/20 08:29 PM
O
oilpsi2high Offline
O
Just take the battery out and store it in a cool, damp place. I wouldn’t stress over being able to use a tender. I would do everything in my power to keep the car out of the elements.
Re: Storing a car in FL [Re: loneryder] #5387159 03/27/20 03:58 PM
R
raaizin Offline
R
We rented this winter and are considering purchasing something for the winter months. While speaking to an owner there who said she left a car in the garage and the tires were destroyed from the heat even though it was in a garage. This didnt sound right to me could this be possible. I am thinking the tires just aged out....
