preferred way of adding a usb port
just get a switch
https://www.amazon.com/NETGEAR-Ethernet-Unmanaged-Internet-Splitter/dp/B00KFD0SYK/ref=sr_1_3?crid=9768BFDPQM65&dchild=1&keywords=8+port+switch&qid=1584811189&sprefix=8+port+sw%2Caps%2C219&sr=8-3
Im a bit confused. Youre putting a fire stick on the router?
Why wouldnt you connect your fire stick to your TV and connect to the router via wifi?
What am I missing?
Wait...
Your router has ethernet ports. The firestick uses HDMI. Where do the USB ports come in?
Originally Posted by Fitter30
Wifi router has all three ports used. Streaming tv using a fire stick and wanting to add another fire stick for another tv.
more info needed why are you even using a usb port or plugging into a router?
