With most folks cooped up at home
by double vanos - 04/04/20 12:58 AM
'18 GMC Canyon Denali 7k Havoline Pro DS 5w-30
by montero1 - 04/04/20 12:52 AM
KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
MC FL500S 7,000 miles CUT OPEN
by 53' Stude - 04/03/20 03:43 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
32 registered members (carlprop, blufeb95, bernau, avi1777, AZjeff, 6 invisible), 1,237 guests, and 19 spiders.
Topics303,557
Posts5,237,352
Members71,086
Garage door replacement a DIY project? #5382188 03/21/20 02:27 PM
J
jayjr1105 Offline OP
J
I have a small garage with a door that gets opened quiet frequently by kids for bikes, power wheels, etc. It's an old heavy wood door and it's rotting out and becoming dangerous. Is this a project I can do on my own being there is already an opener installed? Basically swapping out the door part?
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Garage door replacement a DIY project? [Re: jayjr1105] #5382196 03/21/20 02:34 PM
L
loneryder Offline
L
That rolled up spring at the top of the door is under very high tension, especially on a wooden door. I would be very leary of dealing with that.
Re: Garage door replacement a DIY project? [Re: jayjr1105] #5382200 03/21/20 02:41 PM
dishdude Online Content
Online Content
I did one a while back and it was very straightforward, Home Depot has them in stock. If you can put together a piece of Ikea furniture you can install this door. A cordless driver with 7/16" socket will help running the lag bolts for the track in and make things much easier on you. You'll also need a second person to help lift the panels in place and hold them as you assemble the track.
The trickiest part is getting rid of the old door, I cut mine up and threw it in the dumpster at work.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: Garage door replacement a DIY project? [Re: jayjr1105] #5382201 03/21/20 02:44 PM
skyactiv Offline
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Garage door replacement a DIY project? [Re: jayjr1105] #5382222 03/21/20 03:08 PM
Driz Offline
How bad and where. Post a pic or two. I’ve repaired mine a couple times ( I like all others HATE wooden doors.). I notched mine out and replaced the pieces with 2x 6 . I recessed and ran long screws in so it was solid. It’s primitive easy if you’ve ever done any car body work. I just used wood filler to finish the cracks , sanded with 80 grit and primed then painted it. the big add on was a FAR BETTER aluminum strip with deep hollow seal than it came with. That gets it way up out of the watery slop. It should have been that way since day 1 but the installers never mentioned it🤥.
Here’s the rub with me, I need the crap wood due to the slope of the floor behind sideways along the door. Plans change last minute🤬. Had I a choice I’d have switched to aluminum without a second thought. I had to go to wood to cut the 3” or do taper to follow the floor.
Here’s The deal on the springs. Mine worked fine for 18 years up there until one broke. I did not know you were supposed to keep those overhead torsion type springs oiled. I expect Few folks know either. They have a duty cycle of around 10,000 up and downs before they start to get worn out supposedly. Oiling them helps so Oil the top of the coils. . When you buy the springs you got to get the right one for the door weight . I don’t know what the variances is in the adjustment capability really is between the two types and if backing off enough tension will take care of it if you switch. Someone else probably will. In order to adjust those critters you have to use a hardened steel rod and make sure you hang on real tight so it doesn’t fly off and tear you to pieces. They sell rods as well as the springs on Amazon and eBay whatever. I checked on the price to have mine done when my spring broke and it was only $25 more than if I bought everything myself so Why bother.
Post a pick or two off what you’ve got
Re: Garage door replacement a DIY project? [Re: jayjr1105] #5382237 03/21/20 03:29 PM
M
MasterSolenoid Offline
M
I had mine (door and tracks) installed by professionals.
Took them two hours and everything lined up.
Letting them deal with the Torsion Spring tension was money well spent.
Before attempting yourself, think of your children.
Most garage door springs have a 10,000 duty cycles.
I spent a little more money and bought 40,000 duty cycles.
There longer, bigger diameter, and heavier wire gauge.
[Linked Image]
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Garage door replacement a DIY project? [Re: jayjr1105] #5382245 03/21/20 03:41 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
My grandfather and I did multiple when I was growing up. They all had extension springs, so that part was easy to deal with. All were single-wide...
Re: Garage door replacement a DIY project? [Re: jayjr1105] #5382252 03/21/20 03:46 PM
N
NO2 Offline
N
We had a non-insulated one installed for under $1K, including a wifi opener, steel door with windows, and old door haul away. Install was around $200 of the total. Hardly worth it for DIY.
Re: Garage door replacement a DIY project? [Re: jayjr1105] #5382275 03/21/20 04:21 PM
B
Brybo86 Offline
B
I paid someone to replace the springs on my double wood door . Charged me $500 .
I realized later I got screwed. He never measured or weighed the door. He put springs that were much too small and had to be wound too tight. The door is too heavy when down and at about halfway up the spring become too strong and jump up against the opener.
Fought with credit card company for 2 months finally got the money back.
I have since purchased new heavy duty springs of the correct length and gauge myself.
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Re: Garage door replacement a DIY project? [Re: loneryder] #5382282 03/21/20 04:31 PM
L
Leo99 Offline
L
This is the most important thing. If you have a torsion, let the pros do it. If you have extension, you can do it yourself. The springs come in different color coded "strengths". Get ones that balances your new door which will be most likely lighter than the old one.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: Garage door replacement a DIY project? [Re: jayjr1105] #5382304 03/21/20 05:05 PM
DallasTexas Offline
I installed a SOMMER garage door opener (not the spring tensioner or such).
By the way EZ snap-in assembly mostly, and German made, lifetime warranty, the quietest opener I have ever experienced.
06 E320 CDI 118k miles
14 Sienna 38k miles
96 E300 297k miles Donated
90 Volvo 240 donated.
2001Sienna donated
Re: Garage door replacement a DIY project? [Re: jayjr1105] #5382366 03/21/20 07:25 PM
B
buck91 Offline
B
Yes, the springs contain a large potential energy but with caution I found them to be rather easily replaced when mine broke. I cannot comment on replacing the door itself but it doesn't look overly complicated- maybe just awkward.
I used springs from DDM Garage Doors Inc when I did mine and they had some great info.
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Garage door replacement a DIY project? [Re: loneryder] #5382374 03/21/20 07:41 PM
E
ecotourist Offline
E
When I was a young doctor I saw 2 guys within a few days in the emergency department with broken forearm bones from trying to fix the springs in garage doors. I wouldn't touch them.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: Garage door replacement a DIY project? [Re: jayjr1105] #5382387 03/21/20 08:09 PM
B
bobbobtar Offline
B
I had extension springs on a wooden garage door, one day while closing the door I heard a loud bang and the door stopped moving, one of the springs had broken and went thru the back window of the garage, finally found it 50 feet out in the woods.
2020 Chevy Silverado LT 1500 3.0L diesel
2018 John Deere 2032R
2019 F3 CanAm Spyder
1981 Chevy Malibu 355cu 425hp
Re: Garage door replacement a DIY project? [Re: bobbobtar] #5382419 03/21/20 08:50 PM
E
Elkins45 Offline
E
My dad had a big mess in his garage when one of those extension springs broke and apparently ricocheted all over the place knocking things over and breaking stuff. Fortunately it was unoccupied when it happened.
I would hate to have been in there when that thing let go. He ran steel cable thru all of them so when the next one broke the cable caught it and held it captive.
