RV's for MD's
by 02SE - 04/07/20 01:42 AM
Crawfish, It's A Louisiana Thang!
by BlueOvalFitter - 04/07/20 01:01 AM
M&P .40 Magazines $12.99
by BlueOvalFitter - 04/06/20 11:30 PM
Lots of Big Sur pics, only one of the car :-)
by SLO_Town - 04/06/20 09:24 PM
'16 Pilot Inline ATF filter
by parshisa - 04/06/20 08:55 PM
2019 Ram 1500 Classic
by Skippy722 - 04/06/20 08:53 PM
STP S3614 XL CUT OPEN
by 53' Stude - 04/06/20 07:15 PM
Kia Rio awful sound after sitting 5 years
by antonmnster - 04/06/20 07:13 PM
Cut open Motorcraft FL820S
by PantherFan88 - 04/06/20 06:38 PM
240V Electric Hookup Questions
by 92saturnsl2 - 04/06/20 06:33 PM
license plate frame with 3rd brake light
by wings&wheels - 04/06/20 06:12 PM
Wurth HHS 2000
by ejt - 04/06/20 06:06 PM
Snapper drive belt install trouble LT300
by spk2000 - 04/06/20 05:56 PM
installing garage LED shop light help needed
by FirstNissan - 04/06/20 05:20 PM
Casite filters
by opus - 04/06/20 05:16 PM
Oil for Jeep
by rokwldr - 04/06/20 05:12 PM
Kitchen sink faucet leak help
by 97prizm - 04/06/20 04:45 PM
RIP Al Kaline.
by PimTac - 04/06/20 04:36 PM
Frankentruck power steering question
by Thomcat316 - 04/06/20 04:11 PM
Comment from Miata track on Amsoil GL-4
by Bill_W - 04/06/20 03:28 PM
BludRacing, Cacciatore, Thomcat316, NTexian, LateLifeCrisis
71116 Registered Users
26 registered members (AC1DD, blufeb95, Bailes1992, dave63, BlueOvalFitter, 1 invisible), 1,260 guests, and 17 spiders.
Topics303,699
Posts5,240,218
Members71,116
Use Delvac syn. blend in 2017 Cruze? #5381988 03/21/20 10:23 AM
E
Electromotive Offline OP
E
Bought some Mobil Delvac 10w 30 syn. blend HDEO on clearance a while back. It is rated CK 4 but has no API ratings or Dexos rating on container for gasoline engines. The conventional Delvac HDEO has API ratings (but not Dexos rating) on container for gasoline engines.
Would it be ok to use in a 2017 Cruze with 1.4 L turbo engine in the southeast (GA/SC) year round? The car is out of warranty and has about 60,000 miles, and is mostly used for city driving.
Re: Use Delvac syn. blend in 2017 Cruze? [Re: Electromotive] #5382008 03/21/20 10:44 AM
J
Jackson_Slugger Offline
J
I honestly wouldn't use an oil that doesn't have API in a gasser...
Re: Use Delvac syn. blend in 2017 Cruze? [Re: Electromotive] #5382012 03/21/20 10:46 AM
4WD Offline
Out of spec too when I use M1 0w40 and it’s running great at 128k on the clock
This it ?
Re: Use Delvac syn. blend in 2017 Cruze? [Re: Electromotive] #5382021 03/21/20 10:57 AM
c502cid Offline
I'd use that oil all day long in my Trax with the same motor.
15 Chev Trax AWD
02 GMC 3500 8.1/Ally DRW 4x4
00 Blazer 4.3 4x4
97/98 Civics
84 Chev K30 454EFI/T400/NP205 DRW 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
08 Kawi Brute Force 750
Re: Use Delvac syn. blend in 2017 Cruze? [Re: 4WD] #5382025 03/21/20 11:01 AM
E
E
Yes that is it, but on the label it doesn't have the SM rating as the specs you provided show. It has CK-4, CJ-4, CI-4 ratings , but no API rating of any type for gasoline engines.
Looks like the production date code on container (not really sure) may indicate it was bottled sometime in 2017.
Thank you for the info.
Re: Use Delvac syn. blend in 2017 Cruze? [Re: 4WD] #5382027 03/21/20 11:01 AM
J
J
This it ?
Um, that's for gas engines, it's not "out of spec"...
Re: Use Delvac syn. blend in 2017 Cruze? [Re: Electromotive] #5382030 03/21/20 11:05 AM
J
J
What troubles me is it's not on the website either. I'd use it in power equipment like a mower....
Re: Use Delvac syn. blend in 2017 Cruze? [Re: Jackson_Slugger] #5382045 03/21/20 11:26 AM
CT8 Offline
Why is that?
2015 F150 2.7
2018 F350 6.2
Re: Use Delvac syn. blend in 2017 Cruze? [Re: CT8] #5382058 03/21/20 11:34 AM
J
J
Why is that?
Because obviously it's not formulated or intended for it, most HDEO's do have SL-SN ratings. Maybe an older beater be fine, but not a 2017 Is anyone that cheap that they'd even risk anything issues?...
This Mobil Delvac SE 10W-30 DOES have SN listed: https://www.mobil.com/en/lubricants...bricants/products/mobil-delvac-super-fe/
Mobil's full syn 10W-30 HDEO is rated SM/SL.
Maybe there's a reason the OP's "Extreme" version does not?
Re: Use Delvac syn. blend in 2017 Cruze? [Re: Electromotive] #5382075 03/21/20 11:57 AM
J
J
Your best bet is to email Mobil and ask them if this particular version of their 10W-30 can be used in a gas engine, and why both their other 10W HDEO's have API gas ratings...
Re: Use Delvac syn. blend in 2017 Cruze? [Re: Jackson_Slugger] #5382131 03/21/20 01:08 PM
4WD Offline
Yeah it is
No need to phone or email Mobil
Re: Use Delvac syn. blend in 2017 Cruze? [Re: Electromotive] #5382141 03/21/20 01:30 PM
4WD Offline
And it’s not in the ILSAC world … too thick … has 3.6 HTHS …
Unlike mine, 2017 should be Direct Injection in addition to the turbo (mine just turbo) … so SN plus is better for LSPI and that kind of stuff.
Re: Use Delvac syn. blend in 2017 Cruze? [Re: Electromotive] #5382173 03/21/20 02:01 PM
B
blufeb95 Online Content
Online Content
B
If you're set on a 10w30, I'd use one from a line of oils that includes a Dexos rated 5w30.
Re: Use Delvac syn. blend in 2017 Cruze? [Re: Electromotive] #5382274 03/21/20 04:21 PM
M
mattwithcats Offline
M
I would use what Chevrolet recommends, a Dexos motor oil.
You need a specific viscosity, and additives or you will kill the turbo and pre-cat...
I suggest Mobil 1 Advanced Fuel Economy, in 0W-30...
https://www.mobil.com/en/lubricants/for-personal-vehicles/our-products/products/mobil-1-0w-30/
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Use Delvac syn. blend in 2017 Cruze? [Re: 4WD] #5382289 03/21/20 04:45 PM
J
J
Yeah it is
Which one? LINK? There's THREE 10W-30 Delvac oils and one clearly does not state any API gas engine ratings...
