VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 04/01/20 02:41 PM
NEW Adam's Polishes - Hand Sanitizer
by SavagePatch - 04/01/20 02:40 PM
Home vehicle modification fails
by IMSA_Racing_Fan - 04/01/20 01:57 PM
Internet speeds in current climate.
by sloinker - 04/01/20 01:55 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
125 registered members (5AcresAndAFool, 53' Stude, 2004tdigls, Alfred_B, Al, 2010Civic, 14 invisible), 1,890 guests, and 24 spiders.
Topics303,447
Posts5,235,438
Members71,072
Brightest 893 fog/driving light bulb? #5381568 03/20/20 07:12 PM
dwcopple Offline OP
I need some new bulbs in my fogs on my 98 Mustang GT. I need bright!!! Any ideas?
2017 RAM Big Horn 4x4 3.6L V6
2011 Chrysler 200 Limited 3.6L V6
Re: Brightest 893 fog/driving light bulb? [Re: dwcopple] #5381590 03/20/20 07:40 PM
bdcardinal Offline
Not to derail, but how are the lamp housings? Those fogged up/became cloudy a lot.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Brightest 893 fog/driving light bulb? [Re: dwcopple] #5381643 03/20/20 08:28 PM
U
UG_Passat Offline
U
Your stock Sylvania 893 ones are the best to use.
Unless you can get an aftermarket foglight assembly in that spot that uses a brighter bulb than the 893
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Brightest 893 fog/driving light bulb? [Re: UG_Passat] #5381856 03/21/20 07:54 AM
dwcopple Offline OP
Hmmmmmmm shrug
Re: Brightest 893 fog/driving light bulb? [Re: dwcopple] #5381981 03/21/20 10:15 AM
Delta Offline
Not sure what you're going for but for the fogs in my Tacoma I used some Sylvania Fog Vision bulbs. The yellow tint definitely helps out during inclimate conditions. They are also brighter than the regular Sylvania's that were in there.
'17 VW GTI 2.0T - 6MT - 20K - Edge 0w40
'15 Camry SE - 2.5 - 26K - PP 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 139K - RGT 5w30
Re: Brightest 893 fog/driving light bulb? [Re: dwcopple] #5382019 03/21/20 10:56 AM
O
Olas Offline
O
the outright brightest bulb you can get is an HID upgrade kit with ballast resistors and 893 based upgrade bulbs.
if you also care about light scatter and beam-aim, then you might not want the brightest bulb.
https://www.hidnation.com/collections/893-hid-kits/products/893-hid-conversion-kits
Cable ties should hold it
Re: Brightest 893 fog/driving light bulb? [Re: dwcopple] #5382340 03/21/20 06:28 PM
Dave_Mark Online Content
Online Content
Fog lamps are not driving lamps. Driving lamp = high beam.
893 bulbs are rated for about 900 lumens and draw about 38 watts.
There's really not much you can do short of adding auxiliary fog lamps. Remember, your fog lamps can only handle about 40 watts. Past that you might start melting wiring and burning the inside of the lamp.
Re: Brightest 893 fog/driving light bulb? [Re: dwcopple] #5382389 03/21/20 08:14 PM
dwcopple Offline OP
Ok thanks ^^^
Re: Brightest 893 fog/driving light bulb? [Re: Dave_Mark] #5385950 03/26/20 07:29 AM
R
rat Offline
R
Driving lights are not high beams...
2015 Focus SE hatch 5 speed manual
2003 Expedition 5.4
2018 Grand Caravan
2000 Honda CRV
2000 Buick Century
Re: Brightest 893 fog/driving light bulb? [Re: rat] #5385980 03/26/20 08:17 AM
Online Content
Correct, they're aux high beams.
