This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Refrigerator runs in cooling mode for 2+ hours.
by mrsilv04 - 03/30/20 09:24 AM
Non Detergent Oil
by 10ecfarmer - 03/30/20 08:06 AM
Joe Diffie on vinyl
by skyactiv - 03/30/20 07:52 AM
cooling system vacuum refill kit
by Donald - 03/30/20 07:35 AM
What's the proper oil for a push mower
by jayjr1105 - 03/30/20 07:31 AM
Honda DW-1 OLD Bottles Question.
by David1 - 03/30/20 06:25 AM
Winter 'shoes' for office goers
by MoneyJohn - 03/30/20 05:54 AM
2004 FZ6 Delo 400
by thestockie1 - 03/30/20 04:34 AM
Turn signals all blinking fast
by JHZR2 - 03/30/20 12:14 AM
rider9195, kingsville911, B34R, ChrisSnowden, DIY4quality
71055 Registered Users
109 registered members (53' Stude, Audios, 007, 2015_PSD, 440Magnum, 25ring, 15 invisible), 2,062 guests, and 17 spiders.
Topics303,358
Posts5,234,722
Members71,055
Page 1 of 3 1 2 3
Good Write up On 5.7 Hemi Issues #5381474 03/20/20 05:32 PM
domer10 Offline OP
It seems that MDS is not so much the issue as manufacturer defect that they knew about, excerpting to much forces on parts, and lubrication issues were key, and using heavier weights only made it worse.
Dr. Andy Randolph, technical director at ECR Engines—a NASCAR engine developer based out of Welcome, North Carolina whose lab does lots of failure analyses—gave me his thoughts, too, positing that perhaps there was an issue with oil viscosity. The result would yield the excessive lash that the above R&D engineer told me about:
First, these lifters control lash hydraulically and are designed for 5W20 oil. If the owner uses a heavier oil (for instance a 10W30), this could impede the hydraulic action of the lifters and increase lash between the roller and cam lobe under some operating conditions. This increase in lash will generate impact loading when the lifter contacts the lobe and lead to premature failure of the needle bearings along with the ticking noise that some of the owners report.
Second, the needle bearings are fed oil continuously through the body of the lifter. Once again, if the owner uses a heavier oil then flow to the bearing will be reduced and failure could happen prematurely.
Though not familiar with the Hemi’s MDS, Randolph says he doesn’t think the cylinder deactivation system is playing a role based on what he’s seeing here. In addition, both he and the R&D engineer don’t think this failure should lead to bent pushrods, though Randolph did add that it could happen if “the lash increases sufficiently for the pushrod to be displaced from the cup in either the lifter or the rocker arm. Once displaced, the pushrod could easily become overloaded and bend.” That’s what I think happened, but that’s just a guess..
In any case, it’s pretty clear that a fault in the lifter’s ability to control lash—possibly caused by debris or improper oil viscosity—could theoretically be the cause of these failures.
https://jalopnik.com/chrysler-built-hemi-engines-with-a-major-engineering-de-1842400890
2013Jeep Wrangler Sahara Unlimited
2001 Toyota 4Runner
20010 Harley Davidson Rocker
Re: Good Write up On 5.7 Hemi Issues [Re: domer10] #5381491 03/20/20 05:50 PM
Sunnyinhollister Offline
I thought the 6.4L Hemi uses the same lifters as the 5.7L, however the 6.4L specs a 0W-40 viscosity and the 5.7L calls for a 5W-20.
2017 Ram 1500 Regular Cab 4x2 5.7L 8spd
2017 Chevy Bolt
2018 Jeep Cherokee Trailhawk
2004 Toyota Highlander AWD - RIP
2001 Ranger XL 4x4
Re: Good Write up On 5.7 Hemi Issues [Re: Sunnyinhollister] #5381499 03/20/20 06:03 PM
domer10 Offline OP
Not sure, not up to snuff on 6.4 to tell you truth, does 6.4 have MDS as well?
2001 Toyota 4Runner
Re: Good Write up On 5.7 Hemi Issues [Re: Sunnyinhollister] #5381503 03/20/20 06:07 PM
Skippy722 Offline
They do. The “5w20 or else!” thing is complete nonsense.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Good Write up On 5.7 Hemi Issues [Re: Skippy722] #5381509 03/20/20 06:14 PM
domer10 Offline OP
Not sure where he said 5 20 or else, as he said this is his theory.....which makes complete sense, he states 10 30 and probably means above that.
But what what a NASCAR engine developer know.
2001 Toyota 4Runner
Re: Good Write up On 5.7 Hemi Issues [Re: Skippy722] #5381516 03/20/20 06:24 PM
domer10 Offline OP
And get a bag, or something that holds liquid, now cut a hole...now put thin liquid and push it through...then do same with thicker fluid, let me know the pressures required to get the thicker fluid through that hole. Like it’s common sense and people want to create a argument. I will take his word over someone random on a forum who thinks it’s not true because he doesn’t believe it.
2001 Toyota 4Runner
Re: Good Write up On 5.7 Hemi Issues [Re: domer10] #5381518 03/20/20 06:26 PM
CT8 Offline
Good Write up On 5.7 Hemi Issues What exactly is good about it?
2015 F150 2.7
2018 F350 6.2
Re: Good Write up On 5.7 Hemi Issues [Re: domer10] #5381519 03/20/20 06:27 PM
V
vw7674 Online Content
Online Content
V
Seems as though the rollers in the lifters failed because of the high spring pressure & the under size required to fit the lifter bore.
Bad engineering?. Poor metallurgy?
Re: Good Write up On 5.7 Hemi Issues [Re: domer10] #5381530 03/20/20 06:33 PM
F
fdcg27 Offline
F
Okay, so what's supposed to happen when someone goes out and starts his pickup on a cold morning?
The 5W-20 is then thicker than a 10W-30 would be on a warmer morning.
This is the reason that I don't think this theory has any validity.
Viscosity is always and everywhere a function of temperature and it doesn't take any great reduction in starting temperature for a 5W to be thicker than a 10W.
Next up theory?
18 Accord Hybrid 20K HGMO 0W-20
17 Forester 36K VME 0W-20
12 Accord LX 115K SSO 0W-20
09 Forester 119K M1HM 5W-30
96 Accord LX 104K T5 10W-30
95 318i
Re: Good Write up On 5.7 Hemi Issues [Re: domer10] #5381532 03/20/20 06:37 PM
Same lifter, same basic engine other than displacement, different recommended viscosity. If a higher viscosity causes failures, than surely there would be more dead 6.4L on the side of the road.
2017 Chevy Bolt
2001 Ranger XL 4x4
Re: Good Write up On 5.7 Hemi Issues [Re: domer10] #5381537 03/20/20 06:43 PM
O
OVERKILL Online Content
Online Content
O
He already said he's not familiar with the design. We got into the design in a previous thread, IN DETAIL on here.
Cliff-notes:
- The SRT engines use the same MDS components and spec 0w-40. Their lifter failure rate appears to be lower.
- Oil viscosity is heavily temperature dependant. If the system was indeed this viscosity sensitive, they would fail far more frequently in northern climates, which is clearly not the case.
- When the lifter rollers seize up, this often goes unnoticed and can result in a dramatic amount of wear of both the cam lobe and the lifter, making the lifter shorter. This would allow the pushrod to dislodge and once the lifter is no longer locked in the retainer keeping it straight, it bouncing around could certainly result in a scenario where the pushrod gets bent.
The FCA MDS and the GM's AFM are essentially the same system and both experience the same lifter failure. The difference is that GM uses a billet camshaft core, whilst FCA opted for SADI, so on the FCA engines the cam always needs to be replaced, where this is not the case with the GM engines.
Lifter failure is also not isolated to the MDS lifters. In many cases, the lifter(s) that fail are the regular ones. On top of that, engines without MDS have also experienced the problem. I provided links to examples of this in the previous thread. At this point, both GM and FCA have gone through several part revisions and the issue is believed to have been fixed, though we'll see how that pans out.
Keep in mind, the vast majority of HEMI engines (and GM AFM ones) never experience the issue.
Re: Good Write up On 5.7 Hemi Issues [Re: CT8] #5381541 03/20/20 06:46 PM
domer10 Offline OP
Gets in depth to heart of issues, of course not good enough for you....but enlightened me as to much more going on than MDS.
Why exactly did it not cut the mustard for you?
2001 Toyota 4Runner
Re: Good Write up On 5.7 Hemi Issues [Re: OVERKILL] #5381546 03/20/20 06:54 PM
domer10 Offline OP
Cliff-notes:
Ok but this isn’t about the 6.4, it’s about the 5.7, and 0 40 can be thinner than a thicker 10 30. And there is a mast majority of 5.7 that experience the symptoms before it leads to catastrophic failure. I had a 2012 and within 45k the tick was getting bad, and I had always wondered about it and would read in here of same gen Hemi having failures.
Like I said I have no idea about the 6.4 and it seems from 14 on they started getting a handle on it somewhat.
2001 Toyota 4Runner
Re: Good Write up On 5.7 Hemi Issues [Re: OVERKILL] #5381548 03/20/20 06:57 PM
domer10 Offline OP
Cliff-notes:
And thanks for the info on the 6.4.
2001 Toyota 4Runner
Re: Good Write up On 5.7 Hemi Issues [Re: domer10] #5381554 03/20/20 06:59 PM
O
Online Content
O
[Ok but this isn’t about the 6.4, it’s about the 5.7,
But they use the exact same MDS parts.
[and 0 40 can be thinner than a thicker 10 30.
At lower temperatures. At above 0, the 0w-40 is thicker. Most PCMO 10w-30 are a fair bit thinner than a >3.5 HTHS 0w-40.
[And there is a mast majority of 5.7 that experience the symptoms before it leads to catastrophic failure.
And most owners don't act on them, which is why the damage tends to get so extensive.
[I had a 2012 and within 45k the tick was getting bad, and I had always wondered about it and would read in here of same gen Hemi having failures.
Yes, they updated the lifters sometime ~2014, which is when most think it got fixed.
Page 1 of 3 1 2 3
