Local dealership charges $15 for an oil change.....
by Harrington - 04/04/20 02:57 PM
Did harvest king change suppliers?
by Micahmcmeen - 04/04/20 02:30 PM
Switching back from High mileage to regular.
by Micahmcmeen - 04/04/20 02:28 PM
Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Penne alla Boscaiola
by vavavroom - 04/04/20 10:05 AM
Fuel stabilizers for e10 gas - long storage
by caprice_2nv - 04/04/20 09:59 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
103 registered members (762fermeandyou, 01rangerxl, 4WD, 41Pack, 2015_PSD, 11 invisible), 2,947 guests, and 19 spiders.
Topics303,589
Posts5,237,871
Members71,094
2007 Tacoma - Which U-Joints? OEM? Spicer? Moog? #5381456 03/20/20 05:16 PM
J
john_pifer Offline OP
J
2007 Tacoma PreRunner V6, TRD Off-Road, 228K.
I have a "clunk" upon accelerating from a dead stop or from low speed (<15 mph), or, when coming to a stop. From my research, it's the driveshaft center carrier bearing. It has a rubber isolator, which wears out over time.
OEM part is $190 shipped, cheapest I could find, which isn't too prohibitive.
I did replace all 3 U-Joints back in 2012, because one of them started squeaking when driving in reverse only. Went with the Auto Zone Duralast Gold (non-greasable). Haven't had any issues with them.
I figure, while I have the driveshaft out, I'll go ahead and replace the U-Joints also, since the truck had <100K when I last replaced them.
I called Auto Zone about the U-Joints. They have a few options. ValuCraft (not even a consideration) for $12, Duralast (this one is greasable - I don't think they even offer the Duralast Gold non-greasable any more) for $18, Moog greasable for $26, a Spicer for $24, and another Spicer for $47.
Cheapest OEM I could find are $58 plus shipping. So, my question is, are these $47 Spicer units OEM-equivalent? How are the Moog? Anyone used any of these?
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 225K
18 Civic HB 1.5T 6MT (Fiancee's) - VME 0W-20, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: 2007 Tacoma - Which U-Joints? OEM? Spicer? Moog? [Re: john_pifer] #5381487 03/20/20 05:48 PM
Delta Offline
I've done a little digging into this as well and it seems Spicer is the way to go. They are the OEM manufacturer in these trucks, make sure to get the greaseable versions. Spicer also made the carrier bearing. Drivetrain America has decent prices on the u-joints and carrier. $70 ish for the carrier from them. Chain parts store products do not last long in these trucks. There are subtle differences between the TRD 4wd and TRD PreRunner, so due diligence is needed for part numbers. I thought I had them handy, but can't locate them. Also make sure to lube the slip joint while apart. Funny as it sounds, alot of Tacoma owners use the Ford Motorcraft product for this.
On my 09 TRD 4wd my u-joints and carrier are getting worn out, but since my truck has a 2" level lift (and soon swapping in a 3rd gen TRD suspension that adds another 1") I've been looking into a solid one-piece driveshaft that several vendors have. Might be something to look into as it seems you possibly have the height to do it. Most prices range in the $500-700 range and while pricey you won't have as many issues down the road.
EDIT: Forgot to mention your "clunk" might just be the slip joint. A worn carrier bearing will usually just cause a vibration.
'17 VW GTI 2.0T - 6MT - 21K - Edge 0w40
'15 Camry SE - 2.5 - 26K - PP 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 140K - RGT 5w30
Re: 2007 Tacoma - Which U-Joints? OEM? Spicer? Moog? [Re: john_pifer] #5381489 03/20/20 05:49 PM
danez_yoda Offline
I bought the Moog ones with the grease fitting on the end caps. Complete PITA with the small tip fitting in them. Its OK but another piece you need to buy and master (its different from a zerk, no retention feature)
If I were to do it again, I would get the Spicer non grease ones. My orignial ones were fine except for one that went dry then waddled itself out. The OEM ones I pulled out had Spicer stamped on them.
Re: 2007 Tacoma - Which U-Joints? OEM? Spicer? Moog? [Re: john_pifer] #5381714 03/20/20 10:59 PM
P
PowerSurge Offline
P
On that application, Spicer.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: 2007 Tacoma - Which U-Joints? OEM? Spicer? Moog? [Re: john_pifer] #5381739 03/21/20 12:18 AM
B
BlakeB Offline
B
Rockauto
The “Dana” u-joints On Rockauto look to be Spicer. They say spicer and show it in the pictures if you blow it up. I’d go with those if it was me. On the center support/carrier bearing I would go OEM, the aftermarket units don’t hold up well from what I’ve heard.
5% Discount Code: 1733F4F2C75884
Expires: May 12, 2020
[Linked Image]
How to use the discount code on RockAuto:
[Linked Image]
Re: 2007 Tacoma - Which U-Joints? OEM? Spicer? Moog? [Re: john_pifer] #5381745 03/21/20 12:29 AM
J
J
Wow, thanks!
What’s interesting is that the Dana (Spicer) u-joint in the photo you showed (the bottom one for $21.89) has the same part no. as the Spicer unit that Auto Zone lists for $47.99:
Re: 2007 Tacoma - Which U-Joints? OEM? Spicer? Moog? [Re: Delta] #5381752 03/21/20 12:58 AM
J
J
Hey, thanks man. From doing some research, it seems like the Spicer model 5002334 is probably the OEM unit. Looks like it's the same P/N for 1995-2012 Tacoma 4WD or PreRunner, as well as a few other Tundras and even T100s.
Hard to believe it can be bought for $63 from Summit Racing when the cheapest I've found OEM from a Toyota online parts "wholesale" dealer is $190 shipped.
Yeah, I don't have any vibration at cruise speed. And I do 90 on the freeway in this truck frequently. I can detect some vibes when I accelerate hard from a dead-stop or standing-start, but assumed it's the torque converter. Maybe not.
Maybe I'll just go on and replace carrier bearing and u-joints. And see if that fixes everything. At least that would tell me for sure if the vibes on acceleration that I mentioned are actually the torque converter.
Re: 2007 Tacoma - Which U-Joints? OEM? Spicer? Moog? [Re: john_pifer] #5381806 03/21/20 06:31 AM
danez_yoda Offline
Make sure you mark the drive shaft with paint before you dissassemble it so the splined pieces will go back together the same orientation they are now. the drive shaft is balanced so if you dissassemble it then put it back a different way the balance will be off and cause vibration.
Re: 2007 Tacoma - Which U-Joints? OEM? Spicer? Moog? [Re: danez_yoda] #5381841 03/21/20 07:41 AM
G
Gebo Offline
G
+1
I tried to self diagnose a drive train issue and it cost me over $1000. I should have had it properly diagnosed instead of throwing parts at it. I'd have a hard time using non-OEM parts. But that's just me.
OH, for the second time, please mark your driveshaft because no one can rebalance one. At least in SE USA. Ask me how I know. LOL
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: 2007 Tacoma - Which U-Joints? OEM? Spicer? Moog? [Re: john_pifer] #5381870 03/21/20 08:10 AM
M
mk378 Offline
M
Truck goes "clunk." Owner comes here to talk about buying about $300 of parts before even looking underneath.
Re: 2007 Tacoma - Which U-Joints? OEM? Spicer? Moog? [Re: john_pifer] #5381925 03/21/20 09:10 AM
Delta Offline
The torque converter doesn't try locking up until 33-35mph-ish, under certain conditions it'll shutter/vibrate when it goes into lockup. I typically keep my truck in 4 under 45mph so it won't lockup. Vibration under hard accel points to the carrier is most cases. Get up under the truck and see how much play it has up and down. Being 2wd definitely simplifies things on 2nd gens tracking down vibrations.
Re: 2007 Tacoma - Which U-Joints? OEM? Spicer? Moog? [Re: danez_yoda] #5382170 03/21/20 02:00 PM
J
J
I've disassembled it before when I replaced U-Joints the first time.
Re: 2007 Tacoma - Which U-Joints? OEM? Spicer? Moog? [Re: mk378] #5382205 03/21/20 02:47 PM
J
J
Thanks for your input, but I already know what it is, as I said. It's the driveshaft center carrier bearing. It's a known failure point on these trucks. As I said, the rubber isolator surrounding the bearing rots out, allowing play, and, the "clunk". I've been under the truck and the rubber is deteriorated. The driveshaft has play.
The driveshaft has to come out for me to replace the center carrier bearing, and the driveshaft has to be separated into its 2 pieces to replace the center carrier bearing, so, with it already out, and taken apart, it makes sense to go on and replace the 3 U-Joints, so I'm not having to pull it again. One of the factory u-joints failed at 101,000 miles. These Duralast Gold u-joints that I put in, at 101,000 miles, now have 127,000 miles. Far more than what the OEM had when one of them failed, prompting me to replace all 3 at that time.
Re: 2007 Tacoma - Which U-Joints? OEM? Spicer? Moog? [Re: john_pifer] #5382271 03/21/20 04:17 PM
J
J
Total cost is $150 shipped for 3ea Spicer Life Series u-joints (5-1330-1X) and the Spicer carrier bearing (5002334 - I believe this to be the actual, OEM unit, even though I’ve found it for 1/3 of the cost from a Toyota dealer).
Just to throw it out there, the driveshaft itself is also Spicer. And I suspect that the original u-joints were Spicer, as well.
Ordered from Summit Racing. I have to say, also, that the gentleman I spoke with was extremely friendly and helpful. Especially under the current circumstances. He said order fulfillment shouldn’t be affected by that of which we don’t speak, and that he’s not aware of significant shipping delays at this time. I should have the parts next week.
Re: 2007 Tacoma - Which U-Joints? OEM? Spicer? Moog? [Re: john_pifer] #5382613 03/22/20 06:01 AM
L
Lubener Offline
L
I always use Spicer or Neapco u joints. Carrier bearing, I "try " to go with OEM when possible.
The "thinking" man's friend.
