Broken sway bar bolt
by HoosierJeeper - 03/29/20 04:00 PM
can I use it?
by avi1777 - 03/29/20 03:54 PM
Service Champ OF2222 75% OLM, unknown miles
by bullwinkle - 03/29/20 03:50 PM
Gas Buddy Question
by Wolfshead - 03/29/20 03:30 PM
Caliper piston boot
by painfx - 03/29/20 03:25 PM
Graphene the next detailing protection
by Mamala Bay - 03/29/20 02:17 PM
Anyone here a blacksmith?
by 53' Stude - 03/29/20 02:13 PM
Buying products made outside the USA
by 007 - 03/29/20 01:22 PM
Marine oils on sale at Canadian Tire
by Snagglefoot - 03/29/20 12:42 PM
0W16 instead of 0w20?
by Mter00s - 03/29/20 12:36 PM
XG10575 Walmart.com deal
by 762fermeandyou - 03/29/20 12:29 PM
Virgin ACDelco PF1245 cut and post
by nwjones18 - 03/29/20 11:49 AM
Oups, forgot oil cap...
by M119 - 03/29/20 11:46 AM
Recommendation for tuned BMW N55?
by RIPGermanCastrol - 03/29/20 11:15 AM
Electrician's Help With Circuit Breaker ?
by doitmyself - 03/29/20 11:07 AM
Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
92 registered members (2K2AcuraTL, 01rangerxl, 007, 53' Stude, 2015_PSD, 11 invisible), 2,128 guests, and 19 spiders.
Topics303,322
Posts5,233,901
Members71,038
What oil(EUROPE) #5381371 03/20/20 03:37 PM
I
IvanPletex Offline OP
I
Hi, I am from Croatia, iam searching for quality synthetic oil for my diesel car.
Grade of the oil I am searching for is 5w40, spec-ACEA A3/B4, API SN/CF.
So far I have been using Selenia WR 5w40.
Now I am searching for something diffrent, lets say better oil.
I was looking at Shell helix ultra 5w40, Total quartz 9000 energy 5w40, Motul 8100 x-clean 5w40, 5W40 Valvoline Synpower, Mobil 5w40 super 3000.
What do you think is the best oil?
I want good detergents for cleaning sludge, and good lubrication of course. I am changing the oil every 8500-10000 kilometers.
Any advices?
Cheers all!
Re: What oil(EUROPE) [Re: IvanPletex] #5381385 03/20/20 03:58 PM
sloinker Offline
Might look for some ester content to keep the ring lands free from coke/deposits. Ravenol would be my choice. From your list Motul.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: What oil(EUROPE) [Re: IvanPletex] #5381483 03/20/20 05:43 PM
K
Kamele0N Offline
K
What car? Non dpf equiped Diesel....use HDEO...
Shell Rimula r6m...for one Oči to clean sludge (HDEO has more detergent)....then continue with SHU 5w40...or Mobil1... Both mentioned above (actually all 3) are GTL based
Edit: Mobil1 3000 IS not...ESP it IS!
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: What oil(EUROPE) [Re: Kamele0N] #5381493 03/20/20 05:54 PM
I
I
It is Fiat Grande Punto 1.3 MjTD, i removed DPF from the car. EGR is not removed.
Re: What oil(EUROPE) [Re: sloinker] #5381495 03/20/20 05:55 PM
I
I
Hm, I did not hear for Ravenol, it is not common oil here..In fact I did not see that oil in stores in my region.
Re: What oil(EUROPE) [Re: IvanPletex] #5381705 03/20/20 10:24 PM
DrDanger Offline
My 2c.
The Total is the cheapest. I'm running it and its not the best.
Mobil 3000 is very similar.
Our russian buddies have most of the oils VOA's here https://www.oil-club.ru/forum/forum/33-laboratornye-analizy-svezhie/
Go for Shell HX-8. Per above forum same as Ultra, just cheaper. GTL base (oil made from natural gas) is superior to the other oil's base.That and a good add pack with boron and moly, makes it the clear choice for me(others have just one or the other, bar maybe the Motul, which would be much more expensive).
Re: What oil(EUROPE) [Re: IvanPletex] #5381706 03/20/20 10:25 PM
sloinker Offline
Mail order here in the states. Eastern Europe isn't far from Germany if I remember my junior high geography. Remember that here in the states "not far" is less than 1000 miles.
Re: What oil(EUROPE) [Re: IvanPletex] #5381719 03/20/20 11:22 PM
E
edyvw Offline
E
Get Cstrol Edge 0W30 C3. Forget everything else.
It is not thin, it is premier product for Castrol and you should be able to easily find it. It is PAO based oil.
It does not matter that you took DPF out, I personally would use that oil before anything else.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: What oil(EUROPE) [Re: IvanPletex] #5381921 03/21/20 09:08 AM
F
Falcon_LS Offline
F
Selenia WR 5W-40 is a good oil, personally I would stick with it. If you must change, you can't go wrong with Shell. If memory serves me right, Selenia is also an OE supplier to Fiat.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
05 Envoy: XG9837
Motorcraft 5W-50:
18 Mustang GT: XG10575
Re: What oil(EUROPE) [Re: Falcon_LS] #5382020 03/21/20 10:56 AM
I
I
Yes it is. But it is also expencive. Selenia WR 5W40 is approximately 9€ for 1 liter, and Shell helix UL 5w40 is 5.5€ per liter. I dont understand that price of Selenia. I dont think it is better than mentioned Shell.
Re: What oil(EUROPE) [Re: IvanPletex] #5382553 03/22/20 12:12 AM
E
edyvw Offline
E
Selenia was always expensive. I used WR 5W40 in Lancia Lybra 2.4JTD and it was by far the smoothest oil I used in that engine.
IDK whether they changed formulation since Petronas took over, probably they did.
