This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Refrigerator runs in cooling mode for 2+ hours.
by mrsilv04 - 03/30/20 09:24 AM
Non Detergent Oil
by 10ecfarmer - 03/30/20 08:06 AM
Joe Diffie on vinyl
by skyactiv - 03/30/20 07:52 AM
cooling system vacuum refill kit
by Donald - 03/30/20 07:35 AM
What's the proper oil for a push mower
by jayjr1105 - 03/30/20 07:31 AM
Honda DW-1 OLD Bottles Question.
by David1 - 03/30/20 06:25 AM
Winter 'shoes' for office goers
by MoneyJohn - 03/30/20 05:54 AM
2004 FZ6 Delo 400
by thestockie1 - 03/30/20 04:34 AM
Turn signals all blinking fast
by JHZR2 - 03/30/20 12:14 AM
rider9195, kingsville911, B34R, ChrisSnowden, DIY4quality
71055 Registered Users
110 registered members (Audios, 007, 2015_PSD, 440Magnum, B34R, 25ring, 15 invisible), 2,084 guests, and 17 spiders.
Topics303,358
Posts5,234,722
Members71,055
Honda generator oil. #5381258 03/20/20 01:40 PM
J
JustinSL Offline OP
J
Recently traded into a Honda EU2000i generator. Seems to run good on high idle but surges some on eco mode. I’m going to take the carb off and clean it , change the oil , spark plug and check over everything while I have it tore down. Looks like it calls for 10w-30 so I will probably stick with that and a 20 hour oci since I won’t be using it a ton. What are you guys running as far as oil and weight?
Re: Honda generator oil. [Re: JustinSL] #5381263 03/20/20 01:44 PM
c502cid Offline
My 3 aren't picky at all, whatever I have is what they get. Make sure after you shut it down you use the bowl drain in the bottom of the carb. It's a great feature to keep them from getting gummed up.
15 Chev Trax AWD
02 GMC 3500 8.1/Ally DRW 4x4
00 Blazer 4.3 4x4
97/98 Civics
84 Chev K30 454EFI/T400/NP205 DRW 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
08 Kawi Brute Force 750
Re: Honda generator oil. [Re: JustinSL] #5381265 03/20/20 01:48 PM
L
Lenny5160 Offline
L
I have the Yamaha equivalent 2000w inverter generator, and it usually gets Supertech HD30.
Re: Honda generator oil. [Re: JustinSL] #5381276 03/20/20 01:58 PM
spasm3 Offline
Amsoil HDD 5w-30
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Honda generator oil. [Re: c502cid] #5381278 03/20/20 01:59 PM
J
JustinSL Offline OP
J
I didn’t think it would be too picky as far as oil goes. Luckily I can get Ethenol Free gas close by and will be running that with PRI-G fuel additive as well. Luckily that’s how I got it was because the carb needs cleaned and the previous owner didn’t want to mess with it.
Re: Honda generator oil. [Re: JustinSL] #5381309 03/20/20 02:23 PM
L
Lubener Offline
L
10W-30 is what I use in my generator. Ok for all seasons.
The "thinking" man's friend.
Re: Honda generator oil. [Re: JustinSL] #5381352 03/20/20 03:06 PM
Cujet Offline
I use M1, 10W-30 in my EU2000i. That little generator has been working perfectly for years, through multiple hurricanes and other emergencies.
Re: Honda generator oil. [Re: JustinSL] #5381394 03/20/20 04:06 PM
L
Lawn_Care Offline
L
Super Tech 15w40 or Harvest King 15w40. 5w40 in the winter.
Air cooled engines run hot, and a 40 is much better suited for these.
Having been involved in Katrina cleanup, many gen sets running 30's failed in the hot humid NO weather running continuously.
Those running a 40-wt had a much lower failure rate.
Re: Honda generator oil. [Re: JustinSL] #5381429 03/20/20 04:45 PM
J
JTK Offline
J
I think Honda does a pretty nice job designing these to run as cool as possible, so any old 30wt variant changed at a reasonable interval will keep it running for a long time. Regardless, If I have a heavy-duty 40wt variant on hand, that's what I'd use in any OPE aside from a snowblower.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Honda generator oil. [Re: JustinSL] #5381437 03/20/20 04:49 PM
O
Oildudeny Offline
O
My champion generator calls for 10w30 and I dont believe your Honda is picky on the brand of 10w30. Just use a quality oil, 20hr change intervals go with conventional unless you buy a 5qt jug of super tech. I personally use super tech or napa
Once you clean the carb.. use 93 octane with stable or Chevron with techron to keep the gas fresh.
Re: Honda generator oil. [Re: JustinSL] #5381466 03/20/20 05:24 PM
A
Astro_Guy Offline
A
I like Mobil 1 10w-30 High Mileage for the 3.5 HTHS. Presently both of my generators have Rotella T6 5w-40 in the sump, but I may switch back to the Mobil 1.
Re: Honda generator oil. [Re: JustinSL] #5382391 03/21/20 08:18 PM
spasm3 Offline
I run the amsoil HDD because it has the HTHS of 3.5. And since it sits a lot between running, i like the tbn of 12.1
Re: Honda generator oil. [Re: JustinSL] #5382431 03/21/20 09:08 PM
N
Normac Offline
N
A 2nd the above comments about running a 40-wt in these small air cooled engines.
I've seen to many of these things overheat running thinner oils in near continuous operations.
Re: Honda generator oil. [Re: JustinSL] #5387289 03/27/20 07:22 PM
J
JustinSL Offline OP
J
Ended up going with PYB 10w-40 for those that are interested.
Re: Honda generator oil. [Re: JustinSL] #5388622 03/29/20 12:24 PM
charles_slc Offline
I'm looking at a Westinghouse 4500 dual-fuel inverter, the manual specifies 10w-30 between 32f - 80f and 5w-30 below / 15w-40 above that range.
That seems to be a very narrow/specific range.
I'm planning to use it camping and also for emergencies at home (house already wired with a transfer switch with 30amp input).
So I foresee it being used anywhere between 0-110f.
Seems like a nice synthetic should cover that range, but I'm a software guy...not an oil guy.
If I really need to switch, could I get away with 5W-30 in the winter and 10W-40 in the summer or some other combination?
