Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Refrigerator runs in cooling mode for 2+ hours.
by mrsilv04 - 03/30/20 09:24 AM
Non Detergent Oil
by 10ecfarmer - 03/30/20 08:06 AM
Joe Diffie on vinyl
by skyactiv - 03/30/20 07:52 AM
cooling system vacuum refill kit
by Donald - 03/30/20 07:35 AM
What's the proper oil for a push mower
by jayjr1105 - 03/30/20 07:31 AM
Honda DW-1 OLD Bottles Question.
by David1 - 03/30/20 06:25 AM
Winter 'shoes' for office goers
by MoneyJohn - 03/30/20 05:54 AM
Life2race, rider9195, kingsville911, B34R, ChrisSnowden
71056 Registered Users
115 registered members (2009Edge, 4WD, 10ecfarmer, 53' Stude, 2010Civic, 2K2AcuraTL, 8 invisible), 1,868 guests, and 20 spiders.
Topics303,360
Posts5,234,778
Members71,056
1960's Honda G40 170cc Engine #5380907 03/20/20 06:04 AM
B
Bailes1992 Offline OP
B
Trying to build myself a petrol powered air compressor as cheap as I can.
I picked up a very old generator yesterday for £30. It was fully operational, although I probably wouldn't have wanted to use it. LOL
The engine is a Honda G40, I've seen it start and run, it ran surprisingly well. The person I bought it off recently found it clearing out some storage containers belonging to his Father who died several years ago. Apparently he topped up the fuel tank, pulled the cord and it fired into life.
There is a tap that comes off the fuel tank which is leaking a small amount of fuel and the boot and HT lead going to the spark plug is cracked and fatigued. I'd also like to re-string the pull cord as the existing item is badly worn and frayed.
I'm struggling to find a workshop manual or replacement parts. The Honda G42 seems to be based heavily on the G40, I suspect it was an emissions update. Are parts interchangeable?
I will probably be looking to quieten the exhaust down somewhat. Are small engine exhaust flanges usually the same? The current exhaust has a small mount of rot on the bottom.
My plan is to run a centrifugal clutch on the back of this with a V-Belt running a compressor pump around 10-15cfm. I will then control the engine speed by grafting on a compressor throttle control onto the governor. I.e. at 9-10bar the engine will be at idle and the clutch open, at 8bar I'd want the clutch starting to close and drive the compressor and by 6bar I'd expect the engine to be at max speed.
And obviously... why we are all here... oil! My plan is to run a 15w40 A3/B4 oil in this and change every 100 hours or so. The oil I drained out last night was a little sludgey, thick and some shiny filings. I expect it's been in there for 10-20 years so it's no surprise really. Anyone have any other suggestions for oils in this? Obviously i would love to drop some Valvoline Blue Restore into it but £150 for 3.78litres of oil is just unjustifiable.
IMG_20200319_210313.jpgIMG_20200319_195912.jpgIMG_20200319_210307.jpgIMG_20200319_173341_resized_20200320_083728944.jpg
19 Volvo V40 D3 - 19 Jeep Renegade eTorq - 03 Ford Mondeo 3.0 V6 - 96 LR Defender 90 300TDi
Castrol Edge 5w30 LL
Valvoline Maxlife ATF
Fuchs Sintofluid 75w80
Fuchs Sintopoid 75w90
Re: 1960's Honda G40 170cc Engine [Re: Bailes1992] #5381432 03/20/20 04:47 PM
J
JTK Offline
J
Very cool! I've only see a handfull of Honda flat-head OPE engines.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
