Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 04/01/20 02:41 PM
NEW Adam's Polishes - Hand Sanitizer
by SavagePatch - 04/01/20 02:40 PM
Home vehicle modification fails
by IMSA_Racing_Fan - 04/01/20 01:57 PM
Internet speeds in current climate.
by sloinker - 04/01/20 01:55 PM
concrete work while at home
by spasm3 - 04/01/20 01:19 PM
Oil change
by IvanPletex - 04/01/20 12:52 PM
New Battery --> Group 25 (stock), 24 or 34???
by gathermewool - 04/01/20 12:49 PM
Tell this geezer why I need gigabit Internet?
by csandste - 04/01/20 11:48 AM
KenoshaWizard, junipertoxic, mtnrider, Rickborn, TreyT42
71071 Registered Users
115 registered members (2002 Maxima SE, 53' Stude, 2K2AcuraTL, apollo18, AC1DD, 15 invisible), 1,882 guests, and 21 spiders.
Topics303,440
Posts5,235,348
Members71,071
Transmission fluid service. #5380867 03/20/20 03:52 AM
M
Mattz Offline OP
M
I have a 2011 jeep grand Cherokee laredo. I purchased it usee I dont know any service history when I got it the odometer was at 130 000 ish km no I am at 150 000 ish runs good not problems. I was thinking of having the trans fluid serviced my local garage wanted me to have the BG trans flush serviced done? I was reading flushing is dangerous to transmission? A pan drop would be more suitable? I called a trans shop they said if it isent giving you problems leave it alone. What's my best opinion?
Re: Transmission fluid service. [Re: Mattz] #5380872 03/20/20 04:09 AM
SilentForever05 Offline
I say it is still not too late, just drain and refill using oem fluid and change the filter if there is one. Never flush. I did that before on not too dirty fluid and while it did not make it blowup the shifts are not as good as previously immediately after the flush. If the fluid is really dirty now, I will do multiple drains in a short interval to get it all out and change the filter on the final drain.
Re: Transmission fluid service. [Re: Mattz] #5380927 03/20/20 06:52 AM
supton Online Content
Online Content
I'm a fan of flushing--clean fluid is never bad fluid.
If it wasn't driven hard it's probably not bad, but probably due. You could do drain and fills, but it'd just be faster to do a full exchange IMO. The trans shop doesn't want to be on the hook if anything happens in short order after changing the fluid, coincidence or not.
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Transmission fluid service. [Re: Mattz] #5380939 03/20/20 07:02 AM
Astro14 Offline
I wouldn’t do a flush. I’ve had problems after a flush.
Perhaps it’s the BG machine, perhaps the BG fluid, perhaps it’s stirring something up, but my 1990 4 Runner has regular fluid changes, worked perfectly, and I let a shop flush it to change the fluid, and it was never right afterwards, it overheated on the highway, the torque converter wouldn’t lock anymore. Just awful.
But a cooler line fluid exchange of all the fluid, including in a 150,000 mile transmission in which the fluid came out black, has always worked great.
Exchange the fluid.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Transmission fluid service. [Re: Astro14] #5380947 03/20/20 07:09 AM
B
bbhero Offline
B
I agree....
I did 3 drain and refills over 6,500 miles on my car with a CVT transmission at 283,500 miles. It has been perfect since and quieter too.
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: Transmission fluid service. [Re: Mattz] #5380949 03/20/20 07:13 AM
Z
zrxkawboy Offline
Z
The most important thing is to use an approved ATF+4.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Transmission fluid service. [Re: Mattz] #5380956 03/20/20 07:24 AM
K
Kira Online Content
Online Content
K
A transmission drain & fill...you know, a flush
A disconnected cooling line pump-out.....you know, a flush
A BG transmission flush service....you know, a flush
Some no-name, violently acting, direction reversing pump attachment machine they attach to your car and walk away from.....you know, a flush
You know?
Re: Transmission fluid service. [Re: Mattz] #5380991 03/20/20 07:50 AM
W
WyrTwister Offline
W
Pan drop .
Wyr
God bless
Re: Transmission fluid service. [Re: Mattz] #5381007 03/20/20 08:07 AM
B
BMWTurboDzl Offline
B
That's only 90,000 miles.
IMO you're at the "Fish or Cut Bait" moment. Ask yourself if you're in the financial position to diagnosis/repair any issues which occur post change? If so, then I would consider a simple pan drop w/new filter and keep on trucking.
435i
Re: Transmission fluid service. [Re: Mattz] #5381013 03/20/20 08:10 AM
Snagglefoot Online Content
Online Content
For the record, had two flushes done at the GM dealer on my 6L90. Everything is fine. YRMV. smile
If you want the job done right......do it yourself.
Re: Transmission fluid service. [Re: Mattz] #5381109 03/20/20 09:59 AM
G
Gebo Offline
G
Drop the pan and add OEM ATF.
Flushes are a rip off to the customer and a great profit for the owner of the flush machine.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Transmission fluid service. [Re: Mattz] #5381125 03/20/20 10:19 AM
csandste Offline
I had a flush and fill with MaxLife. Works fine, about the same as the oem fluid.
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Transmission fluid service. [Re: Mattz] #5381136 03/20/20 10:31 AM
SubieRubyRoo Offline
Spill 'n fill is all you need.
De omnibus dubitandum.
Re: Transmission fluid service. [Re: Kira] #5381152 03/20/20 10:51 AM
Donald Offline
You know?
I am not sure you are accurately describing a trans flush machine. It performs two functions, it receives used trans fluid and pushes new fluid into the pan at the same rate it is receiving used fluid. The pump in the transmission is always the one that pushes fluid through the transmission. Nothing is done in reverse flow.
More accurately it is a fluid exchange machine. You can do the same yourself but have to do it by doing 2 or 3 quarts at a time.
2015 Ford F-250 w/Powerstroke
Re: Transmission fluid service. [Re: Mattz] #5381157 03/20/20 10:57 AM
B
blufeb95 Online Content
Online Content
B
Looks like your transmission holds about 10qt, and when you drain and fill you'll remove and replace anywhere from 4-6qts of the fluid, I created some dilution tables here to show if you change out the fluid in the pan a couple times roughly how much of each fill will be remaining, assuming it mixes almost perfectly.
Here's a table if you can only get 4qts out at a time
[Linked Image]
Here's a table if you can get 5qts out at a time
[Linked Image]
Here's a table if you can get 6qts out at a time
[Linked Image]
