RV's for MD's
by 02SE - 04/07/20 01:42 AM
Crawfish, It's A Louisiana Thang!
by BlueOvalFitter - 04/07/20 01:01 AM
M&P .40 Magazines $12.99
by BlueOvalFitter - 04/06/20 11:30 PM
Lots of Big Sur pics, only one of the car :-)
by SLO_Town - 04/06/20 09:24 PM
'16 Pilot Inline ATF filter
by parshisa - 04/06/20 08:55 PM
2019 Ram 1500 Classic
by Skippy722 - 04/06/20 08:53 PM
STP S3614 XL CUT OPEN
by 53' Stude - 04/06/20 07:15 PM
Kia Rio awful sound after sitting 5 years
by antonmnster - 04/06/20 07:13 PM
Cut open Motorcraft FL820S
by PantherFan88 - 04/06/20 06:38 PM
240V Electric Hookup Questions
by 92saturnsl2 - 04/06/20 06:33 PM
license plate frame with 3rd brake light
by wings&wheels - 04/06/20 06:12 PM
Wurth HHS 2000
by ejt - 04/06/20 06:06 PM
Snapper drive belt install trouble LT300
by spk2000 - 04/06/20 05:56 PM
installing garage LED shop light help needed
by FirstNissan - 04/06/20 05:20 PM
Casite filters
by opus - 04/06/20 05:16 PM
Oil for Jeep
by rokwldr - 04/06/20 05:12 PM
Kitchen sink faucet leak help
by 97prizm - 04/06/20 04:45 PM
RIP Al Kaline.
by PimTac - 04/06/20 04:36 PM
Frankentruck power steering question
by Thomcat316 - 04/06/20 04:11 PM
Comment from Miata track on Amsoil GL-4
by Bill_W - 04/06/20 03:28 PM
BludRacing, Cacciatore, Thomcat316, NTexian, LateLifeCrisis
71116 Registered Users
29 registered members (dave63, CNT, Black_Thunder, carlprop, BlueOvalFitter, cabriopeugeot, 2 invisible), 1,236 guests, and 18 spiders.
Topics303,699
Posts5,240,213
Members71,116
Page 1 of 4 1 2 3 4
Yes Magnatec IS quieter...again. #5380865 03/20/20 03:45 AM
Shannow Offline OP
Yes, my Colorado is a diesel, but like I keep saying engine designs are closer together than forever, some run diesel, some run petrol.
40,000 mile service on the Colorado I left Magnatec DX 5W40 C3/Dexos 2 on the passengar seat, to replace the havoline 5W40...
the engine sounds more like a gasser than ever...
If it's the truth....it can handle the pressure !!!
Re: Yes Magnatec IS quieter...again. [Re: Shannow] #5380874 03/20/20 04:17 AM
O
OilUzer Offline
O
You got a lot of miles on that car. Isn't only couple of years old?
What's C3? Is it diesel equivalent of A3/B4?
I bought 2 5qt of Casterol GTX Magnatec 10W30 Full Synthetic but haven't used it yet. Trying to get rid of some of my old dino first. I used to use Castrol GTX dino white bottles and still have a quart left. I may have to mix it with some Chevron Supreme to get rid of it. It maybe api sm or sl grin2
Re: Yes Magnatec IS quieter...again. [Re: OilUzer] #5380877 03/20/20 04:31 AM
O
Olas Offline
O
A3/B3 - Stable, stay-in-grade Engine Oil intended for use in Passenger Car & Light Duty Van Gasoline & Diesel Engines
with extended drain intervals where specified by the Engine Manufacturer, and for severe operating conditions as
defined by the Engine Manufacturer.
A3/B4 Stable, stay-in-grade Engine Oil intended for use at extended Drain Intervals in Passenger Car & Light Duty Van
Gasoline & DI Diesel Engines, but also suitable for applications described under A3/B3.
C3 - Stable, stay-in-grade Engine Oil with Mid SAPS-Level, intended for use as catalyst compatible Oil at extended
Drain Intervals in Vehicles with all Types of modern Aftertreatment Systems and High Performance Passenger
Car & Light Duty Van Gasoline & DI Diesel Engines that are designed to be capable of using Oils with a minimum
HTHS Viscosity of 3.5 mPas.
all copied from here;
https://www.acea.be/uploads/news_documents/ACEA_European_oil_sequences_2016.pdf
Re: Yes Magnatec IS quieter...again. [Re: OilUzer] #5380882 03/20/20 05:06 AM
Shannow Offline OP
It will be 4 years old next month, I've had it for 3.5 now, and put 35,000 miles on it...so not a heaps fast rate.
Yeah, others have described it...the A's are high performance Gas, the B's are high performance diesel...the C is low SAPS gas and Diesel C3 is HTHS above 3.5...the Dexos 2 covers gas and diesel with a tighter spread on quite a few parameters...anything Dexos 2 IMO is a good thing for nearly anything.
Re: Yes Magnatec IS quieter...again. [Re: Shannow] #5380900 03/20/20 05:54 AM
G
Gokhan Offline
G
I don't have the HTHS data, but assuming 3.7 cP for the Havoline and 3.8 cP for the Magnatec, Magnatec would have a thicker base oil by 0.35 cP, which is a lot and would explain the quietness. If I assume 3.7 cP for both, then it's only 0.15 cP higher.
Estimated base-oil viscosity (BO DV150) and VII content of selected oils
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 70 mpg on gas, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Yes Magnatec IS quieter...again. [Re: Shannow] #5380901 03/20/20 05:57 AM
M
Mad_Hatter Offline
M
There's a side of me that always wants to say oil is oil.. how can one be louder than the other? But in practice, I know what you're saying Shannow. There are some lubes that seem to elicit more VT or TC noise, especially at start up in my V6. I have no way of like proving it in any scientific way other than my "calibrated ear" has come to learn how my car sounds. Or maybe I should say, should sound. Is it (louder sounding lubes) hurting anything in a meaningful way, dunno.. maybe or maybe not. That's an entirely different discussion.
Re: Yes Magnatec IS quieter...again. [Re: Shannow] #5380925 03/20/20 06:47 AM
M
MParr Offline
M
C3 oil is basically a VW 504.00/507.00
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2017 Ford Escape SE 2.0T Now: Kendall GT-1 Max 5W30 FS & NAPA Gold 1348
2014 F-150 4x4 Now: Pro DS 5W20 & Motorcraft FL-500s
Re: Yes Magnatec IS quieter...again. [Re: Shannow] #5380929 03/20/20 06:54 AM
K
ka9mnx Offline
K
Shannow. Are you pulling our leg? Experts here claim engine sound cannot be measured by the "ear" and doesn't mean anything.
Just pulling your leg!
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Yes Magnatec IS quieter...again. [Re: Shannow] #5380932 03/20/20 06:55 AM
A
aquariuscsm Offline
A
Some oils do if fact run smoother-quieter than others.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: Yes Magnatec IS quieter...again. [Re: aquariuscsm] #5380936 03/20/20 06:58 AM
K
ka9mnx Offline
K
I agree but I don't mention it here because of said criticism.
Re: Yes Magnatec IS quieter...again. [Re: ka9mnx] #5380940 03/20/20 07:02 AM
demarpaint Offline
I've noticed that too.
God Bless Our Troops
Re: Yes Magnatec IS quieter...again. [Re: Shannow] #5380953 03/20/20 07:17 AM
O
Olas Offline
O
Mobil1 is *LOUD
Everything else is roughly average
Redline is whisper quiet
Re: Yes Magnatec IS quieter...again. [Re: Shannow] #5380972 03/20/20 07:39 AM
K
Kira Offline
K
When a semi-boutique oil made the acceptable ticking of my VT vanish, I knew
When myself and 2 friends -hundreds of miles apart- noticed quieter engines with the same particular oil, I knew
And when a specced synthetic greatly quieted an engine previously lubed with cheaper conventional oils only, I knew
I'm tempted to try Red Line or Amsoil next.
Re: Yes Magnatec IS quieter...again. [Re: ka9mnx] #5380992 03/20/20 07:51 AM
Shannow Offline OP
search my posts...
Re: Yes Magnatec IS quieter...again. [Re: Shannow] #5381000 03/20/20 08:02 AM
G
Gillsy Offline
G
Magnatec is all I run anymore. Smooth, quiet, and I think the low end torque is slightly better due to interaction with variable valve timing.
Many are the afflictions of a righteous man
2019 Nissan Murano S
2018 Gravely ZT HD 52
2016 Kawasaki 650 Versys LT
2012 Mazda 3 Skyactiv 2 ltr
Page 1 of 4 1 2 3 4
