CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Refrigerator runs in cooling mode for 2+ hours.
by mrsilv04 - 03/30/20 09:24 AM
Non Detergent Oil
by 10ecfarmer - 03/30/20 08:06 AM
Joe Diffie on vinyl
by skyactiv - 03/30/20 07:52 AM
cooling system vacuum refill kit
by Donald - 03/30/20 07:35 AM
What's the proper oil for a push mower
by jayjr1105 - 03/30/20 07:31 AM
Honda DW-1 OLD Bottles Question.
by David1 - 03/30/20 06:25 AM
Winter 'shoes' for office goers
by MoneyJohn - 03/30/20 05:54 AM
2004 FZ6 Delo 400
by thestockie1 - 03/30/20 04:34 AM
Life2race, rider9195, kingsville911, B34R, ChrisSnowden
71056 Registered Users
108 registered members (2009Edge, 2010Civic, 53' Stude, aquariuscsm, ArrestMeRedZ, 4WD, 16 invisible), 1,868 guests, and 22 spiders.
Topics303,359
Posts5,234,749
Members71,055
Firestone destination LE3 #5380864 03/20/20 03:44 AM
M
Mattz Offline OP
M
Hey guys.
I was searching for a new set of tires for my wifes 2011 Dodge Journey Crew 225/55/19 after doing some research I came across the Firestone destination le2 which had alot of positive reviews. Anway I go to order them and the guy on the phone says I'll give you the new version le3 for same price. I am like sure I asked the difference he said longer tread life and they are arnt going to be making the le2 anymore. That being said do you think they will be better then the le2 or should I just have him order the cooper srx same tire I have on my grand cherokee...
Thanks for the input!
Re: Firestone destination LE3 [Re: Mattz] #5380868 03/20/20 03:56 AM
O
Olas Offline
O
look at the treadwear rating - treadwear is inversely proportional to grip.
Cable ties should hold it
Re: Firestone destination LE3 [Re: Mattz] #5380869 03/20/20 03:58 AM
Char Baby Offline
Too hard for anyone to tell you if they'll be better.
The LE2's are/were certainly a good tire. Everyone whom I have recommended them to, loved them. And if Firestone is now replacing them with a 3rd generation, they may have improved a portion of the tire that didn't do well in objective testing compared to its competition. That could be tread life and other factors too.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Firestone destination LE3 [Re: Mattz] #5380881 03/20/20 04:58 AM
Char Baby Offline
Here is a TireRack link on the LE2 & LE3 in your size(225-55-19). IDK if the site will timeout but, give it a try. It shows(side-by-side) the tires with some of the important specs and some differences. Scroll down to the "Detailed Specifications(+) and open it up.
https://www.tirerack.com/tires/CompareTires.jsp
Re: Firestone destination LE3 [Re: Mattz] #5380889 03/20/20 05:24 AM
M
msmoke00 Offline
M
I haven't gotten my hands on any LE3 yet to see if Firestone actually made the siping full length in those tires. The LE2 is notorious for poor all season and wet traction once they start to wear down a little. I see they went from a 520ab rating to a 700ab in your size so life should be better than the previous LE2. Hopefully a similar silica compound was still used for traction in the new version.
A General RT43 is also rated at 700aa in that size and would perform better in all season based on my experience. A Conti LX25 and Truecontact tour would fall in the same vein as well as high wearing tires that perform well. The RT43 and Truecontact are both touring tires verses the others being "suv" or highway type. FWIW
The SRX isn't a bad tire either and will wear in similar fashion to the other tires mentioned. They tend to handle well especially with the straighter channels.
Re: Firestone destination LE3 [Re: Olas] #5380943 03/20/20 07:06 AM
CapriRacer Offline
Ah …. Mmmm ….. Not exactly.
When it comes to tread compounds, it's a 3 way - Rolling Resistance/Treadwear/Traction.
But it gets even more complicated if you factor in tread pattern, as tread pattern has an effect on all 3.
And it is possible through research to improve the treadwear without sacrificing the other 2 (and vice versa!)
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Firestone destination LE3 [Re: Mattz] #5380960 03/20/20 07:26 AM
supton Offline
Seems like, recommendations for LE's are up and down. But RT43's are generally positive, with complaints being more about being squishy and not a performance tire. Not sure what you are after but in general I recommend RT43's for any sort of pedestrian driving.
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Firestone destination LE3 [Re: Mattz] #5380988 03/20/20 07:49 AM
danez_yoda Offline
My wifes Sienna loves the General RT43. I'm just hitting 50K miles in them and they are just getting to the wear bars. Siennas are big and heavy and known to eat tires so this is impressive. Especially considering the OEM Michelin MXV4s only lasted 30K. No change in drive performance.
That said if you already got the Firestone LE3s more than likely you will be happy with them. The LE and LE2 were both good tires so I have no reason to think the LE3 would be any worse. This was for a LT application. I would imagine they would be a little rough for a suv.
Re: Firestone destination LE3 [Re: Mattz] #5381016 03/20/20 08:13 AM
M
mrsilv04 Offline
M
From the Firestone website. If this is to be believed, then it sound like they've made changes, and added some badly needed full depth sipes. Tread design is largely the same.
A new spin on a favorite with its improved TractionTech™ Technology; now has even more consistent wear over the life of the tire. In addition to improved traction, this tire’s Hydro-Grip™ Technology offers enhanced water evacuation in wet conditions, keeping you and your vehicle safe. The full depth 3D sipes help navigate snowy weather and perform throughout the life of the tire tread.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Firestone destination LE3 [Re: Mattz] #5381054 03/20/20 08:51 AM
A
ARCOgraphite Offline
A
I had the Le2 on my Rogue Select., While they were "just ok" I would not run them again
They rode HARD as a ROCK. And I mean hard. Horrendous impact harshness.
I even dropped the placard TP by 3 lbs and it rode hard, still..
I did like the factory Conti's much better, though they got pretty skittish in the winter when 3/4 worn
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Firestone destination LE3 [Re: Mattz] #5381138 03/20/20 10:33 AM
M
meep Offline
M
full length siping will help. We had 2 sets and really liked them in dry conditions but not wet/frozen. agreement with above, the were a hard tire - so they handled well if you were feeling aggressive in the SUV, but they did transmit all the bumpz.
2018 F150
2015 crv (wifey!)
Re: Firestone destination LE3 [Re: Mattz] #5381145 03/20/20 10:43 AM
H
Hermann Offline
H
Back in 2008 my Tacoma came with the original Destination LE. Great Tire. Bought a set of LE2's and they were horrible. Rough riding and not good in wet and snow like the original. It's like they were made of plastic rubber not the real stuff.
2018 Ford F-150 XL Reg Cab - 3.3L NA V-6
Motorcraft 5w-20 Syn Blend and Motorcraft FL-500s
1991 BMW R100GS 20w-50 Maxlife & Mahle OX36D filter
Re: Firestone destination LE3 [Re: Mattz] #5381224 03/20/20 12:43 PM
W
wayne50 Offline
W
Have an 05 Tacoma that came with Destination LE and they were very good. Only took them off because they were 10 years old, although they showed no cracking.
Re: Firestone destination LE3 [Re: Mattz] #5381292 03/20/20 02:10 PM
M
Mattz Offline OP
M
Would the cooper srx be a better tire?
Re: Firestone destination LE3 [Re: Mattz] #5381813 03/21/20 07:00 AM
silversport Offline
have the Destination LE2s on a 2007 F150 and they seem to ride just fine compared to other tires I've had on a 2000 Escalade and a 2002 Avalanche...they've done fine in the rain and snow round the ChicagoLand area (mostly in 2WD) for the year I've had them...better of course in 4WD when needed...
they would not have been my first choice but I had to replace 3 from the original owner, the 4th was brand new when I got it and 3 new were far less than 4 of most anything I could get for the price at the time and the Firestone Destination LE2s had a good reputation on several F150 forums so I went with them...not disappointed in their performance
Bill
