CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Refrigerator runs in cooling mode for 2+ hours.
by mrsilv04 - 03/30/20 09:24 AM
Non Detergent Oil
by 10ecfarmer - 03/30/20 08:06 AM
Joe Diffie on vinyl
by skyactiv - 03/30/20 07:52 AM
cooling system vacuum refill kit
by Donald - 03/30/20 07:35 AM
What's the proper oil for a push mower
by jayjr1105 - 03/30/20 07:31 AM
Honda DW-1 OLD Bottles Question.
by David1 - 03/30/20 06:25 AM
Winter 'shoes' for office goers
by MoneyJohn - 03/30/20 05:54 AM
2004 FZ6 Delo 400
by thestockie1 - 03/30/20 04:34 AM
Life2race, rider9195, kingsville911, B34R, ChrisSnowden
71056 Registered Users
113 registered members (AC1DD, 2009Edge, 2010Civic, 53' Stude, aquariuscsm, 4WD, 14 invisible), 1,820 guests, and 21 spiders.
Topics303,359
Posts5,234,749
Members71,055
Green grease for a big Excavator slew bearing #5380826 03/20/20 12:06 AM
B
BigRich954 Offline OP
B
I saw some kind of waterproof grease called green degrees supposed to be pretty good I thinking about using it.
Does it mix well ? Any good for heavy Equipment
Re: Green grease for a big Excavator slew bearing [Re: BigRich954] #5380861 03/20/20 03:05 AM
O
Olas Offline
O
do you mean this stuff?
Green Grease 101
Cable ties should hold it
Re: Green grease for a big Excavator slew bearing [Re: BigRich954] #5380891 03/20/20 05:29 AM
K
krismoriah72 Offline
K
Mystik JT6 is cheap and available most everywhere. Excellent washout resistance and rated GC-LB.
Mystik is less than $3
Green Grease is $9
Ive used both.
Re: Green grease for a big Excavator slew bearing [Re: BigRich954] #5380923 03/20/20 06:42 AM
R
Rob_Roy Offline
R
Assuming you are talking about the Green Grease in the link above - the MSDS says it uses a lithium complex thickener, so it should be compatible with most other greases. Check your operators manual to see what type of grease is recommended, and what the greasing procedure is - some manufactures want you to rotate the cab after you grease the zerks, then grease them again.
"Green Grease" would not be my first choice for an excavator. I am sure it would be fine for the swing bearing, but there are less expensive (and easily available) greases that will work fine for the swing bearing also. A calcium or aluminum complex grease with moly would be a better choice for the pins.
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: Green grease for a big Excavator slew bearing [Re: BigRich954] #5381102 03/20/20 09:49 AM
B
B
I use a Schaeffers 238 grease for the pins.
But I was told do not use a Moly grease for the slew bearing and I don’t know what would be good because it needs a extreme pressure grease
Re: Green grease for a big Excavator slew bearing [Re: BigRich954] #5381111 03/20/20 10:01 AM
B
B
Yea the one in the msds. Green grease
Re: Green grease for a big Excavator slew bearing [Re: BigRich954] #5381389 03/20/20 04:02 PM
R
Rob_Roy Offline
R
238 is an excellent grease for the pins. I agree that a moly grease is not needed for the slew bearing, and some manufactures may not want it in there. You could always call Schaeffer and see what they think.
The green grease should work well for the slew bearing, but if you want something less expensive the Mystik JT-6 High Temp grease mentioned above is a good choice.
1999 Ford F350, V10
