Collection of Euro Oils
by js1956 - 05/24/20 10:29 PM
00 grease in my brush mower
by Elkins45 - 05/24/20 09:55 PM
Coolant UV Dye - for without flushing
by Ndx - 05/24/20 09:10 PM
STP S8A C&P
by mpack88 - 05/24/20 07:50 PM
Aprons
by buck91 - 05/24/20 07:35 PM
Oil Additives for GDI engines
by Drew99GT - 05/24/20 07:21 PM
Memorial Day - Veteran's Cemetery
by JeffKeryk - 05/24/20 07:18 PM
CQ Blue, made by who?
by AJB0009 - 05/24/20 06:45 PM
recommended 5w30 for ticking and engine noises
by apollo18 - 05/24/20 06:29 PM
need new group 65 for my F-150, here's my choices:
by DirtyApe - 05/24/20 06:23 PM
Castrol EDGE cleaned my funnel
by AJB0009 - 05/24/20 05:29 PM
Metal Cloak FAD + Fox Steering Stabilizer
by 2015_PSD - 05/24/20 04:55 PM
Blue Driver OBDII
by Al - 05/24/20 04:50 PM
Coca Cola 600 at Charlotte Motor Speedway
by bdcardinal - 05/24/20 04:38 PM
Memorial day
by gman2304 - 05/24/20 04:33 PM
Transmission temp help!
by zx6rsi - 05/24/20 04:18 PM
BBC_bias, rabblrouzr, Modoi, zx6rsi, Chumpchange
71522 Registered Users
55 registered members (10WSmuckers, BTLew81, 2010Civic, Bruce T, bdcardinal, Bluebullet, 6 invisible), 1,794 guests, and 35 spiders.
Topics305,823
Posts5,281,044
Members71,522
Fram Ultra vs Extra Engine Air Filter #5380731 03/19/20 08:37 PM
gathermewool Offline OP
They look identical, except for color of the pleats and that the Ultra XGA9997 is slightly wider in one dimension than the Extra CA9997. The Ultra fit well.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
The old filters, for reference:
15 Legacy (Unknown, first change since purchase -19k miles ago)
[Linked Image]
[Linked Image]
14 Forester XT (~27k mikes)
[Linked Image]
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: Fram Ultra vs Extra Engine Air Filter [Re: gathermewool] #5380738 03/19/20 08:42 PM
B
blufeb95 Offline
B
The Ultra and Tough Guard Airfilters use a special oiled paper
Re: Fram Ultra vs Extra Engine Air Filter [Re: blufeb95] #5380741 03/19/20 08:45 PM
I remember reading that somewhere.
Re: Fram Ultra vs Extra Engine Air Filter [Re: gathermewool] #5380742 03/19/20 08:47 PM
U
UG_Passat Online Content
Online Content
U
Fram claims the wally-world special has special media that traps more dirt than the Extra
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Fram Ultra vs Extra Engine Air Filter [Re: UG_Passat] #5380746 03/19/20 08:50 PM
B
blufeb95 Offline
B
Also the Tough Guard, from my understanding the Tough Guard and Ultra air filters are identical, but the Ultra is exclusive to Walmart while the Tough Gaurd are available at other retailers.
Re: Fram Ultra vs Extra Engine Air Filter [Re: gathermewool] #5380750 03/19/20 08:52 PM
The Ultra was double the cost of the Extra. I didn’t source a Tough.
Re: Fram Ultra vs Extra Engine Air Filter [Re: gathermewool] #5380769 03/19/20 09:24 PM
slacktide_bitog Online Content
Online Content
The Ultra air filter is my go-to for every car they're available for smile
Re: Fram Ultra vs Extra Engine Air Filter [Re: blufeb95] #5380771 03/19/20 09:27 PM
U
Online Content
U
Fram says to replace tough guards, every 12,000 miles, same as extra guards.
The Ultras are 2 years, assuming they also imply 24,000 miles.
If you used a Subaru genuine air filter, then it's 30,000 miles.
Re: Fram Ultra vs Extra Engine Air Filter [Re: gathermewool] #5380773 03/19/20 09:30 PM
I'll likely stick with 24k miles with these filters from now on, which should be around two years anyway.
Re: Fram Ultra vs Extra Engine Air Filter [Re: gathermewool] #5380922 03/20/20 06:40 AM
T
Trav Offline
T
I cant say which of the two is better or worse but using the best air filter you can buy will help keep engine wear down, this is one part you don't want to skimp on.
Re: Fram Ultra vs Extra Engine Air Filter [Re: gathermewool] #5381014 03/20/20 08:12 AM
silversport Offline
the Walmart near me had both the Extra Guard and the Ultra for an F150...
the Ultra which Fram says is Walmart only is up to 24 months while the Extra Guard is 12K miles. the Ultra was only about $2 more than the Extra Guard...
I can find the OEM Motorcraft priced right in the middle of the two and should be 30K miles...YMMV
Bill
Re: Fram Ultra vs Extra Engine Air Filter [Re: UG_Passat] #5381134 03/20/20 10:30 AM
T
TTK Offline
T
Where did you get the 30k for the OEM Subaru filter? The Subaru maintenance interval?
2010 Volvo V70-3.2
Current Fill:Mobil 1 AP 5w-30
2018 Subaru Forester, 0w-20 Subaru oil
2001 Chevrolet Prism:Castrol Magnatec 5w-30
Re: Fram Ultra vs Extra Engine Air Filter [Re: gathermewool] #5381399 03/20/20 04:08 PM
M
metroplex Offline
M
I normally just gently tap the air filters clean and keep on trucking. I rarely replace them as per the mileage on the box.
Re: Fram Ultra vs Extra Engine Air Filter [Re: metroplex] #5381869 03/21/20 08:07 AM
I used to do the same, but it’s not worth it for something so cheap.
My biggest concern with changing the filter too often: it’s my belief that the largest risk for dirt ingress is during the filter change. The ducting in my Legacy travels upward from the box, but the FXT drops down into the fender, and then down to the turbo.
Re: Fram Ultra vs Extra Engine Air Filter [Re: gathermewool] #5382042 03/21/20 11:24 AM
F
Farnsworth Offline
F
The Ultra air filter doesn't look oiled and the website says the TG is oiled. So they are completely different filters. Is the Ultra pictured made in China?
I would want the best air filter not a choice of good, better, and best.
The Fram installation instructions says to vacuum the air filter housing, that is something I will start doing.
