'18 GMC Canyon 7k Havoline Pro DS 5w-30
by montero1 - 04/04/20 12:52 AM
KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
MC FL500S 7,000 miles CUT OPEN
by 53' Stude - 04/03/20 03:43 PM
USS Theodore Roosevelt
by BMWTurboDzl - 04/03/20 03:42 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
33 registered members (blufeb95, AZjeff, bachman, Alfred_B, bennyG, 3 invisible), 1,352 guests, and 18 spiders.
Topics303,556
Posts5,237,349
Members71,086
2012 Odyssey odd bypass valve deposits PICS #5380692 03/19/20 07:42 PM
B
Brybo86 Offline OP
B
I took off my upper intake manifold today for kicks and giggles
There were a small amount of deposits in the wells of the lower intake manifold near the left side/by pcv inlet.
I cleaned them out with a small screwdriver.
Shown on the towel.
I found some black deposits coated around the bypass valve on both butterfly valves
It almost looks like it was painted/caulked in.
They were brittle black , chipped off relatively easy.
I cleaned the throttle body using the brick on pedal method. It was hardly dirty. But the minimal deposits in the TB butterfly were a thin smooth consistency like the stuff in the intake manifold. But not quite as brittle. They were a little more goopy.
I did manage to crack off the little tab on the back of the airbox that holds the wires for the MAF sensor.
Gotta be pretty common to snap it, I don't see how the wire can be removed without breaking the tab. O well.
Anyone else seen deposits like these?
IMG_20200319_151338.jpgIMG_20200319_151719.jpgIMG_20200319_151726.jpgIMG_20200319_153204.jpgIMG_20200319_153227.jpg
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Re: 2012 Odyssey odd bypass valve deposits PICS [Re: Brybo86] #5381104 03/20/20 09:55 AM
SubieRubyRoo Offline
Yes, that's not really odd. It's par for the Odyssey course with VCM engines. The overarching idea is that the deactivated cylinders develop issues with the ring packs, and let oil mist by causing consumption. The PCV will recirculate the oil-mist-laden crankcase vapors into the intake, and they eventually accumulate in the intake and on the flappers like you found. Mine was the same way when I disassembled it shortly after I bought the van with 134k. I'd say it's a safe bet that your Ody: doesn't have a VCM disabler; and, spends most of its time putting around with the Eco dash light on. Chip it off, move on, and start using the full range of throttle travel more frequently! LOL
De omnibus dubitandum.
Re: 2012 Odyssey odd bypass valve deposits PICS [Re: SubieRubyRoo] #5381135 03/20/20 10:31 AM
B
Brybo86 Offline OP
B
Thanks for the reply regarding deposits.
I got the van about 3k miles ago and installed the S-VCM muzzler at that time.
09 Kymco Super8
01 Kymco People 50
95 Yamaha Jog
Re: 2012 Odyssey odd bypass valve deposits PICS [Re: Brybo86] #5381166 03/20/20 11:09 AM
P
PowerSurge Offline
P
Good deal. These engines I wouldn’t recommend doing extended oci’s.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: 2012 Odyssey odd bypass valve deposits PICS [Re: Brybo86] #5381757 03/21/20 01:07 AM
OP, good plan. I believe the underlying J35 is a good engine, gone bad thru mileage aspirations. Remove the VCM interference (as you’ve done) and as long as there was no damage already done, will be a good, dependable mill. I did UOAs on mine out to about 7,600 miles which is probably a safe maximum to avoid UOA costs.
Re: 2012 Odyssey odd bypass valve deposits PICS [Re: Brybo86] #5382190 03/21/20 02:27 PM
B
bulwnkl Offline
B
The J35Z5 in my Ridgeline is a great engine. Very durable, very reliable. I've taken it out to 10k on oil changes, per UOA. No problem in my climate and service conditions. YMMV.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
