Broken sway bar bolt
by HoosierJeeper - 03/29/20 04:00 PM
can I use it?
by avi1777 - 03/29/20 03:54 PM
Service Champ OF2222 75% OLM, unknown miles
by bullwinkle - 03/29/20 03:50 PM
Gas Buddy Question
by Wolfshead - 03/29/20 03:30 PM
Caliper piston boot
by painfx - 03/29/20 03:25 PM
Graphene the next detailing protection
by Mamala Bay - 03/29/20 02:17 PM
Anyone here a blacksmith?
by 53' Stude - 03/29/20 02:13 PM
Buying products made outside the USA
by 007 - 03/29/20 01:22 PM
Marine oils on sale at Canadian Tire
by Snagglefoot - 03/29/20 12:42 PM
0W16 instead of 0w20?
by Mter00s - 03/29/20 12:36 PM
XG10575 Walmart.com deal
by 762fermeandyou - 03/29/20 12:29 PM
Virgin ACDelco PF1245 cut and post
by nwjones18 - 03/29/20 11:49 AM
Oups, forgot oil cap...
by M119 - 03/29/20 11:46 AM
Recommendation for tuned BMW N55?
by RIPGermanCastrol - 03/29/20 11:15 AM
Electrician's Help With Circuit Breaker ?
by doitmyself - 03/29/20 11:07 AM
Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
89 registered members (01rangerxl, 007, 2K2AcuraTL, 762fermeandyou, 53' Stude, 2015_PSD, 9 invisible), 2,128 guests, and 20 spiders.
Topics303,322
Posts5,233,905
Members71,038
Gas dryer question #5380642 03/19/20 06:41 PM
J
jayjr1105 Offline OP
J
I bought a second hand gas dryer from a friend several years ago because he moved to an area with no natural gas. It's motor is starting to sound like it's struggling a bit. It's a noticeable change in the sound it makes when you start it up. Are the motors worth replacing in these things? I usually don't mess around with gas but since the motor is just 120v electric, I wouldn't be afraid to replace that.
Dryer is a GE® Extra-Large 6.0 Cu. Ft. Capacity Gas Dryer
DCXR463GA0WW
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Gas dryer question [Re: jayjr1105] #5380646 03/19/20 06:45 PM
M
mk378 Offline
M
The belt and the drum rollers are the parts that wear out. Almost every washer or drier goes to the scrap heap with a good motor.
Re: Gas dryer question [Re: mk378] #5380647 03/19/20 06:48 PM
J
J
Well that's good since the motor's cost more than what the dryer is worth. I assume the belt and rollers are A) cheaper and B) easier to replace? I'm seeing gas dryers on craigslist for $100 maybe 5 years old. Am I better off that route?
Re: Gas dryer question [Re: jayjr1105] #5380651 03/19/20 06:50 PM
J
JohnG Offline
J
The other thing to check is the starting capacitor, if it has one. Some motors do, actually most do, inside the rear end frame. If that goes bad, startup will be terrible.
Check motor bearings too while it's out, but that noise would be continuous when running.
Re: Gas dryer question [Re: JohnG] #5380654 03/19/20 06:55 PM
J
J
The sound is continuous. It just doesn't sound like it did in the past. I see from a couple youtube video's that pulling the drum out is rather easy, What should I inspect other than the belt and pulley?
Re: Gas dryer question [Re: jayjr1105] #5380667 03/19/20 07:14 PM
J
JLawrence08648 Offline
J
Belt and rollers are $25.
2019 Hyundai Santa Fe SEL Plus, 2.4
1992 Acura Vigor, 2.5 GS
Re: Gas dryer question [Re: jayjr1105] #5380699 03/19/20 07:58 PM
J
john_pifer Offline
J
How does a gas-powered dryer work?
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 225K
18 Civic HB 1.5T 6MT (Fiancee's) - VME 0W-20, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: Gas dryer question [Re: jayjr1105] #5380711 03/19/20 08:10 PM
J
JohnG Offline
J
[quote]How does a gas-powered dryer work?/quote]
It just uses a gas burner for the heat instead of electricity.
Re: Gas dryer question [Re: jayjr1105] #5380716 03/19/20 08:20 PM
KeithS_NW_Ohio Offline
Remove the belt and see how it sounds
2012 Ford Fusion - Mobil 1 0W-20EP/HM
2005 Nissan Altima - Mobil 1 0W-30AFE
Mine to Maintain
2018 Jeep� Compass - Mobil 1 0W-20EP
Re: Gas dryer question [Re: JohnG] #5380755 03/19/20 09:11 PM
L
Leo99 Online Content
Online Content
L
Yes, it's not natural gas powered. It's natural gas heated. Dryers are pretty simple.
Make sure the lint is all cleaned out of the air outputs and inside the dryer. They sell special brushes for this.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: Gas dryer question [Re: jayjr1105] #5380760 03/19/20 09:15 PM
Dinoburner Offline
The motors in dryers-gas or electric have a start winding operated through a centrifugal switch. The contacts could be worn or dirty. BTW the only difference between gas or electric dryers is a heating element or gas burner. All controls are the same.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Gas dryer question [Re: Dinoburner] #5380787 03/19/20 10:03 PM
Donald Offline
Except in an electric dryer its all 220V. Gas its 110V. Given that the cord for many electric dryers is 2 hot + ground there should not be anything 110V in an electric dryer (since no neutral).
2015 Ford F-250 w/Powerstroke
Re: Gas dryer question [Re: jayjr1105] #5380791 03/19/20 10:17 PM
J
john_pifer Offline
J
Oh, so it still has an electric motor to turn the drum? I gotcha. I've never seen one and I was thinking it was totally gas-powered.
Re: Gas dryer question [Re: jayjr1105] #5381012 03/20/20 08:10 AM
J
J
We'll see how bored I get this weekend. I might dissect it and clean things up while inspecting the belt and rollers.
Re: Gas dryer question [Re: jayjr1105] #5381168 03/20/20 11:13 AM
J
J
Is this my problem?
[Linked Image]
[Linked Image]
