Crawfish, It's A Louisiana Thang!
by BlueOvalFitter - 04/07/20 01:01 AM
M&P .40 Magazines $12.99
by BlueOvalFitter - 04/06/20 11:30 PM
Lots of Big Sur pics, only one of the car :-)
by SLO_Town - 04/06/20 09:24 PM
'16 Pilot Inline ATF filter
by parshisa - 04/06/20 08:55 PM
2019 Ram 1500 Classic
by Skippy722 - 04/06/20 08:53 PM
STP S3614 XL CUT OPEN
by 53' Stude - 04/06/20 07:15 PM
Kia Rio awful sound after sitting 5 years
by antonmnster - 04/06/20 07:13 PM
Cut open Motorcraft FL820S
by PantherFan88 - 04/06/20 06:38 PM
240V Electric Hookup Questions
by 92saturnsl2 - 04/06/20 06:33 PM
license plate frame with 3rd brake light
by wings&wheels - 04/06/20 06:12 PM
Wurth HHS 2000
by ejt - 04/06/20 06:06 PM
Snapper drive belt install trouble LT300
by spk2000 - 04/06/20 05:56 PM
installing garage LED shop light help needed
by FirstNissan - 04/06/20 05:20 PM
Casite filters
by opus - 04/06/20 05:16 PM
Oil for Jeep
by rokwldr - 04/06/20 05:12 PM
Kitchen sink faucet leak help
by 97prizm - 04/06/20 04:45 PM
RIP Al Kaline.
by PimTac - 04/06/20 04:36 PM
Frankentruck power steering question
by Thomcat316 - 04/06/20 04:11 PM
Comment from Miata track on Amsoil GL-4
by Bill_W - 04/06/20 03:28 PM
Help choose a Nissan
by lealedwin485 - 04/06/20 02:31 PM
BludRacing, Cacciatore, Thomcat316, NTexian, LateLifeCrisis
71116 Registered Users
31 registered members (cabriopeugeot, carlprop, blufeb95, 69GTX, BlueOvalFitter, Ded Mazai, 3 invisible), 1,375 guests, and 22 spiders.
Topics303,698
Posts5,240,208
Members71,116
Looking for Decent 7500-1K watt generator #5380612 03/19/20 06:00 PM
9
92saturnsl2 Offline OP
9
I've been wanting to pick up a generator for some time now, figured now is a better time than ever to up the ante on preparedness. It's not a panic buy by any means, this was a planned purchase that I've just been putting off too long. We live in a rural area and springtime leaves lots of surprises some years during storm season.
I need something big enough to run most of the household essentials-- I'm thinking >7500 watts would be ideal. Harbor Frieght has a 7500W (9000-something peak) model for about $600 that would fit the bill nicely, but they're out of stock. I have no qualms with Harbor Freight stuff and their Predator line has great reviews. But I wouldn't mind spending a bit more money on something with a volt/hz meter, and I prefer something dual fuel capable (gas/ propane), but it's not a requirement. I don't recongnize many of the brands I'm seeing on Amazon. Rainier is a name I see a lot of, but know nothing about them. Wondering if you guys have any suggestions. Looking to spend less than $1,000, but the best value per $$$ spent is what I'm ultimately after. Thanks in advance for any input.
96 Grand Prix SE (project car)
04 Odyssey EX 205k Shell Rotella T5 10w-30
96 Maxima GLE 275k Mobil Super HM 5w-30
07 Chrysler Pacifica Limited 4.0L 151k Mobil1 EP 0w-20
Re: Looking for Decent 7500-1K watt generator [Re: 92saturnsl2] #5380620 03/19/20 06:11 PM
cronk Offline
Champion Power Equipment makes good stuff and priced only a little more than Harbor Freight. 3 year warranty and they do make several models that are dual fuel gas/propane.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Looking for Decent 7500-1K watt generator [Re: 92saturnsl2] #5380621 03/19/20 06:12 PM
Cujet Offline
https://www.northerntool.com/shop/tools/product_200467366_200467366
Champion makes good generators. The Northern Tool unit I linked above is also a good unit. The Honda 390 engine is quite good.
Re: Looking for Decent 7500-1K watt generator [Re: 92saturnsl2] #5380659 03/19/20 07:03 PM
E
eljefino Offline
E
At that level of power use, a 20 lb propane tank/ regulator won't keep up. Just FYI.
Re: Looking for Decent 7500-1K watt generator [Re: 92saturnsl2] #5380729 03/19/20 08:36 PM
R
Rand Offline
R
just remember the bigger the unit the less efficient.
its more efficient to run a 2000w generator with a 1000w load than a 8000w unit.
inverter type gives a pretty massive fuel savings if you have low and variable loads.
typically they also produce much cleaner power if you are trying to power electronics.
Also it gets very old refueling them 2+ times a day. and changing the oil every 5 days.
So consider units that have ease of refueling and changing oil if you will be using it extensively.
You will also need an interlock on your electrical panel so you can use it to power your house(or some of your house)
Re: Looking for Decent 7500-1K watt generator [Re: eljefino] #5380743 03/19/20 08:48 PM
spasm3 Offline
Will be hard to store enough for that size unit, propane or gasoline. If you buy a generator that size, also have a smaller one. I have 2. I have a 8-10k generator that burns 1 to 1.25 of gasoline gallons an hour. I have the HF 4375 unit, that one burns about 1/4 that.
24hr run= 24-26 gallons gasoline for the big one, or 6 gallons gasoline for the little one. Both have 240v outlets.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Looking for Decent 7500-1K watt generator [Re: spasm3] #5380761 03/19/20 09:16 PM
cpayne5 Offline
I also have two. The big one is 7500w, which powers the well pump and hot water heater. I fire it up when I need those larger devices.
I have a 3000w unit that sips gas that I use to power the fridge, freezer, and lights when the bigger one isn't necessary.
Re: Looking for Decent 7500-1K watt generator [Re: 92saturnsl2] #5380859 03/20/20 02:11 AM
L
LC Offline
L
Here is one to look at the fits your needs. https://www.newegg.com/pulsar-g12kb...A08C88W7564-_-Product&quicklink=true
I own this one https://www.menards.com/main/outdoo.../10000003560/p-1444431294885-c-10107.htm
Not duel fuel but works great and powers everything in our home. We have had to run it a number of times over the past couple years. Tank of fuel will last you 6 to 8 hours depending on load.
09 CVO SE Road Glide
00 TW 200
12 Jeep Wrangler Unlimited 3.6 100,000> miles
17.5 Gen2 Jeep Compass Traihawk 2.4 80,000> miles
SRGT/PP/PU oil
Re: Looking for Decent 7500-1K watt generator [Re: 92saturnsl2] #5380866 03/20/20 03:45 AM
O
OilReport99 Offline
O
I own this China CAT. Not dual fuel, but it's been great so far.
https://apelectric.com/cat-rp7500e-7500w-electric-start-portable-generator/
Re: Looking for Decent 7500-1K watt generator [Re: 92saturnsl2] #5381472 03/20/20 05:31 PM
A
Astro_Guy Offline
A
Could you clarify why you think you need such a large unit? I have a Champion 3500 watt generator that runs my two refrigerators and a chest freezer, plus the dishwasher on a heated dry cycle. I also run a line over to the neighbor's house for their refrigerator during an extended outage. I also have a Harbor Freight Preadtor 3500 Inverter that has run all of the above, minus the neighbor.
Re: Looking for Decent 7500-1K watt generator [Re: Astro_Guy] #5381529 03/20/20 06:32 PM
9
9
Ultimately I'd like to get a transfer switch for the house, and the hope is that a larger unit can run the electric heat pump / AC unit, along with the other essentials like fridge, freezers and such. I also need it to run a decent size 240V single phase welder (obviously not at the same time as the house.)
After doing some math given the size of the heat pump, I'm probably better off with a 9500W unit if I'm to have a little spare capacity. The 7500W and 9500W units use the same 400-450cc (depending on brand) engine, so the fuel consumption shouldn't be all that different with equivalent loads.
This one seems like a good candidate for the money and has good reviews.
The suggestion to also buy a smaller generator is a good one. I will probably pick up a 2k inverter at some point that can run the fridge/freezer for long periods for when gas is scarce. I've been wanting to get one for camping anyways.
Re: Looking for Decent 7500-1K watt generator [Re: 92saturnsl2] #5381549 03/20/20 06:57 PM
A
Astro_Guy Offline
A
If the money doesn't enter into the equation, have a look at http://www.centralmainediesel.com/order/KB900.asp?page=KB900
'01 Volvo V70XC, 252k, 5W-30 M1 EP
'16 Accord, 50k, 0W-20 M1 EP
Re: Looking for Decent 7500-1K watt generator [Re: 92saturnsl2] #5381564 03/20/20 07:11 PM
spasm3 Offline
The running watts is not the issue, its the start up amperage. I have a 8k 10k surge generator with an 18hp vangard engine. It will not start up my 4 ton a/c unit, granted its 15 years or so old.
I run the well pump and furnace with an HF 4375 , i stagger the well pump and furnace. It also runs 2 fridges, and lights and a 50 inch plasma tv. Again i leave the well pump off. When i need to wash dishes or charge the toilets back up, i turn off the furnace for a short bit while i cycle the well pump.
If i need to run the cook top oven or clothes washer/dryer, i crank up the big one for an hour so so to do that with the gas furnace and well pump running. Then go back to the small one. much less fuel usage.
Re: Looking for Decent 7500-1K watt generator [Re: 92saturnsl2] #5381805 03/21/20 06:29 AM
H
hatt Offline
H
Running the A/C isn't a necessity. If you want to run everything you need to get a whole house setup and a big LP gas tank. If all you have is a heat pump for heat need you need supplemental heat like a kerosene heater. I'd be looking at a much smaller gen. If you have a well you need something that will run that of course.
My 2000 Champion runs my essential stuff. It's also handy enough that you can use it for other things and it doesn't get stuck under a tarp for years.
2013 F150 5.0, Delo 400 XSP 5W-40, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Looking for Decent 7500-1K watt generator [Re: 92saturnsl2] #5390442 03/31/20 07:49 PM
9
9
After a lot of internet research, I came away with the impression that most generators intended for home use are all foreign-made (with Chonda engines) of comparable quality for a given price point. I didn't see any evidence that one brand of X price was better than the other brand at X price, at least not reflected in the reviews. Even the name brand stuff is foreign made and my suspicion is that it comes out of the same factory / supply chain as the lesser known brands. I notice if you try to cheap out too much, that's where the bad reviews start rearing their ugly head.
In the end I went with this one:
https://www.amazon.com/Westinghouse...Watts-Gas-Powered-Electric/dp/B07Q1DLKBG
It simply had the most features for the price, good reviews and the output was on the higher side of what I wanted. Going higher in output above 9500W or so, you start stepping into twin cylinder engines and a huge price hike to go along with it. Unit seems well built and there's a lot of attention to detail, wire ties, rubber cushioning for wires, etc. I ran it for a couple hours with about a 3kw load and the thing purrs like a kitten. After it broke in a while, I tried 6.5kw and it runs fine on a standard 20# propane tank. Much quieter than I was expecting; I figured a 457cc single cylinder engine would scream like a banshee at 3600rpm, but it has a smooth low-pitch sound that is not overwhelming. I'd have no problem running it constantly during a power outage without upsetting the neighbors.
The wife liked the remote keyfob start feature, though you do have to go out and switch the main power switch on--- once that's done you can start/stop the generator inside the house with the press of a button. Hope the electronic gizmos that work the push button and remote start hold up, that was my only qualm, but the unit does have a backup pull start and has a 3 year warranty with 24/7 support.
