KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
MC FL500S 7,000 miles CUT OPEN
by 53' Stude - 04/03/20 03:43 PM
USS Theodore Roosevelt
by BMWTurboDzl - 04/03/20 03:42 PM
2020 Subaru Forester Base
by wagsrk08 - 04/03/20 03:41 PM
New Rislone Hy-per Fuel Product?
by Jackson_Slugger - 04/03/20 03:38 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
52 registered members (Alaskanmont, bernau, Blurider24, blufeb95, bronx, 7 invisible), 1,659 guests, and 19 spiders.
Topics303,554
Posts5,237,342
Members71,086
Memory upgrade goes horribly wrong #5380568 03/19/20 04:53 PM
T
tillnova Offline OP
T
I have HP Pavilion dv6-21 Intel Core i3 CPU M 330 2.13GHz with 2x2GB RAM, my laptop supports up to 8GB upgrade. I needed upgrade and I went to Crucial website and their analytics showed compatible memory Crucial 8GB Kit (2 x 4GB) DDR3L-1600 SODIMM. Since it was out of stock I find Kinston SODIMM DDR3L 1600 4GB so the same specific just different manufacturer.
After installation I got blue screen 'Your PC run into problemm and needs to restart', after that black screen 'Preparing Automatic Repair' and it just keeps going like that in circle.
When I click ESC and enter into Startup, in BIOS it shows 8GB memory and after running a memory test it shows 'memory test pass' so that means that there is nothing wrong with the memory.
I tried putting just 1 stick, replacing their position but always the same.
Could someone please tell me can I use this memory at all or is there any additional tweak that I shoud take in resolving this matter.
Thanks!
Re: Memory upgrade goes horribly wrong [Re: tillnova] #5380570 03/19/20 04:55 PM
O
OVERKILL Offline
O
When you say you ran a memory test, did you run something like Memtest86? Because that's what you need to use. The Windows test is garbage.
Re: Memory upgrade goes horribly wrong [Re: tillnova] #5380583 03/19/20 05:17 PM
P
Pew Offline
P
Did you switch back to the old RAM to see if they're still working?
Re: Memory upgrade goes horribly wrong [Re: tillnova] #5380588 03/19/20 05:21 PM
stockrex Offline
put one stick each of the new one in bank0 and reboot and see if windows boots, this is after you reboot with old ram and confirm everything is good.
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: Memory upgrade goes horribly wrong [Re: tillnova] #5380590 03/19/20 05:24 PM
K
Kawiguy454 Offline
K
You tried using only one stick. did you try both sticks in this singular way. One of them could be culprit. Look for a legit DL of "Ultimate Boot CD" it has memtest on it you can boot from thumb drive. crosscheck the memory using the Kingston tool and see if it agrees the memory is compatible. https://www.ultimatebootcd.com/
Re: Memory upgrade goes horribly wrong [Re: tillnova] #5380592 03/19/20 05:29 PM
O
OVERKILL Offline
O
Just an FYI, but I have recently experienced something remarkably similar on an ASUS motherboard based desktop here. It had 2x2GB DDR3 1600 sticks in it and I replaced them with 2x 4GB 1600 sticks and it behaved just as you described. This was a machine I was going over and I couldn't even get it to finish booting the Windows 10 image, it kept crashing. It had 4x slots, I tried each stick individually in all 4x slots, the sticks were known-good, but the behaviour persisted. I swapped back in the 2x 2GB sticks, it booted no problem. I found 2x more 2GB sticks to bump it up to 8GB (all 4x slots populated) and it worked fine. I'm guessing the higher density 4GB sticks posed a compatibility issue, despite allowing the system to post. I've had a similar issue in the past with single-sided 2GB sticks in a board that when developed, 2GB sticks were lower density double-sided.
It may be that the sticks Crucial recommended were of a different density.
Re: Memory upgrade goes horribly wrong [Re: tillnova] #5380628 03/19/20 06:29 PM
J
JMJNet Offline
J
You need DDR3 NOT DDR3L?
Try to find DDR3 without the L.
DDR3 without the L is an older higher voltage memory module.
For most cases, they are not interchangeable.
Based on reading the spec you link in the original post.
  • 2017 Toyota Sienna
Re: Memory upgrade goes horribly wrong [Re: JMJNet] #5380636 03/19/20 06:38 PM
P
Pew Offline
P
I think you're right. The I3-330M doesn't take DDR3L according to their site
Re: Memory upgrade goes horribly wrong [Re: tillnova] #5380732 03/19/20 08:38 PM
R
Rand Offline
R
yep ddr3L 1600 in a 2010 laptop that has 1066mhz ddr3
nice catch.
or it might be some kind of memory incompatibility as Overkill explained.
a clue to this is the motherboard only supports 8GB max
I had that issue in ancient times (about 15 years ago is ancient for computers)
Re: Memory upgrade goes horribly wrong [Re: JMJNet] #5380754 03/19/20 09:02 PM
O
OVERKILL Offline
O
I think you might be bang-on the money here. He only provided a fragment of the model # in the OP, and if you use the Crucial tool and just snag one from the list that comes up you end up with the memory he chose:
[Linked Image]
However, if you go to the Kingston site and find the one with the matching CPU that he listed:
[Linked Image]
The memory recommendations are quite different (note they are all discontinued LOL )
[Linked Image]
So yeah, he needs the non low voltage part # here as you've surmised.
Re: Memory upgrade goes horribly wrong [Re: tillnova] #5380774 03/19/20 09:32 PM
J
JMJNet Offline
J
OP needs to buy from Ebay or Amazon marketplace if somebody happen to sell it used.
Other source will be Craigslist.
Please be careful to read the description not just the title on ebay.
It needs to be WITHOUT "L" or PC3 WITHOUT "L".
I don't think Crucial site sells DDR3 without "L" anymore.
It is 2 generation behind.
Latest and greatest being DDR4 and before that is DDR3L.
Re: Memory upgrade goes horribly wrong [Re: JMJNet] #5380794 03/19/20 10:31 PM
E
edhackett Offline
E
Amazon has suitable memory from several brands, Corsair, OWC, TIMETEC Hynix being the best options. It was used in the Macbooks of that era. As I recall mac certified memory guaranteed proper performance.
Here's an example: Corsair DDR3 1066
Ed
Never attribute to engineers that into which politicians, lawyers, accountants, and marketeers have poked their fingers.
Re: Memory upgrade goes horribly wrong [Re: tillnova] #5380819 03/19/20 11:48 PM
G
Gokhan Offline
G
Thanks!
For memory upgrades I always buy cheap used memory from eBay.
Your problem has nothing to do with the memory. If it were, your computer would never boot, meaning it would never get past the BIOS load.
Blue screen means your operating system is corrupted. Download the Windows operating system on a DVD or a flash drive using another PC and then do a system reinstall with it. Do an upgrade -- not a fresh reinstall -- so that you don't lose your data.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 70 mpg on gas, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Memory upgrade goes horribly wrong [Re: Gokhan] #5380830 03/20/20 12:22 AM
Skippy722 Offline
Thanks!
Not necessarily. My brother picked up a new laptop a few years ago, it would run fine until you started trying to game on it, or opened 1 too many tabs in Chrome. Turns out 1 of the 2 4gb sticks was bad, had some obscene amount of errors when tested with Memtest.
Bought new sticks and it never had another BSOD.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Memory upgrade goes horribly wrong [Re: tillnova] #5380852 03/20/20 01:21 AM
G
Gokhan Offline
G
That's easy to test -- simply put the old memory back and see if everything goes back to normal.
