VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 04/01/20 02:41 PM
NEW Adam's Polishes - Hand Sanitizer
by SavagePatch - 04/01/20 02:40 PM
Home vehicle modification fails
by IMSA_Racing_Fan - 04/01/20 01:57 PM
Internet speeds in current climate.
by sloinker - 04/01/20 01:55 PM
concrete work while at home
by spasm3 - 04/01/20 01:19 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
111 registered members (53' Stude, Alfred_B, Al, 2010Civic, 2009Edge, 12 invisible), 1,942 guests, and 24 spiders.
Topics303,445
Posts5,235,415
Members71,072
Are older R12 a/c systems better sealed than newer 134 units? #5380547 03/19/20 04:23 PM
A
atikovi Offline OP
A
Two examples I'm working with. 1) 2001 Escort not used since 2017. A/C not working and gauges show zero pressure. Did the 15 minutes on a vacuum pump followed by 15 minutes rest. Vacuum held steady so no obvious leaks. Assume seals just shrunk from inactivity and will be ok after some use. 2) 1988 motorhome not used since 2011. Never imagined the A/C would work after sitting that long, but a few days ago I hit the A/C button and the compressor engaged, noisily for a little bit, but the air blew cold. Far as I can tell it's still on R12. Do these old systems hold a charge better?
Re: Are older R12 a/c systems better sealed than newer 134 units? [Re: atikovi] #5380557 03/19/20 04:38 PM
skyactiv Offline
R134;isnsealed better, but R12 molocules are bigger and don't perminate/leak as easy
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Are older R12 a/c systems better sealed than newer 134 units? [Re: atikovi] #5380562 03/19/20 04:45 PM
Chris142 Online Content
Online Content
Yes the R12 systems did not leak as badly as the R134a systems do.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Are older R12 a/c systems better sealed than newer 134 units? [Re: atikovi] #5380576 03/19/20 05:08 PM
M
MCompact Online Content
Online Content
M
I'm going on 25 years on the R134a system on my Club Sport; it's never lost any R134a.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: Are older R12 a/c systems better sealed than newer 134 units? [Re: atikovi] #5380578 03/19/20 05:11 PM
G
GoldDot40 Offline
G
When R134 came on the scene, a lot of people were installing the "R12 to R134 conversion kits" sold at nearly any parts store. As previously mentioned, the R134 molecules are smaller and the refrigerant would literally seep through the hose linings on a R12 system.
Equal Opportunity Offender
Re: Are older R12 a/c systems better sealed than newer 134 units? [Re: atikovi] #5380656 03/19/20 06:58 PM
J
junk1020 Offline
J
From what we're being told, this may be one of the benefits of the switch to R1234yf, as it is going back to a larger molecule again. Sadly, it costs like 5 times what R134a does.
2011 Hyundai Sonata, Castrol Edge 0w40, Hastings LF565
2017 Toyota Sienna, Castrol Edge 0w20, Hastings LF607
2018 Hyundai Sonata, Mobil 1 5w30, Hastings LF565
Re: Are older R12 a/c systems better sealed than newer 134 units? [Re: atikovi] #5380772 03/19/20 09:30 PM
slacktide_bitog Offline
What everyone else said, the R134a molecules are smaller than R12 molecules, hence more seepage
In fact, some A/C leak detection dyes have larger molecules than the 134a itself, so it's possible to have a leak that the dye can't detect crzy
Re: Are older R12 a/c systems better sealed than newer 134 units? [Re: atikovi] #5380784 03/19/20 09:57 PM
B
brages Online Content
Online Content
B
Did the Escort work in 2017, though? 🤔
Re: Are older R12 a/c systems better sealed than newer 134 units? [Re: atikovi] #5380931 03/20/20 06:55 AM
A
atikovi Offline OP
A
Don't think I ever checked.
Re: Are older R12 a/c systems better sealed than newer 134 units? [Re: atikovi] #5380986 03/20/20 07:49 AM
B
Online Content
B
It may not help you, but I have a 97 Ranger and the compressor leaked at the shaft seal. I got a kit online and resealed it for fairly cheap. Not that tough of a job.
Re: Are older R12 a/c systems better sealed than newer 134 units? [Re: atikovi] #5380987 03/20/20 07:49 AM
M
mk378 Online Content
Online Content
M
At the compressor outlet, 134a runs hotter and that tends to harden the o rings in the line from the compressor to the condenser. Those are a common place to leak in both systems but it may be worse with 134a.
Re: Are older R12 a/c systems better sealed than newer 134 units? [Re: atikovi] #5381052 03/20/20 08:49 AM
Schmoe Offline
Pressure difference. 134a operates at a much higher pressure.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
2018 CRV EX-L
2017 Accord Coupe V6 EX-L 6AT
Re: Are older R12 a/c systems better sealed than newer 134 units? [Re: atikovi] #5381609 03/20/20 07:55 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
R134 uses better hoses and o rings. But is a smaller molecule at higher pressure.
I have three r-12 systems, one leaks and the others are tight.
They said it was important to run your ac in r-12 systems so the oil could coat the lines. I do that.
Re: Are older R12 a/c systems better sealed than newer 134 units? [Re: atikovi] #5381754 03/21/20 01:01 AM
J
john_pifer Offline
J
I dunno about being sealed better, but those old R12 systems sure did blow colder, faster!
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 225K
18 Civic HB 1.5T 6MT (Fiancee's) - VME 0W-20, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: Are older R12 a/c systems better sealed than newer 134 units? [Re: john_pifer] #5382048 03/21/20 11:28 AM
another Todd Offline
I agree. I think R-12 leaked more, unless you converted to R134 and left the R12 hoses---that leaked a lot. Newer vehicles designed for R134 have different hoses that contain the smaller molecules that the R12 hoses could not. In my experience most R134 systems will run on factory fill until a part fails with no leakage, whereas most R12 systems needed a top off every few years.
2017 Ford Escape 2.0
2002 GMC Yukon
2008 Yamaha Rhino 700 FI
2010 Itasca Meridain/Freightliner Cummins 6.7 non DEF
