Broken sway bar bolt
by HoosierJeeper - 03/29/20 04:00 PM
can I use it?
by avi1777 - 03/29/20 03:54 PM
Service Champ OF2222 75% OLM, unknown miles
by bullwinkle - 03/29/20 03:50 PM
Gas Buddy Question
by Wolfshead - 03/29/20 03:30 PM
Caliper piston boot
by painfx - 03/29/20 03:25 PM
Graphene the next detailing protection
by Mamala Bay - 03/29/20 02:17 PM
Anyone here a blacksmith?
by 53' Stude - 03/29/20 02:13 PM
Buying products made outside the USA
by 007 - 03/29/20 01:22 PM
Marine oils on sale at Canadian Tire
by Snagglefoot - 03/29/20 12:42 PM
0W16 instead of 0w20?
by Mter00s - 03/29/20 12:36 PM
XG10575 Walmart.com deal
by 762fermeandyou - 03/29/20 12:29 PM
Virgin ACDelco PF1245 cut and post
by nwjones18 - 03/29/20 11:49 AM
Oups, forgot oil cap...
by M119 - 03/29/20 11:46 AM
Recommendation for tuned BMW N55?
by RIPGermanCastrol - 03/29/20 11:15 AM
Electrician's Help With Circuit Breaker ?
by doitmyself - 03/29/20 11:07 AM
Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
98 registered members (01rangerxl, antone, 007, 2K2AcuraTL, 762fermeandyou, 53' Stude, 11 invisible), 2,118 guests, and 21 spiders.
Topics303,322
Posts5,233,905
Members71,038
Can't remove old banjo bolt from fitting! #5380509 03/19/20 03:43 PM
dwcopple Offline OP
Got the line off the caliper okay but the bolt is being held to the hose fitting by what appears to be too small of a copper washer. I've stopped the leak by doubling the inside washer for now. Am I screwed and need to replace the brake hose now?
2017 RAM Big Horn 4x4 3.6L V6
2011 Chrysler 200 Limited 3.6L V6
Re: Can't remove old banjo bolt from fitting! [Re: dwcopple] #5380526 03/19/20 03:58 PM
A
atikovi Offline
A
Why not just get the correct washer?
Re: Can't remove old banjo bolt from fitting! [Re: dwcopple] #5380527 03/19/20 04:00 PM
V
vavavroom Offline
V
Can't you grab the washer with pointy locking pliers and twist it back and forth until it breaks and comes out? Then remove the bolt and install a new crush washer.
Re: Can't remove old banjo bolt from fitting! [Re: dwcopple] #5380550 03/19/20 04:27 PM
M
mk378 Offline
M
If the threads are caught in the washer, grab the outside edge of the washer with pliers and unscrew the bolt out. Never double-washer. And not so tight next time.
Re: Can't remove old banjo bolt from fitting! [Re: dwcopple] #5380552 03/19/20 04:27 PM
Dadillac Offline
Brake hoses are pretty cheap. Why bother
Don
Re: Can't remove old banjo bolt from fitting! [Re: mk378] #5380573 03/19/20 04:59 PM
dwcopple Offline OP
I didn't make it tight. The double washer is a stop-gap for the time being...I'll try gripping the washer edge and unscrewing but my Hopes aren't high
