Differential Gear Oil Mixture ( Will it destroy my diffs)
Malaysia
Long story short, I have a Toyota Hilux and went to have a diff oil change. I brought toyota fluids which called for 85w-90 for front and 85w-90 LSD for the rear. The swines ended up mixing their drum of Castrol 80w-90 with the toyota 85w-90 for the front and mixing Castrol SAE90 LSD with the toyota 85w-90 LSD. I live in a hot tropical climate. Will this mixture cause any damage or I can wait until the next change? Thanks!
And in addition, as long as both/all gear oils are the proper GL formulation and LSD where applicable, all should be good to go for the whole duration of this drain & refill.
Go ask the swines, as you called them.
What do you mean "mixing"? Did they completely drain both diffs and then replace with the Castrol? I am assuming that is what happened.
I agree with Char Baby in that if the Castrol meet the specs then the Castrol should be fine.
Were these guys that did the changing Toyota employees? The reason I ask is most dealerships where I live use Castrol or Pennzoil as their gear lubes. Non synthetic of course.
They use Toyota ATF and coolant.
It is an independent shop. I brought the toyota oem gear oil ( no idea what company makes them over here) and the shop has existing drum of castrol gear oils. They pour the toyota bottles that I brought into their drum of castrol oil, essentially mixing them and putting it into the diffs.
When I do a LOF on a customers car or truck I often add gear oil to the differential. I have no clue what brand is in it already. I just top it off with what the manufacturer calls for.
So you got a little bit of every other customer-supplied gear lube too if that was the case. I'd ask for a full refund since you're out the cash of your gear lube, and then have it done at someplace reputable.
Thanks! The fluids that I brought and the castrol are both GL-5 and the rear both have LSD. So I be good until the next change of 4 years/ 40000km.
Their drum has a pump for filling diffs and gearboxes, to use your oil they would have to use a hand sludge pump...messy and time consuming. I don't blame them, and you got good oil anyway.
