Applications for a new job
by 97prizm - 03/28/20 02:55 AM
Petro Canada 20L bucket
by MalteseFalcon - 03/27/20 11:34 PM
Toolbox corrosion protection
by buck91 - 03/27/20 09:39 PM
Milwaukee 2767-20 Impact Wrench
by Wolf359 - 03/27/20 09:38 PM
Economic choices?
by buck91 - 03/27/20 09:33 PM
Stripped Bolt...best extractor set?
by TXCarGeek - 03/27/20 09:27 PM
HF Charger barely lasted a year
by jayjr1105 - 03/27/20 08:52 PM
My dog is not doing well.
by Chris142 - 03/27/20 08:40 PM
head rest stain. how to get out
by WhyMe - 03/27/20 07:50 PM
Heavy fuel oil: can we talk about it?
by 53' Stude - 03/27/20 07:35 PM
ramping up production of something
by andyd - 03/27/20 07:29 PM
Who waits for the RPMs to settle before ...?
by TXCarGeek - 03/27/20 06:45 PM
Signed up for Instacart
by 14Accent - 03/27/20 05:53 PM
Future Toyota Vehicle Line-Up
by The Critic - 03/27/20 04:45 PM
Brake Shoes cleaned after soaked in brake fluid?
by Cressida - 03/27/20 04:34 PM
bdowning, OliverQ50, NorCalHD, narelikg, Rhino2278
71032 Registered Users
15 registered members (GMguy84, Aries, Falcon_LS, bachman, anndel, FordCapriDriver), 506 guests, and 17 spiders.
Topics303,255
Posts5,232,688
Members71,032
Differential Gear Oil Mixture ( Will it destroy my diffs) #5379989 03/19/20 01:40 AM
SilentForever05 Offline OP
Long story short, I have a Toyota Hilux and went to have a diff oil change. I brought toyota fluids which called for 85w-90 for front and 85w-90 LSD for the rear. The swines ended up mixing their drum of Castrol 80w-90 with the toyota 85w-90 for the front and mixing Castrol SAE90 LSD with the toyota 85w-90 LSD. I live in a hot tropical climate. Will this mixture cause any damage or I can wait until the next change? Thanks!
Re: Differential Gear Oil Mixture ( Will it destroy my diffs) [Re: SilentForever05] #5379996 03/19/20 02:28 AM
Char Baby Offline
Personally, I believe you'll be just fine.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Differential Gear Oil Mixture ( Will it destroy my diffs) [Re: SilentForever05] #5379999 03/19/20 03:02 AM
Char Baby Offline
And in addition, as long as both/all gear oils are the proper GL formulation and LSD where applicable, all should be good to go for the whole duration of this drain & refill.
Re: Differential Gear Oil Mixture ( Will it destroy my diffs) [Re: SilentForever05] #5380013 03/19/20 04:19 AM
T
tcp71 Offline
T
It’s fine as long as the LSD clutches have their friction modifier.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Differential Gear Oil Mixture ( Will it destroy my diffs) [Re: SilentForever05] #5380023 03/19/20 05:13 AM
F
FordCapriDriver Online Content
Online Content
F
I think you will be just fne
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Whatever keeps the lifters quiet...
Re: Differential Gear Oil Mixture ( Will it destroy my diffs) [Re: SilentForever05] #5380086 03/19/20 07:27 AM
L
Lubener Offline
L
Go ask the swines, as you called them.
The "thinking" man's friend.
Re: Differential Gear Oil Mixture ( Will it destroy my diffs) [Re: SilentForever05] #5380122 03/19/20 08:00 AM
G
Gebo Offline
G
What do you mean "mixing"? Did they completely drain both diffs and then replace with the Castrol? I am assuming that is what happened.
I agree with Char Baby in that if the Castrol meet the specs then the Castrol should be fine.
Were these guys that did the changing Toyota employees? The reason I ask is most dealerships where I live use Castrol or Pennzoil as their gear lubes. Non synthetic of course.
They use Toyota ATF and coolant.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Differential Gear Oil Mixture ( Will it destroy my diffs) [Re: Gebo] #5380148 03/19/20 08:30 AM
It is an independent shop. I brought the toyota oem gear oil ( no idea what company makes them over here) and the shop has existing drum of castrol gear oils. They pour the toyota bottles that I brought into their drum of castrol oil, essentially mixing them and putting it into the diffs.
Re: Differential Gear Oil Mixture ( Will it destroy my diffs) [Re: SilentForever05] #5380159 03/19/20 08:43 AM
A
andyd Offline
A
I would add friction modifier to LSD diff in rear. Open front will be fine
Thick oil is better grin2
Re: Differential Gear Oil Mixture ( Will it destroy my diffs) [Re: SilentForever05] #5380190 03/19/20 09:22 AM
Chris142 Offline
When I do a LOF on a customers car or truck I often add gear oil to the differential. I have no clue what brand is in it already. I just top it off with what the manufacturer calls for.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Differential Gear Oil Mixture ( Will it destroy my diffs) [Re: SilentForever05] #5380431 03/19/20 01:51 PM
SubieRubyRoo Offline
So you got a little bit of every other customer-supplied gear lube too if that was the case. I'd ask for a full refund since you're out the cash of your gear lube, and then have it done at someplace reputable.
De omnibus dubitandum.
Re: Differential Gear Oil Mixture ( Will it destroy my diffs) [Re: Char Baby] #5380809 03/19/20 11:15 PM
Thanks! The fluids that I brought and the castrol are both GL-5 and the rear both have LSD. So I be good until the next change of 4 years/ 40000km.
Re: Differential Gear Oil Mixture ( Will it destroy my diffs) [Re: SilentForever05] #5381712 03/20/20 10:54 PM
Silk Offline
Their drum has a pump for filling diffs and gearboxes, to use your oil they would have to use a hand sludge pump...messy and time consuming. I don't blame them, and you got good oil anyway.
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
