What they look like? ROUND.
Do you just want one tool that matches it or an assortment if cheap enough? Just 1. Why would i need an assortment for this cutter? Would you consider an entire carb/bulb/etc kit if it came with a tool and was cheap? No, all I need is the tool. Does it need to be a high quality tool or just a 10-uses-per-lifetime tool? NO, just to adjust when needed. Do you need it NOW or would a month wait (or whatever delay coronavirus causes) work so ebay from China is acceptable? whenever,not in a rush. Do you want fries and a coke with that?
Originally Posted by 97prizm
I went online and it looks like there are adjuster screws near the back. A couple of YouTube videos popped up with the how to.
I saw a couple of vids, but you got to hack the screw tops. I want to get a tool for this.
Compatible with most 2 cycle small engines and fit many brands of equipments, such as Sears, Craftsman, Poulan, Husqvarna, Weedeater, Echo, Toro, Ryobi, Homelite, and anything else that utilizes the splined adjustment screws
PACKAGE INCLUDED - 10 Pcs of Carburetor adjustment screwdriver, included Pac Man/ Small Head Pac Man/ Single D/ Small Head Single D/ Double D/ Hexagon/ 7 Teeth Splined/ 21 Teeth Splined Sc and the new Shapde/ Six Star screwdriver
A whole MUST-TO-HAVE carburetor adjustment tool set, to keep engine with EPA specifications
HIGH QUALITY MATERIAL & CONCISE DESIGN - Ergonomic grip and metal pole is durable to use
Brand new, well packaged. Free kit bag.
