Keep OE carb vs replacement
by JHZR2 - 05/31/20 10:00 AM
Gave away some of my stash
by Chris142 - 05/31/20 08:32 AM
Two year check in - Dewalt 20 V String Trimmer
by Snagglefoot - 05/31/20 08:07 AM
Sturmey Archer 3 Speed-Shifting?
by ET16 - 05/31/20 07:45 AM
Power washing your home
by ARB1977 - 05/31/20 07:05 AM
Clint Eastwood car collection.
by PimTac - 05/31/20 04:51 AM
Bulk Oil Setup
by Jason_Michaels - 05/31/20 04:39 AM
First generator
by daves87rs - 05/31/20 01:50 AM
New junk tool
by P10crew - 05/31/20 01:07 AM
tetraethyl lead additive
by painfx - 05/31/20 12:40 AM
Best handheld cordless vacuum?
by montero1 - 05/31/20 12:15 AM
2005ToyotaSolara3MZ-
FE coolant leak
by juca - 05/30/20 11:22 PM
I made a dually today. Carftsman LT1000
by ls1mike - 05/30/20 10:39 PM
New Prestone Products
by Snagglefoot - 05/30/20 09:17 PM
BEST OBD2 scanner for UNDER $100
by flinter - 05/30/20 08:44 PM
Oil Drain vs Extraction
by js1956 - 05/30/20 08:08 PM
Rayi, juca, jrow96, Kotsos, sharpmoney
71582 Registered Users
91 registered members (A_Harman, 762fermeandyou, ArrestMeRedZ, 2010Civic, 2015_PSD, 10 invisible), 2,270 guests, and 36 spiders.
Topics306,084
Posts5,286,090
Members71,582
Plugged Grease Nipple Solution #5378764 03/17/20 03:18 PM
G
Gebo Offline OP
G
I may be the only person that didn't already know this but I had a grease nipple that would not accept grease. It was one of those that was pressed in and you couldn't screw out. I fiddled and I faddled until I noticed my propane torch standing at attention on my workbench. Hmmm.....
I fired that baby up and heated that nipple for about 5 seconds and she took grease like my dogs eating raw hamburger. GONE down the PIPE.
Maybe this will help someone???
I'm starting to learn fire and heat can do amazingly good things.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Plugged Grease Nipple Solution [Re: Gebo] #5378798 03/17/20 03:48 PM
Dinoburner Offline
Either that or take the load off the device thats up against the fitting.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Plugged Grease Nipple Solution [Re: Gebo] #5378889 03/17/20 05:13 PM
G
George7941 Offline
G
What you do not realize is that heating the fitting with a propane torch will ruin the spring that holds the check ball. The fitting now no longer seals and grease can leak back out, contaminants can go in.
Carefully heating the fitting with a heat gun till the grease starts flowing, without overheating might save the spring.
I have encountered my share of pressed in fittings and dislike them. I have had to tap new threads and replace them with threaded grease nipples many times.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Plugged Grease Nipple Solution [Re: Gebo] #5378902 03/17/20 05:37 PM
T
tc1446 Offline
T
I have a heat gun and never thought of using it. Went to tractor dealer this morning and paid $9 for 4 new ones!
Good info.
'14 Kia Soul, 2.0L (29K)
'13 Accord EX-L 2.4L (110K) M1 & FU
'00 Ford Ranger 4.0L {69K} M1 & FU
'18 Polaris Slingshot 2.4L GM (QS & Bosch Cart.)
'07 Kioti CK-30 (Delo & Wix)
Re: Plugged Grease Nipple Solution [Re: Gebo] #5378969 03/17/20 07:43 PM
A
atikovi Offline
A
Re: Plugged Grease Nipple Solution [Re: Gebo] #5378986 03/17/20 07:57 PM
K
kstanf150 Offline
K
Yeah
Or keep a few spares in your tool box and just change em out
Their really cheap
Re: Plugged Grease Nipple Solution [Re: Gebo] #5378988 03/17/20 07:59 PM
K
Kestas Online Content
Global Moderator
Online Content
Global Moderator
K
He said he couldn't remove the grease nipple.
I too keep a stash of grease nipples that I use once every 20 years. I started stashing when I bought a new 74 Torino that came with screw plugs where grease nipples should be at the ball joints.
Re: Plugged Grease Nipple Solution [Re: Gebo] #5379039 03/17/20 08:51 PM
G
Gebo Offline OP
G
This nipple was pressed in and I couldn't screw it out.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Plugged Grease Nipple Solution [Re: Gebo] #5379171 03/18/20 12:37 AM
O
oldhp Offline
O
5 seconds of heat? You didn't hurt anything.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Plugged Grease Nipple Solution [Re: oldhp] #5379219 03/18/20 05:22 AM
G
Gebo Offline OP
G
I know grin2
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Plugged Grease Nipple Solution [Re: oldhp] #5379303 03/18/20 08:00 AM
W
WyrTwister Offline
W
That is what I was thinking . You certainly did not damage a spring . If you would have damaged anything , it would be a rubber seal / boot . Which I doubt .
Wyr
God bless
Re: Plugged Grease Nipple Solution [Re: Gebo] #5379324 03/18/20 08:22 AM
G
Gebo Offline OP
G
It is on the blade spindle of a Zero Turn.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Plugged Grease Nipple Solution [Re: atikovi] #5379477 03/18/20 11:19 AM
R
Rick505 Offline
R
Re: Plugged Grease Nipple Solution [Re: Rick505] #5379617 03/18/20 02:49 PM
A
atikovi Offline
A
Originally Posted by Rick505
I venture that many here are tool junkies and any excuse to buy one is good enough, especially the complete set. Better to have a tool you don't need than not have a tool you do need.
Re: Plugged Grease Nipple Solution [Re: Gebo] #5379762 03/18/20 06:02 PM
super20dan Offline
i use an awl and poke the ball in the nipple and move it around and then the fitting will usually take grease. not 100% but worth a try
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
