Local dealership charges $15 for an oil change.....
by Harrington - 04/04/20 02:57 PM
Did harvest king change suppliers?
by Micahmcmeen - 04/04/20 02:30 PM
Switching back from High mileage to regular.
by Micahmcmeen - 04/04/20 02:28 PM
Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Penne alla Boscaiola
by vavavroom - 04/04/20 10:05 AM
Fuel stabilizers for e10 gas - long storage
by caprice_2nv - 04/04/20 09:59 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
105 registered members (762fermeandyou, 01rangerxl, 928, 4WD, 41Pack, 2015_PSD, 11 invisible), 2,918 guests, and 21 spiders.
Topics303,589
Posts5,237,871
Members71,094
ISO 220 Equivalent #5379443 03/18/20 10:38 AM
drwindmill Offline OP
I have a gearbox that says to use ISO 220 gear oil or equivalent. I cannot find any oil in my area that says ISO 220. I understand that it's basically 90 weight oil. Can I just use a 75-90 synthetic? Please school me on this.
Re: ISO 220 Equivalent [Re: drwindmill] #5379463 03/18/20 11:04 AM
W
WyrTwister Offline
W
Wyr
God bless
Re: ISO 220 Equivalent [Re: drwindmill] #5379475 03/18/20 11:15 AM
Scuder Offline
What's the application? A SAE 75W gear oil drops pretty far below ISO 220. Does it specify GL1, GL4, or GL5?
Re: ISO 220 Equivalent [Re: Scuder] #5379507 03/18/20 11:59 AM
Thanks for your reply the manual only says ISO 220 or equivalent. I've scoured the internet and cannot find what the equivalent would be.
Re: ISO 220 Equivalent [Re: Scuder] #5379607 03/18/20 02:37 PM
MolaKule Offline
Global Moderator
Global Moderator
thumbsup
Look at the chart below and find ISO 220, read across, and you will see the equivalent viscosities for various industry grade systems.
https://www.bobistheoilguy.com/viscosity-charts/
The additive package determine whether or not the lubricant is a hydraulic fluid, gear oil, or engine oil. Most modern Gear trains have a protection rating of either GL-4 or GL-5.
Dr. Larry Fleinhardt: "You know, that term "dark matter" has always perplexed me. It fallaciously implies that the 95% of our universe that cannot be observed is some amorphous, eventless emptiness."
Amita Ramanujan: "I'm sorry?"
Dr. Larry Fleinhardt: "I guess it's all too human. Instead of admitting to the present limits of our knowledge, we just declare things to be unknowable." NUMB3RS
Re: ISO 220 Equivalent [Re: drwindmill] #5379774 03/18/20 06:22 PM
R
RDMgr Online Content
Online Content
R
The question has already been asked. What is the application. ISO 220 is usually an industrial viscosity designation. GL-4 and 5 are usually automotive adpacks. The chemistries are usually different. Viscosity read across charts are usually based on 95VI oils and the ISO 220 does align with SAE 90.
Re: ISO 220 Equivalent [Re: drwindmill] #5381342 03/20/20 02:55 PM
MolaKule Offline
Global Moderator
Global Moderator
I have asked the OP to either respond or the thread gets locked.
Re: ISO 220 Equivalent [Re: drwindmill] #5383653 03/23/20 11:36 AM
Z
zeng Offline
Z
ISO 220 is an industrial gear oil whose [email protected]*C is defined at 220 cSt +/- 10 % , i.e 198 - 242 cSt .
It's north american counterpart is AGMA 5 R&O gear oil , and alternatively AGMA 5EP Extreme Pressure gear oil .
Most modern automotive SAE 90 gear oil miss the [email protected]*C by a small margin though close , you need its equivalent in automotive SAE 110 gear oil which isn't available in almost all markets .
No, you can't use automotive SAE 75W90 whose [email protected]*C is typically 100 - 105 cSt , i.e equivalent to ISO 100 industrial gear oil and it is 2 viscosity grades thinner than that of ISO 220 .
[Linked Image]
Edit:If you must consider an automotive gear oil due to availability and price issue , please consider a 85W140 with a [email protected]*C closer to 242 cSt .
Re: ISO 220 Equivalent [Re: drwindmill] #5388874 03/29/20 07:12 PM
The application is a pull type TMR mixer.
Re: ISO 220 Equivalent [Re: drwindmill] #5389732 03/30/20 08:59 PM
R
Online Content
R
AGMA uses the ISO VG system plus grades 2200 and 3200 for the past several years. They don't use the old numbering system or the suffix letters.
Re: ISO 220 Equivalent [Re: drwindmill] #5390275 03/31/20 03:21 PM
MolaKule Offline
Global Moderator
Global Moderator
T
Quote
Check out Schaeffer Oil
https://www.schaefferoil.com/documents/95-209-td.pdf
they have been in the industrial lubricant business since steamboats and covered wagons.
