I thought I could save some money by changing tires myself. I thought the task would be easy, considering the amount of car work I've done. I have changed 4 or so timing belts, swapped an engine, changed an axle, etc. A tire swap should be mince meat - I was wrong. I couldn't believe how much of a bullfight this was. Tire irons feel like Stone Age type tools, and to be honest, I don't have the artistic talent to use these things. I tried for 2 days to get the tire off the stupid rim. The first day I got the old tire off, the second day I got one side of the bead mounted and the other I just couldn't finish.
With a dinged up rim, I must shamefully shamble into the dealer to get my tires swapped. But never again am I going into the bullring. It is not worth the $30 savings. Do you do it yourself? Is there some magical tool that makes unmounting and mounting work? I tried lube, lots of it. Breaking the bead was easy in comparison.
