Originally Posted by Jarlaxle
Originally Posted by OVERKILL
I know one of the southern US guys (Arizona, think it was Nick1994?) had a dry rot issue on a vehicle that sat a lot, but I don't recall it being an issue up our way. I've never personally experienced it and almost exclusively buy Michelin due to the great experience we've had with their tires. Do these folks by chance use tire dressing or do the vehicles sit a lot? I know CapriRacer noted at one point that the oils that are impregnated into the rubber that are supposed to work their way out to protect the surface from UV and cracking require the tire be used somewhat regularly.
The Audi owner used Simple Green, the Ram owner used nothing but a garden hose. Both were driven at least 5 days a week and never sat more than 3-4 days at a time.
Combine that with the catastrophic Michelin XRV problems (they tend to split wide open...sometimes while PARKED!), I will never give a cent to Michelin under any circumstances.
I cannot remember how many Michelins I had, and never had rotting issue.
But, get Kumho, come back and let's talk.
FACT is there is NO better tire then PS4S for what you want.
But, you can always go with 4 mismatched Chinese tires or those Kumho's, or Yokohama, and after 15k have same performance as those 4 mismatched Chinese tires.
In all seriousness, if you want top performance, and do not want best tire, stick to Bridgestone, Pirelli and Continental. In that category I would not venture to other brands.
Your opinion means nothing, because you have absolutely no idea what you are blathering about.
Originally Posted by Olas
It seems highly irrational to intentionally omit the best tire in the class because of some unexplained disdain towards the company that manufactures it
[/quote]
So...did you not read what I posted of did you simply ignore it?
Quote
OP are you brave enough to use a cut slick on public roads? or even a full slick? They can generate sufficient lateral grip to twist your monocoque if you drive hard enough.
Mickey Thompson radials?
Nangkang NS2R
Nangkang AR1
Toyo R888R
Maxsport RB5 Tarmac
Hankook Ventus Z209
DMACK DMT-RC2 Tarmac
Yokohama A006-T
Kumho Ecsta TM02
Pirelli P7 Corsa Classic
Dunlop DZ03G Road - Track
Goodyear Eagle F1 SuperSport
Federal 595 RS-R
Pick one of the above - you'll find your own limits before you find the tyres limits
No, I will not run DOT track tires![/quote]
It might help if you outline ALL of your criteria before asking for recommendations - you say you want a UHP summer tyre so we tell you about the class leader but you dont want it. We list alternatives like the Pirelli Trofeo R and you ignore it.
We give you lists of UHP summer tyres for dry use and you say you dont want track tyres.
So, outline ALL of your criteria and we can make more suggestions.
Also, explain what objections you have to the Mickey Thompson UHP summertime tyre.
