When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 04/01/20 02:41 PM
NEW Adam's Polishes - Hand Sanitizer
by SavagePatch - 04/01/20 02:40 PM
Home vehicle modification fails
by IMSA_Racing_Fan - 04/01/20 01:57 PM
Internet speeds in current climate.
by sloinker - 04/01/20 01:55 PM
concrete work while at home
by spasm3 - 04/01/20 01:19 PM
Oil change
by IvanPletex - 04/01/20 12:52 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
113 registered members (Alfred_B, 2009Edge, 53' Stude, AC1DD, 2015_PSD, 15 invisible), 1,905 guests, and 27 spiders.
Topics303,444
Posts5,235,397
Members71,072
Graphite paint? #5379085 03/17/20 09:33 PM
J
jakewells Offline OP
J
Mods i didn't know where to put to topic.
Been looking into graphite based paint like ez slide to use on the underside of a mower deck does this stuff work is it a gimmick? I sometimes have problems with grass wanting to cake under the deck even with it dry. Just looking for suggestions.
2001 Mercury Cougar base 2.5l CD4E automatic.
Re: Graphite paint? [Re: jakewells] #5379097 03/17/20 09:48 PM
G
George7941 Offline
G
I expect that a chain lube like Dupont Chain Saver will work. It is clear in color and does not create a mess.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Graphite paint? [Re: jakewells] #5379119 03/17/20 10:09 PM
KJSmith Offline
Re: Graphite paint? [Re: jakewells] #5379122 03/17/20 10:12 PM
9
97prizm Offline
9
My yard machines push mower seems to have a tendency for grass to stick to the underside. A gatorblade definitely reduced this but not completely. I sprayed the underside with gunk brand I think it helps quite a bit.
mower deck coating
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: Graphite paint? [Re: jakewells] #5379129 03/17/20 10:21 PM
J
J
I will look into all of them it seems there is a big selection.
Re: Graphite paint? [Re: jakewells] #5379199 03/18/20 04:04 AM
O
Olas Offline
O
remake the part from stainless and you wont need to paint it wink
Cable ties should hold it
Re: Graphite paint? [Re: jakewells] #5379288 03/18/20 07:37 AM
spasm3 Offline
I have tried a lot of things, and none worked. I tried a graphite paint to no avail. I tried various paints and bedliner. Nothing holds up. Now if you are mowing a very small area and coat it often, maybe, but is it worth the effort. I mow a fair area and nothing holds up. Granted i have a lot of small sticks, leaves, and sweet gum balls.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Graphite paint? [Re: jakewells] #5379498 03/18/20 11:48 AM
doitmyself Offline
My results are exactly the same as spasm3's.
Re: Graphite paint? [Re: doitmyself] #5379540 03/18/20 12:42 PM
G
Gillsy Offline
G
YUP, same, nothing worked for me.
Many are the afflictions of a righteous man
2019 Nissan Murano S
2018 Gravely ZT HD 52
2016 Kawasaki 650 Versys LT
2012 Mazda 3 Skyactiv 2 ltr
