Graphene the next detailing protection
by Mamala Bay - 03/29/20 02:17 PM
Anyone here a blacksmith?
by 53' Stude - 03/29/20 02:13 PM
Buying products made outside the USA
by 007 - 03/29/20 01:22 PM
Marine oils on sale at Canadian Tire
by Snagglefoot - 03/29/20 12:42 PM
0W16 instead of 0w20?
by Mter00s - 03/29/20 12:36 PM
XG10575 Walmart.com deal
by 762fermeandyou - 03/29/20 12:29 PM
Virgin ACDelco PF1245 cut and post
by nwjones18 - 03/29/20 11:49 AM
Oups, forgot oil cap...
by M119 - 03/29/20 11:46 AM
Recommendation for tuned BMW N55?
by RIPGermanCastrol - 03/29/20 11:15 AM
Electrician's Help With Circuit Breaker ?
by doitmyself - 03/29/20 11:07 AM
Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
105 registered members (645ja, A_Harman, ARCOgraphite, AZjeff, 53' Stude, 2oldtommy, 6 invisible), 2,177 guests, and 20 spiders.
Topics303,317
Posts5,233,865
Members71,038
Toyota techs here? 2grfe head gasket? #5379005 03/17/20 08:11 PM
T
t1snwrbrdr12 Offline OP
T
2011 sienna 2grfe 3.5 v6.
I was under it to drain the antifreeze and at the rear of the engine, center of the cylinder head where it meets the block, there was a bit smaller than a golf ball size dried up crusted up glob of antifreeze. I saw no trail leading there, although I do work on it in my driveway so it’s a bit harder to get a good inspection.
I ran out of time after bleeding it (kicked my butt getting the air out of it). Kids home from school due to Coronavirus so I didn’t get a pressure tester on it to watch for active leaks. I cleaned the crust and plan on monitoring it.
I never needed to top off coolant. I’ve never smelled it. I’ve never seen it drip. But it’s obviously leaked at some point.
Anyone know of anything that leaks and leads to that area? Someone familiar with this engine may know. It’s kind of a mess under the hood so just looking for anyone familiar to see if I need to look anywhere in particular.
Is this a common issue on 2grfe?
I follow a Toyota tech on Instagram and he’s done some head gasket in the short time I’ve followed him, along with a few coolant crossover pipes. A head gasket would likely drive me to get rid of this van if it got so bad it requires repair. It’s not something I could easily do in my driveway.
Thanks for any insight.
Re: Toyota techs here? 2grfe head gasket? [Re: t1snwrbrdr12] #5379006 03/17/20 08:14 PM
Chris142 Online Content
Online Content
If it's not big enough to cause a problem leave it. Maybe add a couple of seal tabs.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Toyota techs here? 2grfe head gasket? [Re: t1snwrbrdr12] #5379198 03/18/20 04:00 AM
O
Olas Offline
O
Cable ties should hold it
Re: Toyota techs here? 2grfe head gasket? [Re: t1snwrbrdr12] #5379223 03/18/20 05:33 AM
Slick17601 Online Content
Online Content
Add a bottle of K Seal.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Toyota techs here? 2grfe head gasket? [Re: t1snwrbrdr12] #5379254 03/18/20 06:51 AM
diyjake Offline
OP - how many miles do you have on the van? I thought these engines where solid, never heard of head gasket issues before.
Re: Toyota techs here? 2grfe head gasket? [Re: t1snwrbrdr12] #5379280 03/18/20 07:29 AM
T
T
130-140some thousand.
It’s leaking right out of the center of the head but down the back of the block, not into the valley. Unless I didn’t see a clear trail (hopeful) and it was just collecting there from another minor leak elsewhere. I need to get pressure on it and monitor it when I have time to really uncover things and thoroughly inspect. It’s just a mess under hood so figured someone may know right where to look.
