Collection of Euro Oils
by js1956 - 05/24/20 10:29 PM
00 grease in my brush mower
by Elkins45 - 05/24/20 09:55 PM
Coolant UV Dye - for without flushing
by Ndx - 05/24/20 09:10 PM
STP S8A C&P
by mpack88 - 05/24/20 07:50 PM
Aprons
by buck91 - 05/24/20 07:35 PM
Oil Additives for GDI engines
by Drew99GT - 05/24/20 07:21 PM
Memorial Day - Veteran's Cemetery
by JeffKeryk - 05/24/20 07:18 PM
CQ Blue, made by who?
by AJB0009 - 05/24/20 06:45 PM
recommended 5w30 for ticking and engine noises
by apollo18 - 05/24/20 06:29 PM
need new group 65 for my F-150, here's my choices:
by DirtyApe - 05/24/20 06:23 PM
Castrol EDGE cleaned my funnel
by AJB0009 - 05/24/20 05:29 PM
Metal Cloak FAD + Fox Steering Stabilizer
by 2015_PSD - 05/24/20 04:55 PM
Blue Driver OBDII
by Al - 05/24/20 04:50 PM
Coca Cola 600 at Charlotte Motor Speedway
by bdcardinal - 05/24/20 04:38 PM
Memorial day
by gman2304 - 05/24/20 04:33 PM
Transmission temp help!
by zx6rsi - 05/24/20 04:18 PM
BBC_bias, rabblrouzr, Modoi, zx6rsi, Chumpchange
71522 Registered Users
50 registered members (bdcardinal, 10WSmuckers, BTLew81, 2010Civic, Bruce T, 7 invisible), 1,754 guests, and 24 spiders.
Topics305,823
Posts5,281,050
Members71,522
Addititive to Mirror Valvoline Premium Blue Restore #5378851 03/17/20 04:34 PM
P
pollymath Offline OP
P
VPBR is expensive stuff. It's also hard to get. However, we know what's in it.
Is there anyone making an oil additive to recreate VPBR with cheaper oils?
Re: Addititive to Mirror Valvoline Premium Blue Restore [Re: pollymath] #5378866 03/17/20 04:49 PM
T
tundraotto Offline
T
No - because the biggest additive is the very expensive basestock.
50% Group V Ester + 30% PAO (from memory)
Re: Addititive to Mirror Valvoline Premium Blue Restore [Re: pollymath] #5378893 03/17/20 05:20 PM
B
blufeb95 Offline
B
If there was it'd cost about the same by the time you mix it with an oil with comparable base stocks ie. Redline and Amsoil SS.
Re: Addititive to Mirror Valvoline Premium Blue Restore [Re: blufeb95] #5378898 03/17/20 05:29 PM
K
kschachn Offline
K
They have the same base stocks?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Addititive to Mirror Valvoline Premium Blue Restore [Re: kschachn] #5378909 03/17/20 05:49 PM
B
blufeb95 Offline
B
Isn't Amsoil signature mostly PAO, and redline is generally some of the highest ester oil you can find, maybe some racing oils, I guess my underlying point is that the Valvoline Restore is a fully formulated product that has the specific blend of detergents and oils that are good for unsticking rings and cleaning up, if you try to replicate it you're just gonna spend more money and time into doing it, than it costs to buy the properly formulated product.
Re: Addititive to Mirror Valvoline Premium Blue Restore [Re: blufeb95] #5378949 03/17/20 07:19 PM
K
kschachn Offline
K
No clue. I thought you knew since you said they were comparable base stocks.
1994 BMW 530i, 252K
Re: Addititive to Mirror Valvoline Premium Blue Restore [Re: pollymath] #5379189 03/18/20 03:14 AM
O
Olas Offline
O
Esters are very good at cleaning, and Redline has a lot of Ester content. Ask anybody who has been inside an engine that used Redline oil - those Esters keep things looking fresh & new.
Unfortuantely it costs about the same as VPBR. If your rings need un-sticking why not do a piston soak with ChemDip? If the internals are full of sludge then remove what you can remove by hand, and do short changes on something cheap like supertech.
You have to decide how long it will take to clean by hand and how much your time is worth, compared to the cost of a bottle of expensive oil.
Re: Addititive to Mirror Valvoline Premium Blue Restore [Re: pollymath] #5379240 03/18/20 06:21 AM
K
krismoriah72 Offline
K
Just to be devils advocate..i think it was designed to clean carbon from rings of the Cummins ISX but was a bandaid. Cummins figured out antipolishing rings were a better solution. Not sure if VPBR will be available in the future.
OTOH Kreen.
quote:
Guaranteed to improve your engines performance. When added to either the gas or oil of your engine, Kreen dissolves the carbon deposit
buildups and varnishing to Improve Compression · Increase Gas Mileage Reduce Downtime · Restore Power By thoroughly cleaning the rings, valve, and fuel injectors - Kreen gives new life back in any gas or diesel engine.
VPBR- Cleans Rings
Kreen- Cleans Rings
Re: Addititive to Mirror Valvoline Premium Blue Restore [Re: pollymath] #5379253 03/18/20 06:51 AM
O
Olas Offline
O
Yamaha make an additive for stuck rings YAMALUBE Ring Free Plus
Re: Addititive to Mirror Valvoline Premium Blue Restore [Re: pollymath] #5379395 03/18/20 09:44 AM
M
Mad_Hatter Offline
M
Just how bad do you think your ring problem is? Sometimes no amount of mechanic in a can (or bottle) can unstick rings to get em to stand proud or worse yet, fix broken rings. (-duh)
You could try several short, 3k mile'ish, drain intervals using a good dino/HDEO with Rislone. Dino's tend to have better solvency due to their higher levels of aromatics. Rislone has an ester (polyol ester IIRC) in it that slowly dissolves sludge. I'd say if you haven't seen an improvement after 2 or 3 oci's, nothing's gonna help. Or maybe your last resort is/are engine flushes at that point.
Good luck 👍
Fwiw.. you can actually double up on the amount of esters by using a 2nd bottle of Rislone for the last 100 miles or so. Of course you'll would need to drain some out of the crankcase to make room for the addtl bottle of Rislone. Also keep in mind that a 2nd bottle will likely have a meaningful effect on 100c viscosity as Rislone is something like a 0w20 - so keep that in mind in choosing your oils viscosity if you intend to double up..
You can visit Rislone's website for more about that but it's pretty much as i just described.
Re: Addititive to Mirror Valvoline Premium Blue Restore [Re: pollymath] #5379410 03/18/20 09:56 AM
RDY4WAR Offline
High Performance Lubricants 10w-30 flush oil. Supplement up to 25% with it. It's an ester oil with a CI-4 add pack.
[Linked Image]
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Addititive to Mirror Valvoline Premium Blue Restore [Re: pollymath] #5379424 03/18/20 10:13 AM
M
Mad_Hatter Offline
M
Where do you buy that stuff? I don't see it on Amazon..is it direct from the mfg thing? I also didn't see any pricing on the mfgs website either.
Re: Addititive to Mirror Valvoline Premium Blue Restore [Re: Mad_Hatter] #5379469 03/18/20 11:14 AM
B
blufeb95 Offline
B
You have to get it from a Cummins service center last I heard it was around $75 a gallon.
Re: Addititive to Mirror Valvoline Premium Blue Restore [Re: pollymath] #5379486 03/18/20 11:28 AM
M
Mad_Hatter Offline
M
I know about VPB but I mean where does one get the HP product? Not very helpful if ya can't readily find it.
Re: Addititive to Mirror Valvoline Premium Blue Restore [Re: pollymath] #5379583 03/18/20 01:46 PM
K
Kamele0N Offline
K
Put some Diesel into your oil....and idle for a minute or two..
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
