Originally Posted by PowerSurge
You two need to prove the increased wear in a 5.7 liter Tundra engine that has ran 0w-20 against one that has ran a thicker oil. Or any other modern engine for that matter. And I'm talking about actual tear downs where main bearings, piston rings, etc. are compared under the same conditions. We can all read comparisons of oil and MOFT and HTHS figures produced from a lab, but does that ACTUALLY show up in less wear on an actual engine used in real world conditions.
Let's see it. I really am curious to see proof. Like I've stated before. If someone can show me tests done like stated above that show higher engine wear because of 0w-20 I will stop running it today.
As in some of your other posts that I've seen, you change the subject and attempt to post a "gotcha' response when it isn't what was being discussed.
Again what I and Bryanccfshr posted is correct. It is indeed MOFT that keeps parts separated and prevents metal-to-metal contact. Higher viscosity oils depend less on additives to keep an adequate MOFT. I suspect you know this already however.
