2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
112 registered members (5AcresAndAFool, 92saturnsl2, ABomb369, 53' Stude, 55hambone, 17 invisible), 1,792 guests, and 22 spiders.
Topics303,451
Posts5,235,469
Members71,072
PF64 cut open #5378690 03/17/20 01:49 PM
F
Fsharp Offline OP
F
Cut open a AC Delco pf64 filter that was on my 2019 Spark with around 7000+ miles on it. I thought the pleats looked looked really good so I took some pictures I should’ve gotten one of the anti drain back valve but it was in good shape and flexible. I’ve really started to like AC Delco filters as they’re cheap, pretty well made even with the e-core and have a regular bypass valve
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Re: PF64 cut open [Re: Fsharp] #5378714 03/17/20 02:21 PM
blupupher Offline
Looks good (but oil looks very dark).
Still a lot of dislike from many on the e-core, but I have no issue with them at all.
I think it is a better option than louvers.
'18 Santa Fe: PP 10W30/OEM
'18 Soul: Synpower 5W30/ProGuard
'12 xB: M1 EP 0W20/CQ Blue
'10 Santa Fe: Synpower 5W30/D+
'04 F150: Magnatec 10W30/ST
'02 F150: Magnatec 5W20/D+
'94 VT1100: Peak 15W40/D+
Re: PF64 cut open [Re: Fsharp] #5378715 03/17/20 02:21 PM
A
A_User55555 Offline
A
Looks good. Im still curious why this E core filter has metal end caps while the other E cores have the paper ones.
2011 Cadillac DTS. No the headgaskets have not blown.....
5W-30 Valvoline Full Synthetic with a Purloator Boss PBL25288 Filter
Re: PF64 cut open [Re: Fsharp] #5378716 03/17/20 02:21 PM
G
GM4LIFE Offline
G
I stocked up on the classic PF64 Delco filters before they went to the e-core design. I have about 60 of them now. I have 2 GM vehicles that take the PF64 filter (CTS-V and Z06) and wanted to make sure that these V8 engines have the stronger internal metal tube instead of the plastic cage design.
Re: PF64 cut open [Re: Fsharp] #5378719 03/17/20 02:25 PM
L
LeakySeals Offline
L
It looks good to me. But I do wonder about that plastic core. Compared to a metal core with small holes there's not much to prevent media from getting sucked through if it were to tear or get loose.
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: PF64 cut open [Re: blupupher] #5378739 03/17/20 02:59 PM
T
Triple_Se7en Offline
T
Used oil does look real black. Maybe in use too long. Amen to the dislike on louvers.
Keep Your Pistons Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul X-Line 2.0 MPI - both Pennzoil Ultra Plat. 5W30 / AC Delco PF1127 Ecores
04 Chev Colorado Napa Syn 0w20 & K&N
Re: PF64 cut open [Re: Triple_Se7en] #5378758 03/17/20 03:13 PM
Z
ZeeOSix Offline
Z
The oil doesn't look that dark on the metal end caps.
Re: PF64 cut open [Re: Fsharp] #5378767 03/17/20 03:19 PM
F
Fsharp Offline OP
F
The oil life monitor was at about 25% and I’m using Rotella Gas Truck. The oil did seem dark, but it could be the lighting plus the depth of the oil puddle on the bench. I guess it’s keeping particles in suspension which is good. I’ve never done a UOA on this vehicle, but that might be interesting now that it has 20,000 miles or so.
I don’t like louvers either.
Re: PF64 cut open [Re: Fsharp] #5379225 03/18/20 05:39 AM
J
JoelB Offline
J
That's the incorrect filter for your spark. Correct OEM filter is the UPF64R
Mine: 2020 Corolla SE
Factory fill
OE Filter
Wife's: 2018 Chevy spark 1.4 Non-turbo
Mobil 1 0w20 AFE
ACDelco UPF64R
Re: PF64 cut open [Re: Fsharp] #5379226 03/18/20 05:45 AM
J
JoelB Offline
J
Nope I'm wrong, 2019 manual seems to call for PF64. My 2020 manual called for UPF64R. I think there's a TSB out there somewhere calling for use of UPF64R in smaller GM engines though. Relates to cold start oil pressure and filters going into bypass.
Factory fill
OE Filter
Mobil 1 0w20 AFE
ACDelco UPF64R
Re: PF64 cut open [Re: A_User55555] #5379252 03/18/20 06:51 AM
Sayjac Offline
Quote
…... Im still curious why this E core filter has metal end caps while the other E cores have the paper ones.
It appears GM ACDelco has gone from the ecore with fiber/felt endcaps and poppet bypass to this latest hybrid design. Nylon centertube and metal endcaps with poppet bypass. GM has eschewed the use of combo valves in their ecore ACDelco filters for GM with filter integral bypass.
The current new-ish Champ made SuperTech 9688 uses the same element design.
Looks ok to me a 7k miles.
Thanks for c&p.
Re: PF64 cut open [Re: Fsharp] #5379450 03/18/20 10:52 AM
DudeNiceRide Offline
Looks pretty good to me. Nice pleating. Clean. I was never a fan of the legacy e-core design with the poly-fabric ends. I bet GM forced their hand though; got sick of fighting the hate-speech online and on U-toob.
I think the corrug. steel columns with the round holes are my favorite. Louvers are a flow choke. Plastic is plastic, but prob cleaner/rounder/consistent than metal from a mfg point of view?
Champ seems to have picked up that version of the PRV from their short time serving as a conjoined twin with FRAM. I believe FRAM had a patent on that PRV for many years (expired). FRAM & Champ prob buy their PRVs from same place. FRAMer in southern Ohio; Champy down in southern IL; designs look spittin' image identical. I'd guess from somewhere in the Dayton-Evansville-Indy manufacturing triangle.
If Champ offered this "hybrid" design in other stuff, I'd definitely be more interested in their stuff.
Re: PF64 cut open [Re: DudeNiceRide] #5379543 03/18/20 12:47 PM
Z
ZeeOSix Offline
Z
Louvers give more flow area (meaning less delta-p) IF they are formed well. If they are barely opened up due to bad manufacturing then it could cause flow resistance, which means more delta-p across the filter can cause the bypass valve to open when it shouldn't.
This forum has seen very few eCore center tube issues over the last many years. I think the designers & manufacturers took a while in the early days to figure it all out and got it tweaked pretty well these days. Reducing the eCore tube openings and tightening up the pleat spacing was the key to prevent eCore type failures seen in the early days when they hit the market.
AC Delco going with metal end caps is a nice upgrade IMO. Filter looks well constructed IMO. Thanks for the C&P.
Re: PF64 cut open [Re: Fsharp] #5379574 03/18/20 01:21 PM
Malo83 Offline
Looks good but i switched over to Wix/NAPA filters. cheers
Re: PF64 cut open [Re: ZeeOSix] #5379640 03/18/20 03:14 PM
T
T
AC Delco going with metal end caps is really not a nice upgrade, because they had no business downgrading the filter to fiber around 10 years ago.
Would you consider silicone ADBVs a nice upgrade too, if those came back? Most AC Delcos used to have silicone ADBVs and not nitrile around ten years ago.
AC Delco lost good customers like member Malo above and myself when they downgraded around 10 years ago. Malo's not going back to AC Delco and neither am I.
