RV's for MD's
by 02SE - 04/07/20 01:42 AM
Crawfish, It's A Louisiana Thang!
by BlueOvalFitter - 04/07/20 01:01 AM
M&P .40 Magazines $12.99
by BlueOvalFitter - 04/06/20 11:30 PM
Lots of Big Sur pics, only one of the car :-)
by SLO_Town - 04/06/20 09:24 PM
'16 Pilot Inline ATF filter
by parshisa - 04/06/20 08:55 PM
2019 Ram 1500 Classic
by Skippy722 - 04/06/20 08:53 PM
STP S3614 XL CUT OPEN
by 53' Stude - 04/06/20 07:15 PM
Kia Rio awful sound after sitting 5 years
by antonmnster - 04/06/20 07:13 PM
Cut open Motorcraft FL820S
by PantherFan88 - 04/06/20 06:38 PM
240V Electric Hookup Questions
by 92saturnsl2 - 04/06/20 06:33 PM
license plate frame with 3rd brake light
by wings&wheels - 04/06/20 06:12 PM
Wurth HHS 2000
by ejt - 04/06/20 06:06 PM
Snapper drive belt install trouble LT300
by spk2000 - 04/06/20 05:56 PM
installing garage LED shop light help needed
by FirstNissan - 04/06/20 05:20 PM
Casite filters
by opus - 04/06/20 05:16 PM
Oil for Jeep
by rokwldr - 04/06/20 05:12 PM
Kitchen sink faucet leak help
by 97prizm - 04/06/20 04:45 PM
RIP Al Kaline.
by PimTac - 04/06/20 04:36 PM
Frankentruck power steering question
by Thomcat316 - 04/06/20 04:11 PM
Comment from Miata track on Amsoil GL-4
by Bill_W - 04/06/20 03:28 PM
BludRacing, Cacciatore, Thomcat316, NTexian, LateLifeCrisis
71116 Registered Users
33 registered members (cabriopeugeot, bachman, blufeb95, Char Baby, 73guna, 4 invisible), 1,232 guests, and 19 spiders.
Topics303,700
Posts5,240,225
Members71,116
Belt(?) squeal under load but only when warm #5378608 03/17/20 12:14 PM
Calikura Offline OP
As per title - after engine is thoroughly warm from a long drive of over 30 minutes I get a squeal that sounds like belt squeal, but while it is very high pitched, it is not loud.. but well concealed by the otherwise normal engine noise. It's subtle enough I thought it was tinnitus messing with me at first, but when I have the windows down rolling through the quiet residential parking lot and listen carefully, it's there, and it stops when I let off the gas or at idle.
Cold start in the morning, and/or if I only do a short drive, the squeal is completely absent even under hard acceleration and with the AC on.
Checked the basics - no wobble of serpentine belt on pulleys, no wobble of pulleys themselves, none seized, no grinding noises and belt tension feels within spec. Engine has a timing chain rather than timing belt. Don't have any means of loosening the tensioner myself so I can't remove the belt to hand-spin the pulleys - will have to get that checked at the shop.
Is there something obvious I should know if I get a squeal only after thoroughly warmed and driven a bit? My past experiences with belt squeals is that they are worse in the morning or when it is wet.. so this one seems totally out of whack. Maybe it's not even the belt..?
Re: Belt(?) squeal under load but only when warm [Re: Calikura] #5378627 03/17/20 12:36 PM
L
Lubener Offline
L
When it is warmed up, have a buddy rev up the engine to produce the squeel. Then give the belt a squirt of water and see it it quiets down that will isolate the belt.
The "thinking" man's friend.
Re: Belt(?) squeal under load but only when warm [Re: Calikura] #5378642 03/17/20 12:55 PM
The Critic Online Crying
Online Crying
What is the application?
Does the alternator have a decoupler pulley?
2011 Toyota Prius 1.8L - 206K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 144K - Valvoline Premium Blue Restore 10W-30
Re: Belt(?) squeal under load but only when warm [Re: Calikura] #5378679 03/17/20 01:36 PM
B
Boomer Offline
B
Over the years, I have used this trick over forty years to quiet numerous squealing belts that otherwise appear to be in good shape and still quite functional. Take a pea size lump of SILICONE (not petroleum) based grease and gently apply it to the ribbed or contact side of the belt. Do this in about three places along the contact side of the belt so that they are approximately equally spaced. Turn on the engine and let the car idle for a minut or two to allow the grease to be equally spread across the belt. This will NOT cause the belt to slip but will really quiet the noise.
2019 VW Passat 2.0 liter gasoline DI engine, DI, 2,700 miles, Castrol Professional VW 508 0W-20
2017 VW Golf All Track 1.8 liter gas engine DI, 25,500 miles Castrol Professional VW 505 5W-40
Re: Belt(?) squeal under load but only when warm [Re: Calikura] #5378911 03/17/20 05:54 PM
K
Kawiguy454 Offline
K
Belt tensioner pulley bearing can also squeal when it starts going bad
Re: Belt(?) squeal under load but only when warm [Re: Kawiguy454] #5379318 03/18/20 08:16 AM
W
WyrTwister Offline
W
Yep . The pulleys / tensioner bearings can squeal . I have also had the A/C compressor clutch bearing make noise .
Wyr
God bless
Re: Belt(?) squeal under load but only when warm [Re: Calikura] #5380893 03/20/20 05:32 AM
M
motor_oil_madman Offline
M
Bearings make noise when they get hot
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Belt(?) squeal under load but only when warm [Re: Calikura] #5380894 03/20/20 05:33 AM
M
M
Had a bearing on my boat go bad and it would be fine for the first 10 minutes, then after that it would stall the engine.
Re: Belt(?) squeal under load but only when warm [Re: Calikura] #5385020 03/24/20 10:51 PM
Calikura Offline OP
It turned out to be the tensioner pulley bearings. The spring in the tensioner was also creaking a bit. Thankfully, the crank, alternator and water pump pulleys are still good.
I replaced the tensioner, the idler pulley and the serpentine belt (which had 60k miles on it anyway). Things are quieter under the hood now, and even the subtle chirp I used to get upon first engagement of the compressor clutch in the morning doesn't happen anymore.
I admit the fact that the squeal only happening when thoroughly warm threw me off a bit, and I started to overthink a simple wear and tear issue.
