Gas Buddy Question
by Wolfshead - 03/29/20 03:30 PM
Caliper piston boot
by painfx - 03/29/20 03:25 PM
Graphene the next detailing protection
by Mamala Bay - 03/29/20 02:17 PM
Anyone here a blacksmith?
by 53' Stude - 03/29/20 02:13 PM
Buying products made outside the USA
by 007 - 03/29/20 01:22 PM
Marine oils on sale at Canadian Tire
by Snagglefoot - 03/29/20 12:42 PM
0W16 instead of 0w20?
by Mter00s - 03/29/20 12:36 PM
XG10575 Walmart.com deal
by 762fermeandyou - 03/29/20 12:29 PM
Virgin ACDelco PF1245 cut and post
by nwjones18 - 03/29/20 11:49 AM
Oups, forgot oil cap...
by M119 - 03/29/20 11:46 AM
Recommendation for tuned BMW N55?
by RIPGermanCastrol - 03/29/20 11:15 AM
Electrician's Help With Circuit Breaker ?
by doitmyself - 03/29/20 11:07 AM
Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
111 registered members (007, 2010Civic, 53' Stude, 2oldtommy, 2015_PSD, 645ja, 7 invisible), 2,207 guests, and 17 spiders.
Topics303,319
Posts5,233,874
Members71,038
1993 Ford Ranger Spark Plug Analysis #5378607 03/17/20 12:12 PM
spavel6 Offline OP
I'm having random misses at idle when warm with no Check Engine light on a 1993 Ranger 4.0.
It also has intermittent tapping, which I believe is the pushrods/rockers, but I will be tackling this later.
I pulled the plugs, and found it interesting. The whole left bank is much more fouled than the right.
What do you guys think? Expert opinions needed!
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
2003 VW Jetta Wagon TDI 198k M1 5W40 TDT
2001 VW GTI VR6 250k T6 5W40
2001 VW Passat Wagon V6 4motion 110k PP 5W30
Re: 1993 Ford Ranger Spark Plug Analysis [Re: spavel6] #5378617 03/17/20 12:23 PM
I
incognito_2u Offline
I
Is that V6 in your 1993 Ranger "Transverse" mounted?
2006 Jeep Commander 3.7 V6 -116k (M1EP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -88k (M1EPHM5W30/XG3600)
1999 Toyota Corolla 1.8 -91k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -68k (VME5W30/XG3600)
Re: 1993 Ford Ranger Spark Plug Analysis [Re: spavel6] #5378621 03/17/20 12:27 PM
spavel6 Offline OP
Longitudinal
Re: 1993 Ford Ranger Spark Plug Analysis [Re: spavel6] #5378625 03/17/20 12:32 PM
K
Kira Offline
K
How many miles on this '93?
Was the "waste spark" system used on that engine? They say incorrect spark plugs on one bank will take a beating due to the polarity of the spark.
However, "double platinum" is supposed to negate the imbalance. Did operation improve with the new plugs?
Bad valve seals on one bank? Perhaps head work on the other side years before?
Re: 1993 Ford Ranger Spark Plug Analysis [Re: Kira] #5378628 03/17/20 12:36 PM
spavel6 Offline OP
Very little history on this vehicle, aside from the visual inspection. I just got this in a trade.
The engine I would guess has ~150k-200k on it.
Yes, it's better with the new plugs. However, I wonder if the skip will return shortly.
Also, I did pull a left-bank "lean" code with the old plugs. They were hand-tight, so I wondered if they were leaking compression causing the lean..
Re: 1993 Ford Ranger Spark Plug Analysis [Re: spavel6] #5378682 03/17/20 01:39 PM
M
meep Offline
M
if anything, the lean bank looks healthy and the other bank looks like it's running rich.
Wonder if a PCV return or other waste line is feeding one side of the intake, though any waste fumes shouldn't cause anything so much as the difference shown.
2018 F150
2015 crv (wifey!)
Re: 1993 Ford Ranger Spark Plug Analysis [Re: meep] #5378685 03/17/20 01:42 PM
spavel6 Offline OP
My understanding is that Cyl 4,5,6 is the left bank (drivers side). Are you saying the sooty plugs are normal vs the very clean Cyl 1,2,3?
Re: 1993 Ford Ranger Spark Plug Analysis [Re: spavel6] #5378702 03/17/20 02:07 PM
W
WobblyElvis Online Content
Online Content
W
Sticking my neck out a bit here but I think that the plugs were loose, could be the entire problem.
Re: 1993 Ford Ranger Spark Plug Analysis [Re: spavel6] #5378760 03/17/20 03:15 PM
F
Fsharp Offline
F
Maybe the intake gasket is leaking on that side.
Re: 1993 Ford Ranger Spark Plug Analysis [Re: spavel6] #5378795 03/17/20 03:47 PM
O
Oily_Thing Offline
O
Left side oxygen sensor is bad.
2020 Nissan Rogue SL AWD times two! (white and black)
Re: 1993 Ford Ranger Spark Plug Analysis [Re: spavel6] #5378830 03/17/20 04:13 PM
K
Kira Offline
K
I've read that at 150-200K all the exhaust sensors should be changed. Look 'em up - they're cheap.
I'm with that finger tight thing. Run her sane for a bit. She might like it.
Be glad you didn't shoot a hole somewhere under the hood....or bang the heck out of the threads on the way out.
Re: 1993 Ford Ranger Spark Plug Analysis [Re: spavel6] #5378878 03/17/20 05:01 PM
F
Fsharp Offline
F
I doubt that a 1993 ranger has separate o2 sensors for each bank
Does it burn or leak any oil op?
Re: 1993 Ford Ranger Spark Plug Analysis [Re: spavel6] #5378886 03/17/20 05:04 PM
spavel6 Offline OP
Doesn't appear to burn oil.
It has two O2 sensors, one on each side. I have ordered a new left sensor. Should be here by Friday.
