RV's for MD's
by 02SE - 04/07/20 01:42 AM
Crawfish, It's A Louisiana Thang!
by BlueOvalFitter - 04/07/20 01:01 AM
M&P .40 Magazines $12.99
by BlueOvalFitter - 04/06/20 11:30 PM
Lots of Big Sur pics, only one of the car :-)
by SLO_Town - 04/06/20 09:24 PM
'16 Pilot Inline ATF filter
by parshisa - 04/06/20 08:55 PM
2019 Ram 1500 Classic
by Skippy722 - 04/06/20 08:53 PM
STP S3614 XL CUT OPEN
by 53' Stude - 04/06/20 07:15 PM
Kia Rio awful sound after sitting 5 years
by antonmnster - 04/06/20 07:13 PM
Cut open Motorcraft FL820S
by PantherFan88 - 04/06/20 06:38 PM
240V Electric Hookup Questions
by 92saturnsl2 - 04/06/20 06:33 PM
license plate frame with 3rd brake light
by wings&wheels - 04/06/20 06:12 PM
Wurth HHS 2000
by ejt - 04/06/20 06:06 PM
Snapper drive belt install trouble LT300
by spk2000 - 04/06/20 05:56 PM
installing garage LED shop light help needed
by FirstNissan - 04/06/20 05:20 PM
Casite filters
by opus - 04/06/20 05:16 PM
Oil for Jeep
by rokwldr - 04/06/20 05:12 PM
Kitchen sink faucet leak help
by 97prizm - 04/06/20 04:45 PM
RIP Al Kaline.
by PimTac - 04/06/20 04:36 PM
Frankentruck power steering question
by Thomcat316 - 04/06/20 04:11 PM
Comment from Miata track on Amsoil GL-4
by Bill_W - 04/06/20 03:28 PM
BludRacing, Cacciatore, Thomcat316, NTexian, LateLifeCrisis
71116 Registered Users
32 registered members (cabriopeugeot, dbias, blufeb95, Char Baby, 73guna, 3 invisible), 1,191 guests, and 19 spiders.
Topics303,700
Posts5,240,225
Members71,116
Would you change this antifreeze? #5378384 03/17/20 08:24 AM
Z
ZZman Offline OP
Z
Just bought a 2014 Ford Fusion with 28,000 miles. Unknown maintenance.
Since the car is 6 years old and maintenance is unknown, would you do a drain and fill of the antifreeze?
Don't they usually say like 100,000 miles or 5 years?
2005 Toyota Avalon XLS 3.5 motor
2014 Ford Fusion 2.5 motor
Re: Would you change this antifreeze? [Re: ZZman] #5378388 03/17/20 08:30 AM
W
WyrTwister Offline
W
I would seriously consider it .
If feasible , drop the lower radiator hose & dump as much as will come out . Fill with the same it had in it . Guessing , around a gallon . I always purchase 100% coolant , not pre-mix .
Inspect all the hoses / belts , while you are at it .
Wyr
God bless
Re: Would you change this antifreeze? [Re: ZZman] #5378395 03/17/20 08:37 AM
Schmoe Offline
Leave it....28K miles is nothing. I disagree using 100% coolant.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
2018 CRV EX-L
2017 Accord Coupe V6 EX-L 6AT
Re: Would you change this antifreeze? [Re: ZZman] #5378397 03/17/20 08:37 AM
Snagglefoot Offline
I vote yes. Time is just as important as mileage when it comes to coolant. There are 10 year coolants out there but I prefer 5. I have a 20 year old car with the original radiator and water pump, using the 5 year strategy. Just sayin'. smile
If you want the job done right......do it yourself.
Re: Would you change this antifreeze? [Re: ZZman] #5378398 03/17/20 08:38 AM
Char Baby Online Content
Online Content
ATF as well and brake fluid too.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Would you change this antifreeze? [Re: ZZman] #5378413 03/17/20 08:50 AM
dadto2 Offline
I just dumped 5 year old coolant from my wife's S60. The mileage is only 25k. Mechanic said he had to back flush the heater core as it was starting to clog a little. As they say about PM... Pay now or pay later.
'16 GMC Sierra 1500 Crew Cab 4.3
'15 Volvo S60 T5 AWD
'99 Volvo S70 2.4
Re: Would you change this antifreeze? [Re: Char Baby] #5378421 03/17/20 08:57 AM
Z
ZZman Offline OP
Z
Yes I have the trans fluid ready. Was thinking of brake fluid flush as well.
Re: Would you change this antifreeze? [Re: Schmoe] #5378424 03/17/20 09:00 AM
L
Lubener Offline
L
AGE has more to do with it than mileage when it comes to coolant.
The "thinking" man's friend.
Re: Would you change this antifreeze? [Re: Schmoe] #5378432 03/17/20 09:05 AM
Online Content
[quote=Schmoe]
I think WyrTwister meant...purchase 100% coolant(and a gallon of distilled), mix your own.
Re: Would you change this antifreeze? [Re: ZZman] #5378433 03/17/20 09:07 AM
R
ragtoplvr Offline
R
I also only buy 100% coolant, then I dilute using distilled water to 50 to 60% antifreeze. It is less expensive that way.
I do partial drain and fill every presidential election year as I can not stand the commercials. I find spending time in the shop is much more relaxing. And I never forget.
Rod
Re: Would you change this antifreeze? [Re: ZZman] #5378556 03/17/20 11:17 AM
J
Jimzz Offline
J
I would do a drain/fill now on the coolant and also the trans fluid.
Do trans around 65k next time then trans and coolant again at 100k as long as it does not sit again.
yup
Re: Would you change this antifreeze? [Re: ZZman] #5378570 03/17/20 11:38 AM
W
walterjay Offline
W
I would get a test strip and see what the condition is. No sense throwing good antifreeze into the environment.
Re: Would you change this antifreeze? [Re: ZZman] #5378623 03/17/20 12:29 PM
Chris142 Offline
Yes. It's past the recommended time.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Would you change this antifreeze? [Re: ZZman] #5378711 03/17/20 02:18 PM
J
JohnG Offline
J
What does the owners manual say?
Dexcool, when it first came out was blamed for a lot of cooling system failures. People thought it would be good for 150,000 miles. They forgot about the 5 year part entirely. Time is more important than miles when it comes to coolant, particularly when all aluminum engines are involved.
The only thing that puzzles me is the 2018 Mercedes that I have. There is no recommended coolant changes out to about 10 or 12 years! (forget exactly which right now) No mileage limit involved. No mention of coolant change on the maintenance chart either, which goes past 110,000 miles.
Strange to me.
Re: Would you change this antifreeze? [Re: Schmoe] #5380015 03/19/20 04:28 AM
Donald Offline
While one might add 100% coolant, the final mixture in the cooling system needs to be 50/50, maybe 60/40 if in the artic.
100% coolant cools worse than the proper mixture.
Now some who have flushed several times with plain water add 100% coolant to bring the system to 50/50.
2015 Ford F-250 w/Powerstroke
