Gas Buddy Question
by Wolfshead - 03/29/20 03:30 PM
Caliper piston boot
by painfx - 03/29/20 03:25 PM
Graphene the next detailing protection
by Mamala Bay - 03/29/20 02:17 PM
Anyone here a blacksmith?
by 53' Stude - 03/29/20 02:13 PM
Buying products made outside the USA
by 007 - 03/29/20 01:22 PM
Marine oils on sale at Canadian Tire
by Snagglefoot - 03/29/20 12:42 PM
0W16 instead of 0w20?
by Mter00s - 03/29/20 12:36 PM
XG10575 Walmart.com deal
by 762fermeandyou - 03/29/20 12:29 PM
Virgin ACDelco PF1245 cut and post
by nwjones18 - 03/29/20 11:49 AM
Oups, forgot oil cap...
by M119 - 03/29/20 11:46 AM
Recommendation for tuned BMW N55?
by RIPGermanCastrol - 03/29/20 11:15 AM
Electrician's Help With Circuit Breaker ?
by doitmyself - 03/29/20 11:07 AM
Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
109 registered members (2oldtommy, 53' Stude, 2015_PSD, 645ja, ARCOgraphite, AZjeff, 7 invisible), 2,201 guests, and 19 spiders.
Topics303,317
Posts5,233,869
Members71,038
Fuel Filter #5378262 03/17/20 02:40 AM
R
rrretiree7 Offline OP
R
In my Jeep Liberty3.7L what are some symptoms if I need a new filter? Thank you
Re: Fuel Filter [Re: rrretiree7] #5378270 03/17/20 03:31 AM
B
blufeb95 Online Content
Online Content
B
A clogged fuel filter would usually cause the car to not start or have difficulty starting and cause fuel delivery problems that may cause the CEL to come on that can't be explained by ignition issues or bad sensors.
Re: Fuel Filter [Re: rrretiree7] #5378271 03/17/20 03:33 AM
O
Olas Offline
O
If the fuel filter is completely blocked the engine will not run because no fuel can get through the filter.
If the filter is partially blocked you *might experience lack of power at high RPM or slow acceleration.
Does the car have any problems? What makes you think the fuel filter is due to be changed? If the car starts and drives as normal the filter is most likely still ok.
Cable ties should hold it
Re: Fuel Filter [Re: rrretiree7] #5378285 03/17/20 04:44 AM
L
Lubener Offline
L
Symptoms will begin to appear during peak engine demands where fuel flow is at its peak.. You may notice it will start getting more difficult to merge onto the freeway. I had one on a Ford van and the van wouldn't go faster than 50 mph without shuddering and the CEL coming on. It idled and started ok but that isn't considered "peak". Of course fuel pressure is going to go down too if you can measure it. I change mine every 30-40k just to avoid problems but it only takes one tank of bad gas to ruin a new fuel filter.
The "thinking" man's friend.
Re: Fuel Filter [Re: rrretiree7] #5378291 03/17/20 05:24 AM
O
Olas Offline
O
Depending on the location of the filter, you may find futuure maintenance easier if you move it to another location. If its in the tank it can be a pain to change but if its in the engine compartment itll be easier to access...
Re: Fuel Filter [Re: rrretiree7] #5378325 03/17/20 06:34 AM
Donald Offline
The car might idle and run slow but as you press the gas pedal it will bog down.
Gas is very clean these days. When I pulled a gas tank on my 1993 Suburban inside was pristine. Its always possible for one to get a bad load of gas or ex-wife to have messed with gas tank.
But a clogged fuel filter would not be high on my list.
2015 Ford F-250 w/Powerstroke
Re: Fuel Filter [Re: rrretiree7] #5378362 03/17/20 07:42 AM
J
Jimzz Offline
J
The Liberty 3.7 only had a fuel filter from 2002 to early 2004 models. They are usually good for 100k unless someone puts something in the gas tank that should not be there.
rockauto has one for $30. They rarely clog up anymore as gas p[umps are required to have filters on them now. Hence why most cars do not have fuel filters anymore.
yup
