Facebook Marketplace riddled with scam RV ads
by atikovi - 04/01/20 08:14 PM
2017 Corvette / 14.4k / ACDelco MTF
by dparm - 04/01/20 08:10 PM
Replacing Rusty Brake Lines
by 92saturnsl2 - 04/01/20 08:08 PM
2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
118 registered members (92saturnsl2, 14Accent, 69GTX, AC1DD, 5AcresAndAFool, ABomb369, 16 invisible), 1,722 guests, and 24 spiders.
Topics303,455
Posts5,235,493
Members71,072
Page 1 of 3 1 2 3
Genuine Toyota or aftermarket brake pads #5378155 03/16/20 09:19 PM
L
Leo99 Offline OP
L
Going to change the pads in my Camry. Just over 100k miles. Pads have a little life left in them but I'm working from home until at least the end of March and probably longer and the golf courses are starting to close near me. I'll have time to do this job so might was well knock it out.
Genuine Toyota pads and rotor and shim kit will cost me about $225 delivered. Raybestos pads and rotors with included hardware will cost about $105. Is genuine Toyota worth the extra cost?
I'd really like to change the pads/rotors and not have to worry about them for another 100k miles.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: Genuine Toyota or aftermarket brake pads [Re: Leo99] #5378157 03/16/20 09:22 PM
CT8 Offline
Toyota.
2015 F150 2.7
2018 F350 6.2
Re: Genuine Toyota or aftermarket brake pads [Re: Leo99] #5378182 03/16/20 10:01 PM
B
benjamming Offline
B
Why are you replacing rotors already?
Anyway, I would stick with Toyota rotors.
What do you prioritize from pads? OEM performance - stopping, dust, etc.? Akebono would have been a potential supplier & provide very similar pad performance to OEM. Let price determine between Akebono & OEM.
Note that you can get Toyota parts from online dealerships and save ~ 30%. Apologies if you already knew that & have that factored into your pricing.
Re: Genuine Toyota or aftermarket brake pads [Re: Leo99] #5378191 03/16/20 10:13 PM
G
GMBoy Offline
G
Raybestos rotors and their EHT pads. Better than stock.
Re: Genuine Toyota or aftermarket brake pads [Re: benjamming] #5378194 03/16/20 10:16 PM
L
Leo99 Offline OP
L
The rotors looks good to me but I read it's good idea to replace them. I'm on the fence if I should replace the rotors.
The factory pads are quiet, almost no dust, last long time, and work fine for my driving.
Yes, the cost is from a Toyota dealer on ebay. My local dealer wanted $100 for the pads and $30 for the shim kit. Pads with shim kit is $70 online
Re: Genuine Toyota or aftermarket brake pads [Re: Leo99] #5378196 03/16/20 10:17 PM
P
PowerSurge Offline
P
Toyota pads are better than most OEM’s in my experience. But if not them, I use Akebono.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: Genuine Toyota or aftermarket brake pads [Re: Leo99] #5378237 03/17/20 12:19 AM
Dave9 Offline
Toyota doesn't make pads. ID them, then get from the manufacturer brand if you must have the same thing, but the truth is, there are multiple brands that would do fine. It is not brand but TYPE of pad that you should consider, then compare the price of that type from each brand, at the suppliers you'd consider using.
Re: Genuine Toyota or aftermarket brake pads [Re: Leo99] #5378249 03/17/20 01:14 AM
K
Kamele0N Offline
K
If that helps.... My Yaris has ATE stamps/inprints all over the brakes....on discs.... On calipers...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Genuine Toyota or aftermarket brake pads [Re: Leo99] #5378261 03/17/20 02:37 AM
O
Olas Offline
O
Toyota do not manufacture brake pads, so there is no such thing as 'Genuine Toyota Brake Pads'.
They approach most or all of the pad manufacturers and ask who can commit to producing X million pairs for less than Y price - whoever can do it quickest/cheapest gets the contract. Somewhere along the production/distribution/retail line, a Toyota sticker is put on the box.
You can buy any pad that fits, and if you take the time to heat-cycle and bed the pad properly then it will be fine.
Remember that supply chains change all the time but recently we had a discussion in whihc it was deterined that Akebono make a lot of pads to order for Toyota
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/1718216/toyota-brake-pad-questions
Cable ties should hold it
Re: Genuine Toyota or aftermarket brake pads [Re: Leo99] #5378265 03/17/20 02:59 AM
The Critic Offline
Make sure the pads are not the 04465-AZXXX pads. Those are the TCMC Premium pads which are different than the factory originals.
https://www.toyotapartsandservice.com/wp-content/uploads/2019/11/04_BrakePads2019.pdf
2011 Toyota Prius 1.8L - 206K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 144K - Valvoline Premium Blue Restore 10W-30
Re: Genuine Toyota or aftermarket brake pads [Re: Leo99] #5378272 03/17/20 03:36 AM
O
Olas Offline
O
Why not consider the Pagid RS line for better stopping power? Your brakes are your safety! Its your brakes that stop you from killing kids aas they run accross the road without looking. Brakes are joint first with tyres as the most important part of your vehicle, so you want the best brakes you can source on the open market.
Pagid RS or Carbon Lorraine give you the most stopping power - using anything less is just negligent.
Re: Genuine Toyota or aftermarket brake pads [Re: GMBoy] #5378294 03/17/20 05:36 AM
J
Jimzz Offline
J
Yep I run these on many cars, including toyota. I like either the premium raybestos rotors or at least the coated ones.
yup
Re: Genuine Toyota or aftermarket brake pads [Re: Leo99] #5378310 03/17/20 06:07 AM
T
Trav Offline
T
You may want to consider Advics also, good pads and an OE supplier.
Re: Genuine Toyota or aftermarket brake pads [Re: PowerSurge] #5378324 03/17/20 06:33 AM
W
wag123 Offline
W
Toyota's OEM brake pads are manufactured by Akebono.
I have been using Akebono brake pads for years and I strongly recommend them.
Re: Genuine Toyota or aftermarket brake pads [Re: Leo99] #5378364 03/17/20 07:47 AM
A
atikovi Online Content
Online Content
A
[The rotors looks good to me but I read it's good idea to replace them. I'm on the fence if I should replace the rotors.
Unless they are too thin or causing a pulsation, there is no need to. You read it's a good idea to replace them because parts stores and shops are in business sell parts and service. If you do replace them, make sure you clean the hub real good for any rust or corrosion.
Page 1 of 3 1 2 3
